Welcome to the North American Subaru Impreza Owners Club Monday September 28, 2020
Old 04-29-2019, 04:49 AM   #1
PrinceVegeta
Member#: 428946
2008 JDM WRX
Default Girodisc 2 Piece Floating Racing Rotors Rear
Hey guys,
I recently purchased the Girodisc 2 Piece Front Rotors Ring replacement as my Fronts needs to be replaced soon.
Link here: https://www.girodisc.com/Girodisc-2p...Ti_p_5728.html
At the same time, I decided to complete the whole look and got the Girodisc 2 Piece for the Rears as well (because racecar) and so that I can brag to my friends that I had 2 piece floating rotors in the Front AND Rear.
Link here: https://www.girodisc.com/Girodisc-Re...Ti_p_5527.html
The Girodisc Rears weigh only 11lbs, which saves 7lbs over the Stock Unit (18lbs)
My initial butt dyno noticed a difference is the acceleration of the car with the Rear Girodisc Rotors installed.
I felt that it was slightly quicker and less sluggish than before off the line, especially from a dead stop.
The Rotors looks absolutely beautiful and the Made in USA quality is definitely evident
If you are looking to replace your rotors, look no further than Girodisc! #NoRagrets
https://i.imgur.com/7zMYSNz.jpg
Unboxing Video:
PrinceVegeta is offline   Reply With Quote
Old 05-28-2019, 10:07 PM   #2
Fierysun
Member Sales Rating: (109)
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
So you no longer have parking brakes?
Fierysun is offline   Reply With Quote
Old 05-28-2019, 10:32 PM   #3
[email protected]
Member#: 280104
2019 Subaru STi
Yeah what’s going on with your parking brake
Theo@theoharris.com is offline   Reply With Quote
Old 05-29-2019, 04:42 PM   #4
car_freak85
Member Sales Rating: (41)
Member#: 13530
EA63 , EA81T, EJ20G,
EJ205
I think those rotors still use the internal area of the aluminum hat as the parking brake drum. Just don't drag the parking brake while you're rolling....
car_freak85 is offline   Reply With Quote
Old 05-31-2019, 06:20 PM   #5
Fierysun
Member#: 82745
2005 Subaru STI
LOL the aluminum hat is not a parking brake drum. In effect, there's no parking brake.
Old 06-04-2019, 03:14 PM   #6
car_freak85
Member#: 13530
EJ205
We won't know unless we buy one, see a photo of the back side, or ask Girodisc.
It's not as if the parking brake drum is a high-wear part. the shoes only make contact with the drum when the vehicle is sitting still. I agree AL is not the right material, but the parking brake would still work pretty dang well with an aluminum drum, I would suspect...
Old 06-04-2019, 05:12 PM   #7
Fierysun
Member#: 82745
2005 Subaru STI
That hat has very little contact with the drum brake as compared to a rotor that's designed for it. I wouldn't trust it to hold the car.
Old 09-09-2019, 11:40 AM   #8
ether947
Member Sales Rating: (20)
Member#: 297799
2003 WRX
EJ207 version 8
Looks like the parking brake is retained.
http://www.westernsubaruclub.com/smf...?topic=37593.0
ether947 is offline   Reply With Quote
Old 09-09-2019, 05:28 PM   #9
WRXnick16
Member#: 447898
2016 WRX (traded)
2019 STI CWP
Thanks for sharing.
I hope to pick these up for my '19 STI when I do my first pad/rotor change down the road. I recall KNS posting that the Girodisc rears aren't possible for the 18+ STI because they would require a shorter pad and/or a lot of grinding. Looks like the DBA's are the only slotted option for the rear at this time.
WRXnick16 is offline   Reply With Quote
Old 09-28-2019, 11:55 AM   #10
Stickers
Member Sales Rating: (1)
Member#: 301428
2015 WRX
CWP
Originally Posted by WRXnick16 View Post
Thanks for sharing.
Send them info or a set of OE rotors and they would probably make them for the market.
The parking brake functions as normal. All 2008-2017 STIs as well as 2015-2017 WRX use the same knuckle and e-brake assembly. Mine are on and work correctly on a 2015 WRX.
Stickers is offline   Reply With Quote
