Welcome to the North American Subaru Impreza Owners Club Monday October 14, 2024
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 02-06-2010, 01:30 PM   #1
breathinez
Member#: 79859
2002 384 whp
332.5 lbs
Default Can UTEC run an 06 sti engine in my 02 wrx w/ AVCS?
OK probably noobish question but I am unfamiliar with the UTEC. I have a 02 wrx and have a 06 sti engine, with the AVCS. The car has the wrx minifold and tb, so its cable driven. There is a guy on here that wants to sell me a UTEC. He says it has the sti conversion. Is there a paticular UTEC that can run my setup?
breathinez is offline   Reply With Quote
Old 02-06-2010, 05:06 PM   #2
breathinez
Member#: 79859
2002 384 whp
332.5 lbs
Looks like this want work. The guy who had the UTEC for sell said one of his tuning buddies in Tenn said I would still have to run the Hydra for the AVCS.
OK now I the guy says he thinks it will work...I have no idea. Any help with this from persons in the know.
Old 02-13-2010, 10:15 AM   #3
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
The UTEC cannot run AVCS, nor can the 02 WRX ECU.
You can use the UTEC to tune your car with the STI engine if you are using the WRX cam sensors. If you are using the STI cam sensors then no, the UTEC cannot be used. nor can your 02 WRX ECU.
mick_the_ginge is offline   Reply With Quote
06 sti radiator in to 02 wrx???? badgerbugeye Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-30-2010 01:33 AM
trying to swap an 05 sti engine into my 02 wrx chinpocoman Subaru Conversions 8 02-11-2009 09:25 AM
Would a stock turbo inlet from an 06 STi work on my 02 wrx ? mrrallysti Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-28-2007 04:54 PM
Would a stock turbo inlet from an 06 STi work on my 02 wrx ? mrrallysti Southern California Impreza Club Forum -- SCIC 0 12-28-2007 01:36 PM
JDM STi Pedals in my 02 WRX thrdeye Interior & Exterior Modification 15 06-26-2005 09:11 PM
