Welcome to the North American Subaru Impreza Owners Club Monday January 20, 2020
Old 07-28-2019, 08:11 PM   #1076
oichan
Member#: 492327
19 WRX / 16 STI
17 Golf-R / 16 FiST
Took my STI out for a spirited run yesterday and today and found it developed a squeak (metal to rubber sound) coming from the either the frame or rear suspension. I greased the rear swaybar bushings today with no improvement. Ordered a pair of Kartboy endlinks and will give it a shot in about a week.
It does not make any noise while going over bumpy roads nor going straight so I don't think it's the rear dampers or any other suspension/drivetrain related bushings. Only when the car leans while making quick left/right turns, going up/down driveway curb which points towards the swaybar/endlinks..
oichan is offline   Reply With Quote
Old 07-29-2019, 04:07 PM   #1077
08redWRX
Member#: 186068
2019 STi
Installed my new to me RCE black springs. Gave it a nice slight drop, went on a quick drive to the store and didn't notice to much change in ride quality.
08redWRX is offline   Reply With Quote
Old 07-30-2019, 06:13 PM   #1078
08redWRX
Member#: 186068
2019 STi
Really tried to hold off to install stage 1 Cobb OTS prior to 5k miles but that didn't work. Gave in and installed it today. Ordered Cobb SF intake and catted downpipe so will be stage 2 in about 3 weeks after I get back from NY.
Mod bug has taken over!!
Old 07-30-2019, 07:37 PM   #1079
oichan
Member#: 492327
19 WRX / 16 STI
17 Golf-R / 16 FiST
Nice! I too run the Cobb Stage1+. That along with a pair of Remark muffler deletes was all that I needed on my daily driver as far as engine related mods.
Old 07-30-2019, 11:30 PM   #1080
jdm05
Member#: 180155
05 Jdm Sti 2.0
jdm05 is offline   Reply With Quote
Old 07-31-2019, 01:01 AM   #1081
arempee26
Member#: 491364
Do you have a mid pipe paired with your Remark deletes or you're still on the stock mid pipe?
arempee26 is online now   Reply With Quote
Old 07-31-2019, 10:47 AM   #1082
oichan
Member#: 492327
19 WRX / 16 STI
17 Golf-R / 16 FiST
Stock midpipe on my WRX. My STI runs their SP CBE and Stage1+
Old 07-31-2019, 12:01 PM   #1083
thatgarrett
Member#: 497099
2007 Outback Sport
Urban Gray
Took my Hawkeye to redline today for kicks and heard a noise, looked back and saw the OEM exhaust tip fly off the car and go tumbling down the road. Guess I can say I have a high flow exhaust now haha
Now that itís gone I want to source another one, it looks weird without it...
thatgarrett is offline   Reply With Quote
Old 07-31-2019, 08:40 PM   #1084
oichan
Member#: 492327
19 WRX / 16 STI
17 Golf-R / 16 FiST
My Kartboy endlinks arrived for my STI. Will swap them out over the weekend in hopes it gets rid of the squeak/creaking noise..
Old 07-31-2019, 10:20 PM   #1085
gathermewool
Member#: 143624
14 FXTT (hers)
15 Legacy 2.5i Prem (his)
Based on another post, I decided to pull my MAP sensor (PRESSURE sensor, to be clear) in my 2014 Forester XT, which is installed directly atop the intake manifold, aft. It was coated with a very thin film of a very dark, oily like substance that had a 3D geometry (it stuck out from the bulb) A spritz of MAF cleaner from each of the four axis had it looking like new.
I've never seen a MAP sensor that looked, well, kinda like a MAF sensor. Any thoughts?
I forgot to grab a pic and will do so when I get the chance, but here's a dirtier example from another FXT:
Now that I think about it, I also forgot to add a dab of dielectric grease to the connector, which I do any time I take one apart.
P.s., the MAP sensor in my '15 Legacy 2.5 (non-turbo) is located in the same exact location, but appears as a normal MAP sensor of old, except it dips into the intake manifold, too, instead of having a vacuum tube attached to it.
gathermewool is offline   Reply With Quote
Old 08-01-2019, 08:11 PM   #1086
08redWRX
Member#: 186068
2019 STi
Installed my Cobb SF Intake with airbox and loaded Cobb Stage 1+. Nice to hear the turbo spooling up. Downpipe came along with the intake but that will have to wait until I get back from vacation.
