Welcome to the North American Subaru Impreza Owners Club Thursday October 19, 2017
Old Today, 10:31 AM   #26
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Originally Posted by Obviously Tyler View Post
Your parts photos are always so good. They're my favorite part of your build threads.
Thanks!
Originally Posted by JLEET View Post
Yay! Found it! A reason for me to get back on Nasioc!
Agreed. I didn't go on here for many months. It's a good way to keep track of all my changes though.
Old Today, 10:57 AM   #27
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I picked up the MAPerformance header and had it modified by Fobia for EWG. The gate placement is similar to a configuration that BNM performance, but they are not taking orders until next year, so I had this all done locally over a weekend. The MAP header is a 4-1 merge design which lends itself to putting the gate directly on the header. Fobia made my previous foglight kit and this is similar to how he sets up the wastegate on that header so it was an easy modification.
The MAP header has very smooth bends and a formed merge section (as opposed to cut and welded). The fitment was perfect and the primary design made all bolts very easy to access with a straight socket and extension, except for one that I needed to use a swivel. The wastegate position was very close to the AVCS connectors and timing cover but it does clear. It has plenty of room on the radiator and frame rail side. It likely could be angled down a few degrees for extra clearance but I will re-evaluate if that's needed in the future.
Old Today, 11:01 AM   #28
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I installed the GrimmSpeed wastegate bracket, put in new plugs (NGK 6619 LFR6AIX-11 IX Iridium gapped to 0.028"), and changed the oil. Then I swapped on some 17" BBS wheels, ran the gas tank down close to empty, and filled up with E85.
Engine Bay
17" BBS from 2006 STI
E85 Swap
Only $1.75/gal
Old Today, 01:44 PM   #29
baggedhawk
Member#: 344203
life in Nasioc again.....
Keep the updates coming!
baggedhawk is offline   Reply With Quote
Old Today, 02:34 PM   #30
tmnc09
Member#: 397956
2009 WRX
Bummer you got rid of the tail lights, I really like them and want to do that to my 09
tmnc09 is offline   Reply With Quote
Old Today, 02:49 PM   #31
TDagen
Member#: 163648
2002 Resurrected WRX
Wow, you are really making good progress.
E85? Yes please.
Old Today, 03:15 PM   #32
Dave D.
Member#: 130990
06 Red Ltd.Wagon
20g-xtr jdm 6-spd JJtuned
I'd like to see those 50-100's again as your build progresses!
