Welcome to the North American Subaru Impreza Owners Club Friday January 24, 2020
Old 02-09-2007, 06:12 PM   #51
AREITU
Member#: 12234
1991 318is
I think in the next few years, people will begin to realize the benefits of tuning with variable valve timing systems. EMS technology should eventually catch up, too. Power Enterprise even makes a CamCon device for VVTI.
Originally Posted by grippgoat View Post
VTEC doesn't run two sets of actual camshafts, but that's silly. I'm sure it's not literally what he meant.
For a pair of valves, the camshafts have a separate 3rd lobe between the two lobes that are normally there, and when VTEC activates, it does something funky I never quite understood to start making both valves follow the more agressive center lobe.
So while AVCS can change overlap and cam timing, VTEC can actually change lift and duration. Although I think some newer honda engines actually do both. They have variable cam timing like AVCS as well as the 2nd set of cam lobes that can be activated.
-Mike
There's about half a dozen versions of VTEC. SOHC and DOHC versions, and variations of both. All SOHC VTEC systems work only on the intake side. Basically, each intake cam lobe is staggered, one slightly smaller than the other, to promote swirl. Above a certain RPM, the VTEC solenoid pushes a pin through the rockers, which forces both valves to follow the larger lobe.
In DOHC VTEC, (Prelude, Integra GSR, S2000, Si, RSX-S etc) there is a 3rd lobe (high lift and duration) between the normal lobes, as if each cylinder had 3 valves. Below each lobe is a rocker, but the one under the high lift lobe floats freely before VTEC engagement, and the rockers follow the low-lift lobes. When VTEC engages, it opens a solenoid that pushes a a pin through all three rockers, forcing the valves to open with the biggest lobe: The high lift lobe.
here's an old article. http://asia.vtec.net/spfeature/vtecimpl/vtec1.html
And a picture: http://www.accordforum.de/images/vte...m/vtec_cam.gif
i-VTEC is simply cam phasing (Like AVCS) on top of VTEC.
With that OT stuff out of the way...
Is AVCS two-step, or is it infinitely variable within a given range?
AREITU is offline   Reply With Quote
Old 04-14-2009, 01:40 AM   #52
B-Kerr
Member#: 14841
2002 Impreza WRX
WRB, VF22, Cusco, Unichip
I have a pretty good understanding of both the AVCS and the Vtec in Hondas... however, the question I have is this: is the AVCS an instantaneous actuation (solenoid kicks at an rpm), or is it more gradual? The reason I ask is this... if a person were to put an AVCS engine into a WRX with a non-avcs computer, could you actuate the avsc with an rpm dependent switch much like a Vtec controller? I hear idle can be a real problem with an avsc engine in a non-avsc car...
B-Kerr is offline   Reply With Quote
Old 04-14-2009, 02:06 AM   #53
STIBungy
Member#: 51684
No, there's an engine load vs rpm table for how much timing advance to give the AVCS.
STIBungy is offline   Reply With Quote
Old 04-14-2009, 02:26 AM   #54
Godspeed55
Member#: 186553
The link doesn't work for me . Am i the only one having this problem?
Godspeed55 is offline   Reply With Quote
Old 04-14-2009, 09:02 AM   #55
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
01 Legacy 95 Impreza L
Try this: http://www.drive.subaru.com/Win05_WhatsInside.htm
Seems they put an extra dot in at some point.
mccanixx is offline   Reply With Quote
Old 04-14-2009, 11:04 AM   #56
B-Kerr
Member#: 14841
2002 Impreza WRX
Ok... how about this... I know the advance is load specific, but we want the capability for sure. The issue is low end drivability. Why couldn't we just switch it at say 3k. It may not be as precise as the computer/load controlled switch, but it would give the basic desired results... low end grunt and open end breathing with no idle issues...
Any thoughts?????
BTW... the top length wasn't working for me either Godspeed....
Old 04-14-2009, 11:16 AM   #57
sense of nature
Member#: 112759
2004 Stock OEM AsFu*
FoZZY SexyRP
I've pondered this thought too , If it is possible to connect a micro switch to the throttle to activate the solenoids ?
Ideas anyone ?
sense of nature is offline   Reply With Quote
Old 04-15-2009, 09:56 AM   #58
B-Kerr
Member#: 14841
2002 Impreza WRX
It appears to be a 2-wire solenoid, much like the vtec solenoid. Seems a switch, like a vtec controller, with a rpm input/trigger would be just the thing...
Old 09-25-2009, 06:37 PM   #59
Smdavis27
Member#: 219455
2009 WRX Sedan
Satin White Pearl
Here, I am still a Toyota Celica GT-S owner and there is a wealth of information on how these systems function at Newcelica.org
http://www.newcelica.org/forums/show...1&referrerid=0
How Lift works (Toyota's approach toward this)
Smdavis27 is offline   Reply With Quote
Old 11-01-2010, 10:19 PM   #60
Thongpocket
Member#: 248749
2013 BRZ Limted
Dark Grey Metallic
that link is broken
Thongpocket is offline   Reply With Quote
Old 11-01-2010, 11:23 PM   #61
BigRigger
Member#: 129969
2005 Sti
Silver/Black
no kidding, this thread is almost 6 years old
BigRigger is offline   Reply With Quote
Old 11-02-2010, 09:47 AM   #62
ADR 04STi
Member#: 51918
2015 Audi S3
Daytona Gray
Looks like I posted on this wayyy back in 1/05.
