Welcome to the North American Subaru Impreza Owners Club Friday January 17, 2020
Old 08-21-2017, 09:50 AM   #1
azatabbasov
Member#: 405143
Default 2004 WRX stage 2 + E85?
Hello. I currently have a 2004 wrx that's currently getting installed
Short ram intake
Unequal length headers
Cattles up pipe
Cattles down pipe
Cat back exhaust
Cobb boost controller
565 injectors
Walbro 255 fuel pump.
Now my question is I'm shooting for 280 WHP and wanted to know if I can go open source just on stage 2 and achieve they or am going to need to go e85 as well? Also will the stock TD04 hold 280WHP?
azatabbasov is offline   Reply With Quote
Old 08-21-2017, 10:28 AM   #2
subaru_gc8
Member#: 29292
2004 WRX wagon
sure but you are going to need bigger injectors for e85 at least 850
Old 08-21-2017, 11:46 AM   #3
azatabbasov
Member#: 405143
She get bigger injectors? The stock turbo should hold the the power?
Old 08-21-2017, 05:04 PM   #4
LAS04subie
Member#: 379520
2005 Wrx
I have Vf48 e85 full exhaust intake id1000 unequal header... im making 320 whp. Without e85 I was making 280 still with the vf48. Never pushed my td04. I have a 2005 wrx
LAS04subie is offline   Reply With Quote
Old 08-21-2017, 09:34 PM   #5
peeledback7777
Member#: 112543
if you have a stock transmission, the amount of torque you'll get with e85 & a td04 might snap gears relatively quickly
peeledback7777 is offline   Reply With Quote
Old 11-06-2019, 06:50 PM   #6
kolton1119
Member#: 508110
Default 2004 wrx stage 2 e85
So i have a 2004 WRX and iím wanting to switch to e85 with a ots map but am wondering what supporting mods it will need. Will i have to upgrade my injectors or fuel pump at all?
kolton1119 is offline   Reply With Quote
Old 11-06-2019, 08:08 PM   #7
sig
Member#: 318247
if its an ots map it really depends on what the map requires doesnt it? But yes you will need at least bigger injectors id go with 1000cc and a walbro 255 pump
sig is offline   Reply With Quote
