07-25-2014, 10:45 AM | #826 | |
Member#: 286408
Vehicle:WFC #952 Function:error! |
Btw if you ever need to go to Cincinnati or Lexington I can get you there on E easy too. I went to import alliance on E and it was actually really easy just had to call some stations
07-25-2014, 10:48 AM | #827 |
Member#: 305107
Vehicle:2016 GT 5.OHH DIB |
thats def high, i just filled up today and it was 2.77. but its not true e85, my zeitronix reads 77-78 but thats ok by me, thats what my tune is based on, im just hoping i dont see some crappy ethanol at 70 or below
07-25-2014, 11:24 AM | #828 |
Member#: 327511
Vehicle:13' WRX 6 Speed 11sec VF52 EL-EWG-E85 |
I've seen it mid 3s in Chicagoland, but also have seen it at 2.74, so it depends where you are I guess. My local station I frequent is 2.99 and tests 90% every time.
07-25-2014, 11:32 AM | #829 | |
Member#: 261612
Vehicle:2002 WRX - 750WHP 9.5s @ 150mph |
Holiday brand is always the cheapest in MN. Usually about $0.80 cheaper than 87 octane. Right now that puts it under $2.50. Other stations are much closer to pump gas, so they're probably around $3 right now. |
07-25-2014, 04:53 PM | #830 |
Member#: 307725
Vehicle:2012 WRX Now 2015 WRX |
am I seriously the only person who caught on to the $355 jokes vs. $3.55 as it should be formatted lmao.
also I pay $2.99 right now for E |
07-25-2014, 05:01 PM | #831 |
Member#: 261612
07-25-2014, 05:36 PM | #832 |
Member#: 321728
Vehicle:2011 WRX Limited DGM |
I know I choose to ignore bens antics I won't fuel him anymore lol!
Sent from my iPhone using NASIOC |
07-25-2014, 05:41 PM | #833 |
Member#: 261612
Went right over your head.
07-25-2014, 07:20 PM | #834 |
Member#: 321728
Ok we dokey sir as I said lol
07-25-2014, 07:51 PM | #835 |
Member#: 261612
You just didn't get it. Thats OK.
07-26-2014, 10:19 PM | #836 |
Member#: 261612
Another shot from when I met up with my friend's 2015 STI.
07-28-2014, 10:23 AM | #837 |
Member#: 261612
I think it's time to go bigger. My stock location GTX3071 hybrid is now up for sale.
http://forums.nasioc.com/forums/show....php?t=2651944 |
07-29-2014, 12:22 AM | #838 |
Member#: 261612
Turbo is sold, out of the car, and boxed up (original box with foam).
07-29-2014, 02:58 AM | #839 |
Member#: 272471
TXIC
Vehicle:2010 WRX FlareObody Red |
40R or bust!
07-29-2014, 07:51 AM | #840 |
Member#: 261612
07-30-2014, 10:25 AM | #841 |
Member#: 261612
It appears I had a bit of an uppipe to turbo leak. That could explain the late-ish spool.
07-30-2014, 10:50 AM | #842 |
Member#: 327511
I've got one myself, gonna smoke it to make sure where it is- I'm suspecting the flex section. Mine is bad enough that my wideband is reading lean at idle, did yours?
07-30-2014, 10:56 AM | #843 |
Member#: 261612
No, it didn't. And I checked all around the header/uppipe/turbo/EWG with the car idling and I didn't notice any leaks. It may have only leaked under boost.
07-30-2014, 11:00 AM | #844 | |
Member#: 327511
so, next turbo going to sit crooked? |
07-30-2014, 11:03 AM | #845 |
Member#: 261612
No, it won't.
07-30-2014, 11:08 AM | #846 |
Member#: 327511
07-30-2014, 11:11 AM | #847 |
Member#: 261612
07-30-2014, 12:21 PM | #848 | |
Member#: 172698
Vehicle:11 STi BW 8374 E85 02 v8 Spec C E85 |
I was thinking about going to a 35r setup on my car but I'm starting to lean more towards the 8374 now. I'll be curious what you end up with. Any ideas or options you are leaning towards right now? |
07-30-2014, 12:39 PM | #849 | |
Member#: 261612
I still think the journal bearing PTE turbos are far and away the best value for the money. It's too bad that they're pushing all their new offerings over to ball bearing only. At that point they are getting close in price to most everything else. The new turbo will be something in the size range of the DOM 4, FP Red, GT3576, etc. That's the plan at least. I suppose that's similar to a 7670 as well. It would be hard to compare since I'm guessing their setup is far different than mine. |
07-30-2014, 12:56 PM | #850 | |
Member#: 172698
You are saying stock location then? Justin put a Dom 4.0 on his RS with the new motor. 9:1 CR, S2 cams, etc. We maxed the turbo out and it put down 580 whp @ 30 psi on the superflow dyno. Its damn quick for a stock location turbo car. |