ADR 04STi is offline   Reply With Quote
Old 11-02-2010, 10:13 AM   #63
Thongpocket
Member#: 248749
2013 BRZ Limted
Dark Grey Metallic
GOOD NEWS! It's a thread and people still read it so......fix or delete, eh?
Old 11-02-2010, 10:56 AM   #64
Bizko1288
Member#: 151260
2011 BMW 135i
__________
The link in post #55 works for me. Very good article. I .pdf ed it. If anyone wants an email just shoot me a pm.
Bizko1288 is offline   Reply With Quote
Old 11-02-2010, 11:09 AM   #65
prometheum
Member#: 92003
04 bicycle!
that's not really the same thing, vvti is closer to avcs
prometheum is offline   Reply With Quote
Old 05-10-2011, 05:01 PM   #66
raggedoutsti
Member#: 255714
2005 STi
psm
i really wish i could read this article, any one have an alternative? or no where to find it?!
raggedoutsti is offline   Reply With Quote
Old 05-10-2011, 06:42 PM   #67
Freon
Member#: 88322
2009 BMW 135i
AVCS allows continuously variable (not stepped, and not just one or two positions) changes of camshaft timing. Single AVCS is intake cam only, dual AVCS is both intake and exhaust cam. Many car companies have the ability to control cam timing in this way (pretty sure Nissan, Hyundai, and Ford do this on their 4 bangers). Subaru's implementation uses engine oil pressure driven into the cam sprocket to change the angle of the camshaft in relation to the teeth on the sprocket and timing belt. The engine oil flows through a PWM-driven solenoid with closed loop ECU control to ensure a specific requested camshaft angle is maintained during operation. I believe older implementations allow up to 30 degrees of camshaft advance (15 crank degrees), and newer ones may do up to 40/20. Not positive on that.
From there, all you need is just a good book on engine operation to understand what cam shaft timing is and its effects on engine operation, but here is a quick version:
"Optimal camshaft timing" is difference under different RPM and loads. Camshaft timing will affect volumetric efficiency, and/or better emissions, and/or fuel economy. If you do not have this camshaft control, camshaft timing is a tradeoff. Camshaft timing may allow good torque and acceptable emissions, but poor top end power. With a dynamic camshaft, you can get both.
There are still other camshaft elements that AVCS lacks in comparison to some competitors' systems. There is no control over the profile of the cam, so no changes in lift or duration are possible. Duration, lift, and shape are still tradeoffs, and it would be preferred (cost and reliability issues set aside) to also be able to control these if you are seeking optimal power, efficiency, emissions, etc.
Freon is offline   Reply With Quote
Old 05-11-2011, 12:47 AM   #68
raggedoutsti
Member#: 255714
2005 STi
psm
What can my avcs system do for me? Is it dificult for a tuner to tune the avcs, I don't hear about it often
Old 02-05-2013, 10:05 PM   #69
meebs
Member#: 3251
2009 WRX Hatch
meebs is offline   Reply With Quote
Old 12-22-2015, 01:35 AM   #70
bov300zx
Member#: 282553
Default Updated link?
Does anyone have an updated link to the AVCS article? I tried each link in the thread but they all come up broken.
bov300zx is offline   Reply With Quote
Old 12-23-2015, 01:37 PM   #71
Ron_Burgundy
Member#: 275443
2011 WRX
Obsidian Black Pearl
Ron_Burgundy is offline   Reply With Quote
Old 04-21-2017, 09:08 AM   #72
grex07
Member#: 167116
2013 STi 5Dr
All the links are broken again.
grex07 is offline   Reply With Quote
Old 04-23-2017, 11:50 AM   #73
Evilwalker93
Member#: 466490
Great find good sir!
Evilwalker93 is offline   Reply With Quote
Old 04-23-2017, 03:23 PM   #74
HumanBoost
Member#: 440291
. I can also confirm ALL AVCS explanation links are broken and do not work.
HumanBoost is offline   Reply With Quote
Old 11-05-2019, 11:45 AM   #75
Titanicflea
Member#: 508066
2006 Forester
Champagne
Thank you!
Titanicflea is offline   Reply With Quote
AVCS Help deftonez99 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 06-03-2010 03:38 PM
Directions how to install AVCS heads in a non AVCS car and not use AVCS sgiord86 Built Motor Discussion 1 11-19-2009 05:31 PM
FS:NY Apexi AVC-R, low milage, great condition singincanary Engine/Power/Exhaust 18 02-08-2007 04:25 AM
Apex-i AVC-R & S-AFC Great Condition! TheWRXMan Private 'For Sale' Classifieds 4 02-11-2004 12:55 AM
Great deals on AVC-R DragOnWRX Private 'For Sale' Classifieds 8 07-30-2003 08:19 AM
