Welcome to the North American Subaru Impreza Owners Club Tuesday September 22, 2020
Old 08-08-2019, 05:09 PM   #1
maxbr7t
Member#: 206215
2005 9-2x Aero
Default 05 WRX Leakdown test issues
I have a blinking CEL misfire that was showing all cylinders and now only showing 4. I'm trying to diagnose the issue.
I'm trying to perform a leakdown test, I got the engine to TDC (via Cam markings) and when I turn up pressure(to 70psi) it just rotates the engine. So I tried holding the crank pulley bolt steady with a ratchet and when I hit about 60psi it just unscrewed my crank bolt. Either way, the leak down tester was showing 100% leakdown the entire time and I can hear air pissing out the entire time.
I made sure I was on compression stroke
I made sure my hose is seated snug into the cylinder
No matter what, air is pissing out from somewhere around the cylinder when I'm turning up pressure.
Can someone tell me what I'm doing wrong?
maxbr7t is offline   Reply With Quote
Old 08-08-2019, 05:26 PM   #2
Waddlz
Member#: 395275
2012 STi
its easier with two people. You could brace the crank pulley somehow but I've never tried by myself.
but you need to hold the crank bolt. Use a breaker bar
Every time I do one I use a breaker bar and have someone else check it for me. Never had the crank bolt come undone.
I usually slowly turn the crank clockwise until I get almost 1:1 pressure ratio, around 10 or 15 psi.
Then I hold it there and have that person crank it til it hits ~100. its going to be a PITA to hold but you only need to do so until 90 psi. but if you are truly getting 100% leakdown you have a cracked ringland or bad valve.
Waddlz is offline   Reply With Quote
Old 08-08-2019, 06:16 PM   #3
maxbr7t
Member#: 206215
2005 9-2x Aero
I'm going to try a different cylinder tomorrow and if it I have the same issue I'll just rip this stupid engine out and visually inspect the head.
Old 08-08-2019, 10:11 PM   #4
subaru_gc8
Member#: 29292
2004 WRX wagon
did you do a compression test first? why do you need to do a leakdown?
Old 08-09-2019, 03:16 PM   #5
maxbr7t
Member#: 206215
2005 9-2x Aero
Didn't do a compression test yet. I started with the leak down, I was thinking it might be a blown headgasket
Old 08-14-2019, 07:59 AM   #6
User_Name_1944
Member#: 497803
Any answer on this? Bad rings? Bent valves? Head gasket?
User_Name_1944 is offline   Reply With Quote
Old 08-14-2019, 09:52 AM   #7
subaru_gc8
Member#: 29292
2004 WRX wagon
if its a blown head gasket the signs are different. when subarus blow a headgasket it pushes exhaust gases into the coolant passages and it pukes it out of the over flow. for that you dont do a leakdown you do a block test.
