Welcome to the North American Subaru Impreza Owners Club Monday February 10, 2025
Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 09-29-2009, 10:43 PM   #1251
Leonardo
Cowabunga!
Super Moderator
Member#: 185
2014 Impreza Sport
Ice Silver Metalic
Thanks!
Thinking of getting a 07 wrx wagon and build it up for next season.
Leonardo is offline   Reply With Quote
Old 09-30-2009, 12:15 AM   #1252
CamaroFS34
Member#: 6850
1996 Camaro Z28 1LE,
'23 WRX & '19 XV
Originally Posted by Blaze-65 View Post
I'm still working on my ESP wrx, I had some problems at the last event due to a clutch starting to slip. So my big question now is .... can someone recommend a pretty good clutch to go with? I'm on stock engine power right now, I do plan to add a COBB AP in the very near future. So what will handle the autox and daily driver duty? I don't mind a stiffer clutch, I bought the car with a stiffer one to begin with.
I am currently using the heavy-duty ACT clutch with a streetlite flywheel. Definitely heavier than stock, but I do like the lightened flywheel. I have the Cobb AP, as well as other ESP-legal power stuff.
Karen
CamaroFS34 is offline   Reply With Quote
Old 09-30-2009, 12:42 AM   #1253
Blaze-65
Member#: 190655
2004 Impreza WRX
I'm reading through the FAQ right now, but i bumped this thread up because I felt like I could get a more motorsport perspective on it. I didn't even think of changing the flywheel until your comment ... hmm I will be right there so I guess why not.
mccanixx has a thread on his ESP build ... it's suprising to see him using the stock setup
Originally Posted by mccanixx View Post
Trans:
2002 wrx Transmission rebuilt w/used gears...... I do live dangerously
MFactory Helical front diff
Cusco 1.5 rs rear
Stock clutch PP and Flywheel
Blaze-65 is offline   Reply With Quote
Old 09-30-2009, 03:43 AM   #1254
makofoto
Member#: 25243
2006 Legacy Outback
The stock STI clutch is good .. get the Excedy (? spelling) one ... same as the more expensive STI labeled version.
makofoto is offline   Reply With Quote
Old 09-30-2009, 08:32 AM   #1255
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
01 Legacy 95 Impreza L
HP levels on a esp wrx aren't tremendous. Factory clutch is quite good. Although I wouldn't mind a street act or something it's was an unecassary $600.00 that could go elsewhere. The feel is better. I do like the way Karen's engages. It's easy for me to stall
As I said in my thread, a stiffer clutch set up is only going to increase load on the gear sets. IMO.
I've had no issues with slippage or 60's so why spend the money. I'll change it in the spring, it's 4 years old, and I bet what goes in is stock.
I guess if you have the cash get a street style package, just over stock. But, it's in no way necassary for a dd esp car.
Greg
mccanixx is offline   Reply With Quote
Old 09-30-2009, 10:16 AM   #1256
Blaze-65
Member#: 190655
2004 Impreza WRX
Yeah I noticed exedy had a stock unit around 250 i believe ... that may be the way to go. I honestly don't have the spare cash, although I could save and get the street style package. I may just spend the saved money on a flywheel. I'm used to my clutch already, but I am curious to know what I have in the car already. It's definitely above stock and a bit stiffer ... I've had several WRX owners sit in my car and try the clutch out.
oh yeah this is my car now
Old 09-30-2009, 10:26 AM   #1257
Mechie3
Member#: 120152
How much benefit do you feel from a lightweight flywheel? My engine is out of the car now (it blew up....again) and the flywheel is all blue and has a fair number of surface cracks. Guess that's the cost of letting the wifey autocross the car when she's still learning to drive stick and launching the hell out of it.
Mechie3 is offline   Reply With Quote
Old 09-30-2009, 12:40 PM   #1258
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
I tend to think a LWF would negatively effect my launches.
Old 09-30-2009, 01:49 PM   #1259
bcblues
Member#: 17256
18 Outback
on the road....
It does require a bit of finesse, but then again, so does babying a stock clutch. Most folks end up putting on a LWF along with power-adding mods, so the launch factor does not change all that much....
bcblues is offline   Reply With Quote
Old 09-30-2009, 04:05 PM   #1260
Mechie3
Member#: 120152
Since I don't do a lot (err...any as of late) pro solo's that don't have a hard launch into a straight, do you think the LW FW's benefits over the rest of the course outweigh a potentially worse launch?
Old 09-30-2009, 04:14 PM   #1261
sureshot007
Member#: 142405
#716 Group5 S10
You blew your engine AGAIN?! Jeez, that's more than me
I have a 12 lb flywheel and I think it makes a ton of difference. I love it. Launch issues were quickly corrected by adding launch control to the ecu.
sureshot007 is offline   Reply With Quote
Old 09-30-2009, 05:08 PM   #1262
angryfist
Member#: 22760
#54 STR S2000
crazymonkeyracing
theres no need to baby a stock clutch. its got enough clamp load for ESP power levels.
angryfist is offline   Reply With Quote
Old 09-30-2009, 05:19 PM   #1263
Mechie3
Member#: 120152
yeah. The last one was one I built myself. Lasted 2k miles, a subaru challenge, and an autocross. I think some silicone got in a passage after a while. For the next one I bought an OEM shortblock from Subaru.
I'm looking at a 15lbs flywheel.
Old 10-01-2009, 12:31 AM   #1264
CamaroFS34
Member#: 6850
'23 WRX & '19 XV
You seemed to launch mine okay.
Old 10-01-2009, 08:21 AM   #1265
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
Ya, but you didn't see me stall it at nationals pulling onto some boards so we could jack it up.
It was a fail and Hilary laughed heartily!
Old 10-01-2009, 02:49 PM   #1266
CamaroFS34
Member#: 6850
'23 WRX & '19 XV
<shrug> Gabe and Pat stall it regularly too. Me, not so much, but I drive it more than anyone else.
Old 10-02-2009, 12:06 AM   #1267
hilary0110
Member#: 217964
1989 STS CRX Si
Calico
I did laugh and still do!
McCance that ass hat switchbladed himself!
hilary0110 is offline   Reply With Quote
Old 10-15-2009, 11:25 AM   #1268
thewerxracing
Member#: 141498
Okie Dokie. I need everyone's help.
I'm selling my Autocross toy because I am sick of it. My E-Stock Prepped Porsche 944 is going away and I am going to move my daily driver into autocross duties. It's job as a DD will be taken over by a 2010 Impreza Hatch.
What else would be needed (Tires/Sways/Saftey/etc) to make my DD into an ESP contender?
So far:
2002 WRX Sedan
The path the air takes:
Injen Cold Air
Perrin Inlet
Stock TD04
STi & Samco "Y-Pipe"
TurboXS Top Mount w/Spray
STi Manifold
Stock Internals
Stock Exhaust Manifold
GrimmSpeed Up-Pipe
TiAL 38mm External WG
COBB Heatsheild with Blanket
HKS Downpipe w/Wrap
APEXi from the DP-out.
Suspension:
KYB GR2 Struts
Tanabe GF-210 Springs
Undercar H-Brace
Perrin Lockdown Kit
Brakes:
Hawk HPS Pads
Brembo Blank Rotors
Drivetrain:
SPEC #2 Clutch
SPEC Streetlight Flywheel
Kartboy Short Throw w/Bushings
So, I'm headed towards ESP. How's my list look?:
Brakes:
Braided Lines
Race Fluid
Suspension:
Coilovers
Rear Sway Bar
Tires:
Hoosier A6's
Interior/Saftey:
Recaro Pole Positon (2)
Recaro 5-Point Harness (2)
AutoPower Bolt-in Race Cage
Fire Suppression
Battery Disconnect
What else does this thing need?
Oh, yeah. I'm aiming for a Camaro SS.
thewerxracing is offline   Reply With Quote
Old 10-15-2009, 11:28 AM   #1269
sureshot007
Member#: 142405
#716 Group5 S10
Are you only autox'ing it? If so, why bother with fire supression and roll cage?
Oh yeah, and if you want to do it right, just do everything mccance did.
Old 10-15-2009, 11:41 AM   #1270
thewerxracing
Member#: 141498
Well, I like hillclimbing, too. Who is this mccance you speak of?
Old 10-15-2009, 01:12 PM   #1271
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
OMGHi2U
I'm pretty sure you won't be able to do the external wastegate.
Here's a thread ESP Project I haven't updated it lately. Mainly cause I've been lazy, and it got a bit cluttered at the end. I'll get back into it as I switch to E85 and make a concerted effort at tuning the chassis.
Looks like you're off to a good start.
Cheers
McCance
Old 10-15-2009, 01:15 PM   #1272
Mechie3
Member#: 120152
H brace and EWG have to go to be ESP legal. Water spray isn't legal either.
Didn't mention if any of your manifolds were PnP'd. Also recommend TGV deletes.
Old 10-15-2009, 01:15 PM   #1273
hilary0110
Member#: 217964
1989 STS CRX Si
Calico
Really?
Old 10-15-2009, 01:20 PM   #1274
thewerxracing
Member#: 141498
Originally Posted by hilary0110 View Post
Really?
Really to.....? What Hillclimbing? Mccance? What are you talking about?
Old 10-15-2009, 01:24 PM   #1275
thewerxracing
Member#: 141498
Cheers
McCance
Thank you! Off to a good start is just what I wanted to hear. I have a winter to do this project so things are looking good. The Wastegate can go, thats not a problem. I'm sure Ill have plenty of questions for you....
The water spray and H-brace can get junked. No big loss on either of those two. What kind of bracing can we do then?
The Mani's are neither polished nor ported. I may do TGVs to get the spool time lower....
As for suspension, junk the KYBs, right?
ESP-The 2002 WRX Project Butt Dyno NASIOC Project Cars 803 05-08-2022 08:15 PM
The Competition (strictly by the numbers) R Diamond STi Forum Archive 9 05-22-2003 05:16 PM
The Competition is Worried..G Stock is worried Scooby South Motorsports 10 02-23-2001 05:41 PM
Weapon R Intakes vs. the competition Matthew Nelson General Forum Archive 3 08-31-2000 01:19 AM
0-50 vs the competition bryanw General Forum Archive 11 08-11-2000 09:15 PM
