Old 03-26-2013, 12:43 PM   #1
TravTagz
Member#: 326310
2012 WRX Premium
Default Protect Transmission
I wanted to know if replacing the clutch and flywheel would help protect the transmission and much higher cost to replace. I will soon be at 330+wtq and was wanted to know the best way to strengthen the transmission. I have a heavy foot on a daily basis and plan to drag the car a few times a year. Also plan on installing new engine, transmission, and pitch stop mounts...will this make any difference as far as protection?
TravTagz is offline   Reply With Quote
Old 03-26-2013, 12:47 PM   #2
HinshawWRX
Medium Frank
Member#: 140114
2020 Subaru
Outback
Your clutch and flywheel are how the motor connects to the transmission without slipping. Your transmission can still be damaged. The mounts for engine, trans, and pitch make no difference.
Why are you worried about "protecting" it? And by protect I assume you mean not shattering gears...
Old 03-26-2013, 12:49 PM   #3
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
A lighter flywheel will help a little, but a stronger clutch will make the stress worse.
Old 03-26-2013, 12:49 PM   #4
Dmochowski
Member#: 306478
2016 Focus RS
stock
Probably make it easier to strip a gear...
If you think about it this way a stronger pressure plate will grab harder and if you drag launch your car and you get all the power put down to the wheels where it would otherwise slip more, than that is gonna be a higher chance to strip first gear. You would just have to learn again how to slip your clutch the right amount and not damage anything.
Also stiffer mounts will transmit more force through the body of the car
Dmochowski is offline   Reply With Quote
Old 03-26-2013, 12:52 PM   #5
TravTagz
Member#: 326310
2012 WRX Premium
I am worried about the increased whp + wtq that I will be placing on the wrx transmission and am concerned about how much it will be able to withstand.
Old 03-26-2013, 01:01 PM   #6
Dmochowski
Member#: 306478
2016 Focus RS
stock
Its all in how you drive it. Give me ten minutes and I could trash an Sti trans
Old 03-26-2013, 01:19 PM   #7
Jack
Add Lightness
Member#: 13699
2021 Building
It Better
Less than what you plan.
Look into trade in values towards an STi or costs to install an STi 6 speed.
Old 03-26-2013, 04:32 PM   #8
HinshawWRX
Medium Frank
Member#: 140114
2020 Subaru
Outback
Let me guess, you read one thread and now you think your trans won't hold any power at all over stock.
Old 03-26-2013, 04:41 PM   #9
Jack
Add Lightness
Member#: 13699
2021 Building
It Better
330+ wtq and drag a couple times a year?
I would be worried. (then again, I did one drag day 5 years ago for the first time since 1976 and blew a clutch on a mis-shift)
Old 03-26-2013, 04:46 PM   #10
TravTagz
Member#: 326310
2012 WRX Premium
Yes I'm worried that the 100+whp/100+wtq increase over stock will increase my chances of shattering gears
Old 03-26-2013, 04:46 PM   #11
vision.dynamix
Member#: 139955
2015 Subaru STI
17Forester / 18Crosstrek
All those blown gearboxes, none of them are driver errors.
Old 03-26-2013, 04:52 PM   #12
HinshawWRX
Medium Frank
Member#: 140114
2020 Subaru
Outback
Then learn to drive or start saving to swap in a 6 speed or stronger 5 speed gears.
But if you are DDing the car you should be fine.
Old 03-26-2013, 05:11 PM   #13
TravTagz
Member#: 326310
2012 WRX Premium
I've got a heavy foot and like to launch the car so engine rebuild fund just became transmission fund
Old 03-26-2013, 05:23 PM   #14
Member#: 51961
2005 STi
2012 WRX
Better add in a rear diff fund and axle fund too.
Honestly, it sounds like you bought the wrong car. If your goal is to go out clutch dumping at 330+ whp, you should have bought an STi in the first place. That's the reason the thousands of WRX vs STi threads exist on this forum, to give people an idea of when and why they should buy an STi instead of a WRX. This is one of those cases.
You may be better off cutting your losses now and trading up. The tranny is stronger, the clutch is stronger, the diff is stronger, etc. It already comes with all of the parts you're about to replace on your car, and you get them without flushing your resale value down the toilet.
Old 03-26-2013, 05:25 PM   #15
TravTagz
Member#: 326310
2012 WRX Premium
You bought the wrong car if your goal is to go out clutch dumping at 330+ whp.
By transmission fund I mean full STi 6spd swap
Old 03-26-2013, 05:33 PM   #16
Member#: 51961
2005 STi
2012 WRX
Or you could spend about the same amount of money by trading your car in for an STi, get all of the same goodies pre-installed with a warranty, and have your resale value go up instead of down.
Old 03-26-2013, 05:42 PM   #17
TravTagz
Member#: 326310
2012 WRX Premium
6-8k increase in price plus would need to remove a few things to go back to stock and would have to order the car and wait 8 weeks
Old 03-26-2013, 10:31 PM   #18
Member#: 51961
2005 STi
2012 WRX
Doing a full 6 spd swap plus brakes plus DCCD controller plus clutch is going to cost about the same, plus installation.
Most or all of which could be installed on the STi once you got it
Unless you can find one on the lot or buy used.
I think you fail to understand what an absolutely horrible idea it is to do something this extreme to such a new car, when you can spend pretty much the exact same amount of money to get a car that already has all of it pre-installed with a warranty.
Think about it this way...if you do this, your car will become almost unsellable. It's resale value is going to drop at LEAST $5k, that's on top of the $6k+ that you put into it to do the swap, which means you're now ~$11k worse off than before. If the car gets stolen or gets totaled, all of the money you invested is gone. Alternatively, if you trade up to an STi, all of the money you put into that trade becomes equity that you will reclaim (at least some of it) when you sell or if it gets stolen/totaled.
It's the same reason why when people post about turboing their N/A impreza, we tell them to sell it and buy a WRX.
Old 03-27-2013, 04:00 AM   #19
TravTagz
Member#: 326310
2012 WRX Premium
I guess ultimately the best alternative is to change the way I drive seeing how it would be a pain for me to pay for the swap or trade up :-( damn my need for speed and low budget lol
Old 03-27-2013, 06:13 AM   #20
Dmochowski
Member#: 306478
2016 Focus RS
stock
you have a 2012 at least its not an 02. From what i hear the new wrx's hold up better. If buying an STI isnt an option just dont worry about it and drive carefully at the dragstrip.
Old 03-27-2013, 06:26 AM   #21
HinshawWRX
Medium Frank
Member#: 140114
2020 Subaru
Outback
Drive like an adult and not like you just watched 2 Fast 2 Furious and you'll be fine. If you're not having issues with the trans currently then you are making yourself a worry wort for no reason.
Old 03-27-2013, 10:29 AM   #22
Unabomber
Big Ron
Super Moderator
Member#: 18062
on car parts so PM
me b4 j00 buy
Old 03-27-2013, 11:01 AM   #23
TravTagz
Member#: 326310
2012 WRX Premium
Interesting
Old 03-27-2013, 01:53 PM   #24
TravTagz
Member#: 326310
2012 WRX Premium
Like this?
