#1 |
Member#: 532275
Vehicle:2002 Impreza WRX |
![]() Hello all,
Around 3 weeks ago I got a new clutch and clutch assembly on my 02 wrx (slave cylinder, master cylinder) done by a reputable shop. In the past week I started noticing some squeaking and resistance in the clutch pedal. Yesterday I decided to go under the car to see if there was anything obvious and I noticed right where the slave cylinder meets the spring (not sure what this is called) there is reddish fluid with some of it dripping down. I’m wondering if this is clutch fluid or grease? And if this could have to do with how the clutch has been feeling? (I have pictures just unsure how to post them) Thanks! Last edited by Subicat; 03-17-2023 at 04:39 PM. Reason: Unfinished |
#2 |
Member#: 512891
Vehicle:2010 STi/21 Passport RIP 19 WRX & 16 FXT |
![]() As far as posting pictures, you are going to have to use an image hosting site that isn't Imgur. Or you can just post the Imgur links as text so people can select ctrl+c+v it into the browser. I can't help with your real issue unfortunately, good luck!
#3 |
Add Lightness
Moderator Member#: 13699
Vehicle:2021 Building It Better |
![]() If the mechanic properly did the job, there would be no red fluid anywhere. Regular brake fluid goes into the reservoir.
Just as a point of interest, replacing the master and slave is a cake job. Easy enough to do that it's worth just doing if you think either piece is bad. Take off the intercooler and the job is a big nothing. |
#4 | |
Member#: 333468
RMIC
Vehicle:93 SS - 06 OB XT 03 WRB GD 205/22T 20G-XT |
![]() Quote:
