#176 |
Member#: 140315
#177 |
Member#: 83567
Vehicle:08 Outback Obsidian Black Pearl |
![]() This is a great thread....I didn't realize the OEM radio brackets are used with an aftermarket HU.
I know this is sort of the wrong thread, I have an 02' WRX with a factory sub (Not sure if the 04+ wiring harnesses are different but it looks the same). I pretty much think I have this all down right but want someone to verify something for me. Ya know how the factory 14 pin plug goes into the back of the oem HU? Well down from there is another white plug connection (looks to be 14 pin). There are some other wires spliced in by that 2nd plug connection as well as the oem sub wires. I have a 14 pin Subaru wiring harness that I bought and it that plugs into that first plug, the one that goes into the HU...........do I just need to splice that Subaru wiring harness into the Alpine harness and be done? I read some other oem sub wiring threads and got a little confused. Thanks!! Last edited by Farnsrocket; 02-15-2007 at 08:19 PM. |
#178 |
Member#: 83567
![]() Ok, I just installed my Alpine 9857 and there is no sound coming from the speakers at all.......no static or anything. The HU powers on and a Cd even plays but no sound.
#179 | ||
Member#: 25837
South East
Vehicle:1996 SVX L AWD Laguna Blue Pearl |
![]() (continuing the thread hijack)
Here's what you had behind the factory radio:
Stock head unit information -- pin-outs, subwoofer, aux inputs, and more Quote:
I'd pull your harnesses back out and double check your connections. While you're doing that you might as well try temporarily connecting the factory radio to see if everything still works. No need to slide it back into the dash, just plug in the 14-pin plug and antenna. Next try bypassing the factory subwoofer and connect your Alpine to the car's wiring harness. Are you sure the Alpine was good before you installed it? Did you try all of the inputs (AM, FM, CD, Aux)? Make sure the Alpine's internal amps have not been disabled (on the model CDA-9856, the menu option should say "POWER IC ON"). You only want this "off" when you've connected your speakers to an external amp. See the Alpine's manual for details. |
#180 | |
Member#: 83567
![]() Quote:
![]() Sorry for the thread jack! ![]() Last edited by Farnsrocket; 02-16-2007 at 05:28 PM. |
#181 |
Member#: 123889
SCIC
![]() thanks for the write up!!
#182 |
Member#: 71903
Vehicle:11 Audi A4 6MTQ 13 Mazda CX-5 |
![]() I read through the thread, and i think i know the answer but... i have an 07 WRX TR (with the single din and the pocket underneath). can i reuse that pocket when i install my HU? I assume that I can; I just haven't taken the car apart yet and I want to get my supplies before I do.
#183 |
Member#: 99289
![]() Yes..
#184 |
Member#: 136725
NWIC
Vehicle:2006 Impreza 2.5i Crystal Grey Metallic |
![]() Thanks for doing that thread, it helps out a lot. I'm just curious about one thing. I am replacing my stock 2006 2.5i HU with and 05 sti HU. Will I have to do any of that electrical wiring stuff, or can I just plug in the 05 HU where the old one was?
#185 |
Member#: 99289
![]() plug and play. This is covered in the FAQ at the top of this Sub forum.
#186 |
Member#: 140825
Vehicle:2011 STi SWP |
![]() idk if this was said yet but just wanted to put my two cents in and say that one thing that will help with stopping people from stealing your head unit will be to replace the philips head screws that hold the unit in with torx screws. Cheap replacement that helps, just FYI
#187 |
Member#: 83567
![]() ^^^ Good idear!!!
#188 |
Member#: 144744
International
Vehicle:2007 Impreza 2.0R White |
![]() Thanks,
This is my first post here, and If I haven't seen this great thread, it might have cost me a fortune. I just have trouble with the antenna, I cant pull it from the stock deck?? is there a particular way to remove it. I don't wanna spoil the connector (I have a impreza MY07) with the single din cd player. |
#189 |
Member#: 139699
Vehicle:2011 WRX STi Limited OBP |
![]() that looks a little too easy doesnt it? maybe i just suck... nice instructions!
#190 | |
Member#: 25837
South East
![]() Quote:
Perhaps it's a little tight, but it should just slide out. Grab by the plug, not the wire. |
#191 |
Member#: 83567
![]() Yeah, just pull that bastard out!
#192 |
Member#: 144744
International
![]() Yeah it is that. I'm just waiting for my DVD player then I'll just use a plier and pull it out. If it breaks I'll just have to use my soldering skills
#193 |
Member#: 45400
RMIC
Vehicle:06 WRX TR OBP |
#194 |
Member#: 151347
![]() does anyone here have a 2007 impreza 6 disc mp3 changer and possibly the stock subwoofer that you would want to sell?
please contact me if you do or if you know of a good place to get one that isnt the dealer and isnt ebay....looking for cheap used Last edited by mshanek30; 06-13-2007 at 03:00 PM. |
#195 |
Member#: 99289
#196 |
Member#: 151347
![]() Thanks....very helpful!
#197 |
Member#: 151347
![]() does somebody know if i have a stock basic cd player in my 07 impreza 2.5i if i can swap it out with a stock cd changer? i feel like it should be straight forward (especially with this AWESOME with picture how to guide).
does anyone know if the cd changer has a more powerful amp in it than the single disc player? |
#198 |
Member#: 99289
![]() Plug and play. And not likely.
#199 |
Member#: 151347
![]() thanks
#200 |
Member#: 131390
Vehicle:2010 5 Door Spark Silver |
![]() great write up... def made putting my 7019 in a lot easier knowing where all the screws and clips were.
How to install 2007 AUX Input on 2006 WRX? | GooseMan | Car Audio, Video & Security | 5 | 08-15-2011 06:27 PM |
How-to install a stereo in a 1993 Impreza L | rizwan | Car Audio, Video & Security | 5 | 12-05-2009 03:26 PM |
How to install A system in your 06 Impreza | Harley Sporty | Car Audio, Video & Security | 57 | 02-12-2009 10:47 PM |
How to install new pedals on a 2006 STI | Jag32 | Interior & Exterior Modification | 4 | 06-30-2006 02:24 PM |
How to install aftermarket stereo in '02 WRX | joeroket | Car Audio, Video & Security | 4 | 04-28-2005 08:28 PM |
