Welcome to the North American Subaru Impreza Owners Club Monday September 21, 2020
Old 01-30-2014, 01:20 AM   #1
Cbreakin
Member#: 349443
2013 WRX
Default 2011+ STI lower control arms on a 2011+ WRX
So today I successfully installed 2011+ STI aluminum lower control arms on my 2013 WRX hatch. It's a 100% bolt on affair with the only parts required being the lower control arms themselves and the STI rear mounting bolts (the WRX uses a stud and nut). After installation I test dove the car, there is definitely more NVH transmitted into the cabin, it's not excessive, but there none the less. The car feels somewhat "tighter" if that makes sense. Other than that not too much changed in the steering feel other than the wheels returning to center slightly easier/faster. Overall I'm happy with the mod, however unless you find a smoking deal on the LCAs the cost to benefit ratio just isn't there. Just thought I'd share if anyone was interested. Thanks for reading.
Cbreakin is offline   Reply With Quote
Old 01-30-2014, 01:44 AM   #2
ToneWrx02
Member#: 239095
2002 Wrx
Thanks i was curious about actual benefits.
Unless i get some free i wont purchase.
ToneWrx02 is offline   Reply With Quote
Old 01-30-2014, 01:26 PM   #3
Robin2
Member#: 390
2020 Forester Sport
Dark Grey
i changed mine 2 years ago. lot better than the groupN mount which i tried. and caused way more feedback through the steering wheel.
i'd do suspension and then control arms after.
Robin2 is offline   Reply With Quote
Old 07-01-2015, 02:41 AM   #4
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
Good to know... I plan on swapping to these arms when my stock WRX LCA rear rubber bushings rip themselves to pieces (or rather just before)
For the 2011 WRX, nothing else needs to change right? Just the arms? Same axels, same everything?
chimchimm5 is offline   Reply With Quote
Old 07-01-2015, 09:53 AM   #5
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg 2+ 310/370, 6sp R180
I did this mod on my narrowbody 2010 wrx like 2-3 years ago. very happy with it. I like the greased/sealed/booted pillowball joint. a bit more involved on the narrow body though. I swapped out my axles and inner tie rods for longer units.
gsrcrxsi is offline   Reply With Quote
Old 07-11-2015, 01:49 PM   #6
moviemedic
Member#: 327627
LIGHTNING RED, 2003 R1
Thanx for the info. I've been considering the swap out.
moviemedic is offline   Reply With Quote
