Welcome to the North American Subaru Impreza Owners Club Friday January 17, 2020
Old 10-21-2010, 07:26 PM   #1
SubieWReX
Member#: 151080
07 BME AutoX WRX
Default Tail Lights/Parking Lights not working?
Hey All,
I've tried searching for an answer to this, and have so far been unsuccessful. I recently changed my stock wrx seats with a set of Recaros, and have since run into this issue. I'm not sure if it is a coincidence or what.
I haven't had a chance to do the 3.3 om resistor trick to turn off the airbag light yet. Does this affect the tail and parking lights?
They light up when I press the brakes.
I checked the fuse for the tails and it is fine. I also checked all of the bulbs, which are fine.
Any suggestions/ideas?
Thanks.
Mark
SubieWReX is offline   Reply With Quote
Old 10-21-2010, 08:03 PM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
Check to see if they light up when you switch them on with the switch on the top of the steering column. If they work ok that way then the wiring to the lights would seem to be ok. The current to the lights from the normal light switch passes through the top switch also.
Cougar4 is offline   Reply With Quote
Old 10-21-2010, 09:37 PM   #3
SubieWReX
Member#: 151080
07 BME AutoX WRX
Just checked and the courtesy lights come on when I switch them on. But the brake lihts do not come on when I pull the e brake lever...
They lights blink when I lock the doors and unlock them.
Old 10-22-2010, 01:50 AM   #4
Cougar4
Member#: 53443
Winestone
The brake lights don't turn on with the emergency brake, only the brake pedal. The courtesy lights are inside the car. Did you mean to say the parking lights work ok when turn on the switch on top of the steering column? If that is ok then the trouble could be with that switch or possibly the taillight relay in the fuse panel. The trouble could also be a fuse. Many folks mistake a bad fuse for a good one on the first go around.
Old 10-22-2010, 10:01 AM   #5
SubieWReX
Member#: 151080
07 BME AutoX WRX
I swapped the fuse with another identical one in the fuse box(rear wiper/defroster) just to check. No luck...
I meant the parking lights, I'm sorry. That switch works.
Do you think it has anything to do with the different seats and not having that wiring harness fully plugged in yet? I do have an airbag light on right now...
Old 10-22-2010, 11:43 AM   #6
Cougar4
Member#: 53443
Winestone
I'm not sure if the seat change would cause the airbag light to turn on or not. It is possible though I would think. It won't have anything to do with the rear lights though. You need to make sure the switch on top of the steering column is passing power from the light switch when it is turned on. That switch makes a connection even though it is OFF. You also need to make sure the taillight relay is working ok and you will need a test light probe at least to check those connections out. If you don't have a factory service manual for the wiring I suggest you purchase one or download the info from Subaru's website for a small amount. You can also get service info on Ebay.
Old 10-22-2010, 11:50 AM   #7
SubieWReX
Member#: 151080
07 BME AutoX WRX
Thanks for your help so far. Where is the tail light relay located?
Old 10-22-2010, 12:42 PM   #8
Cougar4
Member#: 53443
Winestone
I think it is in the dash fuse panel.
Old 12-25-2010, 01:58 AM   #9
WarTowels
Member#: 185653
2002 WRX Sedan
Rally Blue
I had a similar problem tonight. As the local police officer pointed out to me.
My rear brake lights are not working, unless pressed. I don't think my running lights via the switch are doing anything either.
But here's where I think things got fouled up:
It's 23 degrees outside, and I put my e-brake up while I was at church for an hour. After getting back into my car, my e-brake was entirely frozen. And regrettably, I had to break it free by driving. Not the first time this has happened. =(
BUT, even though the e-brake light is off- I'm wondering if the fact that the brakes are stuck is causing my issue. I noticed on my 2002 WRX that the brake lights go OFF if I engage my e-brake. Even while driving.
Food for thought,
-Towels
WarTowels is offline   Reply With Quote
Old 12-25-2010, 04:13 AM   #10
Cougar4
Member#: 53443
Winestone
I don't think that the brake lights should turn off using the E-brake. The fuses need to be checked for the running light trouble.
Old 12-25-2010, 01:57 PM   #11
WarTowels
Member#: 185653
2002 WRX Sedan
Rally Blue
No, they probably shouldn't. But mine seem to.
-Towels
Old 12-26-2010, 07:06 PM   #12
WarTowels
Member#: 185653
2002 WRX Sedan
Rally Blue
I foolishly left a connected unplugged when I installed my turbo timer.
All is well again.
-Towels
Old 12-27-2010, 12:45 AM   #13
SubieWReX
Member#: 151080
07 BME AutoX WRX
Mine are working now. It had something to do with the courtesy lights button on top of the steering column. It got pressed between on/off.
Old 12-27-2010, 02:46 AM   #14
Cougar4
Member#: 53443
Winestone
The normal power to the lights runs through the switch contacts in the OFF position. When the switch is ON power bypasses the tail light relay.
Old 09-22-2018, 06:20 PM   #15
Zshiesubie
Member#: 491751
Iím having the same issue now with my 03 impreza I just bought. PO has wired tail lights and tag lights to an accessory charger via the cigarette lighter plug. The lights work as long as I remember to plug that in but Iíd like to get the car back in proper operating order and Iím not sure where to start with all this. My dash lights and front marker lights do not work with the headlight switch or parking light button on top of the column. I have a multimeter and Iím hoping someone can tell me where to start testing to figure out what is going on here
Zshiesubie is offline   Reply With Quote
Old 09-26-2018, 04:03 AM   #16
Cougar4
Member#: 53443
Winestone
The best thing you need to do next is to purchase a factory service manual for the car. Ebay is a good place to get a CD copy if you don't want a real manual. It will help you immensely with this problem since it seems mods have been done to the car. Start the checks by checking the fused power to the circuits and making sure that power is at least getting to the switch.
No Tail Lights, Parking Lights, or Instr. Panel Lights! HBK Electrical & Lighting 7 12-01-2012 05:17 PM
Tail lights/Parking lights not working toutanje Electrical & Lighting 8 10-13-2008 06:28 AM
Dash and now tail/license/parking light Disorder scotto Electrical & Lighting 6 08-30-2007 01:40 PM
tail lights and front position lights not working 1993 Legacy Electrical & Lighting 1 12-15-2004 06:01 AM
brake light on. . drl's not working x12oyx316x Electrical & Lighting 4 07-17-2004 03:11 AM