Old 08-01-2019, 09:40 PM   #1087
shokoman
Member#: 504831
ordered new spoiler wings As well as today needs to come in clutch plates which I ordered on site . If the output will come and the wings, then arrange the garage a bit of a mess.
shokoman is offline   Reply With Quote
Old 08-01-2019, 10:03 PM   #1088
jdm05
Member#: 180155
05 Jdm Sti 2.0
Slowing adding more
Old 08-03-2019, 08:33 AM   #1089
sonicyellowbug
Member#: 504385
I blew my turbo on my 03 WRX lmao
sonicyellowbug is offline   Reply With Quote
Old 08-03-2019, 01:44 PM   #1090
oichan
Member#: 492327
19 WRX / 16 STI
17 Golf-R / 16 FiST
^^ Ouch..
For me, installed the Kartboy endlinks on the stock rear swaybar (hoping to rid this squeaking/creaking noise on my STI) and to my surprise the rear response feels refreshed and faster than the stockers. But the noise from the rear of the car worsened. LOL
After scratching my head for a while, and rethinking what would cause this noise, I realized the noise was coming from the Cusco rear cross brace. Loosened one of the bolts, retightened and creaking/squeak noise went away. It needed adjusting probably due to thermal expansion. I installed them while it was cold outside, so with the summer heat it appears it had to be re-seated in its brackets.
Oh well, at least it was not a total waste spending $125 on the rear endlinks.
Old 08-03-2019, 04:07 PM   #1091
baneonrt
Member#: 174281
Be careful. For a '19 STI Cobb does not have an OTS map for both their intake and downpipe installed. It's one or the other. Check the map notes for context but here is a quote from Kyle at Cobb answering a question about running the intake and dp.
"You'll have to return the intake to stock to run the Stage 2 maps. Another option would be to add the required fuel modifications and run the Stage 3 maps."
Steve
baneonrt is offline   Reply With Quote
Old 08-03-2019, 09:50 PM   #1092
Senfinger
Member#: 110912
2018 STi RA
Can you post pics and what you think of them... Also, thinking about these over yellows.
Senfinger is offline   Reply With Quote
Old 08-04-2019, 01:14 AM   #1093
carsebuco
Member#: 482289
2018 STI
Hope you still got that stock intake cause you'll need it to run stage 2. Otherwise, buy some new injectors.
carsebuco is offline   Reply With Quote
Old 08-04-2019, 02:37 PM   #1094
goldtop
Member#: 504860
Trying to diagnose odd intermittent drive train noise
goldtop is offline   Reply With Quote
Old 08-04-2019, 02:39 PM   #1095
Ej20ForesterGuy
Member#: 504717
02 Forester XT
https://imgur.com/n9vvbIR
https://imgur.com/RpuUAKD
Gonna try to remove these clip-on window trim/rain guard things because above 60km/h it sounds like the window is open. They're held on with a double sided tape. I'm hoping the tape glue comes off without taking the paint off underneath..
Ej20ForesterGuy is offline   Reply With Quote
Old 08-04-2019, 09:48 PM   #1096
kabz
Member#: 351744
2004 WRX Wagon
SRR
New windshield wipers. Topped up fluid.
Installed an old GFB BOV.
Changed the heater hoses (fixing a small coolant leak - causing little puddles anywhere I park with the car hot). pita job!
kabz is offline   Reply With Quote
Old 08-05-2019, 12:08 AM   #1097
Umbriss
Member#: 504839
2005 SAAB 9-2X Aero
Wired in a second cigarette lighter so I could tuck my dash cam wires behind the dash.
Umbriss is offline   Reply With Quote
Old 08-05-2019, 10:59 AM   #1098
MAD WRX
Member#: 472279
2015 WRX ( traded )
2019 WRX WRB
Blacked out my headlights, upgraded the c light with the drl harness and installed the tail as turn modules.
MAD WRX is offline   Reply With Quote
Old 08-05-2019, 04:41 PM   #1099
Jaakko
Member#: 504930
Tried to solve o2 sensor problem...
Jaakko is offline   Reply With Quote
Old 08-06-2019, 12:35 AM   #1100
jdm05
Member#: 180155
05 Jdm Sti 2.0
The complete set
