Welcome to the North American Subaru Impreza Owners Club Saturday February 24, 2018
Old 05-18-2017, 12:25 PM   #776
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg 2+ 310/370, 6sp R180
Originally Posted by husak View Post
Worked with Emil, can't get it working (tried his new beta version too). Nothing in the logs say it doesn't work so we don't have anything to go on. Im using Malysk (sp) firmware so I'm going to try stock firmware before giving up.
What does everyone else do for internet connection on the headunit? I want something where I can just plug USB and go. Wifi hotspot isn't fast enough to stream music so I end up playing it from my phone on bluetooth.
I have a different unit (Xtrons TB706APL, PX5 unit)
i use my phone's wifi hotspot to run my unit. can stream music and run google maps (not offline), and even stream youtube videos. iphone 6s on T-mobile ONE-plus plan.
who is your cell carrier? do they limit your mobile hotspot speeds? I get full LTE speeds via hotspot for my first 10GB (3G speeds after, unlimited data amount).
I'm not sure any of these units support USB tethering.
gsrcrxsi is offline   Reply With Quote
Old 05-18-2017, 12:51 PM   #777
husak
Member#: 443909
2016 WRX
Yeah the plan supports hotspot tethering (same thing, 'full speed' until 10gb), but it runs like garbage. 5m to DL 3mb. I figure that's probably what I should be troubleshooting now that you mention it.
husak is offline   Reply With Quote
Old 05-18-2017, 01:00 PM   #778
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Default Android Headunit 10.2'' Screen
Are you trying to run wifi and BT at the same time? The antennas on these things are pretty bogus. I can't run both at the same time. If I hookup BT while the wifi hotspot is running it really slows down the internet speeds.
Wifi and BT are on the same 2.4GHz frequency and they interfere with each other.
Old 05-18-2017, 02:13 PM   #779
husak
Member#: 443909
2016 WRX
might be onto something! I do have both running, but don't really need it if wifi works well. I can also set wifi to 5ghz just to see.
Old 05-18-2017, 02:31 PM   #780
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
I doubt the headunit supports 5GHz. Can you actually set that? I don't have any band selections in my settings menu
Old 05-18-2017, 02:47 PM   #781
husak
Member#: 443909
2016 WRX
oh true. I can set it to 5ghz on the phone (advanced tethering settings) but yeah, probably not supported by the HU.
Old 05-18-2017, 04:22 PM   #782
T-WRX_62
Member#: 458326
2015 WRX
CBS
Has Jack sent anyone with the PX5 unit an MCU Update??? I'm running version KLD_2.35. If any of you guys are willing to check your "about" sections. Just about every other PX5 unit excluding this one is actively getting MCU updates, so for Jack to tell me that there aren't any is a bit concerning...
T-WRX_62 is offline   Reply With Quote
Old 05-18-2017, 05:51 PM   #783
husak
Member#: 443909
2016 WRX
This was absolutely the problem, it works great now with bluetooth off!
I did some speedtests, with bluetooth on, i would get about 1-2Mbps download. With bluetooth off, 10-17Mbps!
Old 05-19-2017, 12:57 AM   #784
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Yeah I thought so. It really sucks because I'd like to be able to have the car using the BT signal for phone calls and whatnot. Maybe I'll test out USBtether but I don't know if the radio can do it.
Old 05-19-2017, 08:58 AM   #785
husak
Member#: 443909
2016 WRX
I just checked mine, KLD V2.41b_1 Mar 22nd 2017 not sure why he'd say there aren't any?
That was one of the things I tried. There's nothing stock on the HU to accept USB as 'internet connection'. We would need some kind of middleman app to take the USB connection and emulate it as ethernet or something
Old 05-19-2017, 09:14 AM   #786
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
My unit can do a 3G/4G dongle via USB, so it should have the network connections there. I just have to try
Old 05-19-2017, 09:37 AM   #787
husak
Member#: 443909
2016 WRX
Ah, I only messed with it once for a couple minutes. Turned on USB tethering and couldn't get internet on the HU. I'd honestly prefer USB tether anyway since I have to USB the phone regardless because of the battery drain of hotspot.
Old 05-19-2017, 02:30 PM   #788
Spetnaut
Member#: 464237
2017 WRX
Anyone installed the new Subispeed unit with a factory kicker sub? The subispeed head unit puts out much more wattage then the OEM head unit. Was wondering how the kicker sub is wired, and if I could wire it into the preamp sub out connection instead? I would much rather be able to control the sub independently versus how Subaru has to coming from the rear audio
Spetnaut is offline   Reply With Quote
Old 05-19-2017, 03:05 PM   #789
nux4thecup
Member#: 410405
2017 STI
Does anyone have any suggestions for an app or setup like this?
How Toyota reads out your text messages
nux4thecup is offline   Reply With Quote
Old 05-21-2017, 07:44 PM   #790
T-WRX_62
Member#: 458326
2015 WRX
CBS
Huh, you've got a newer MCU then me. I'm running KLD 2.35_1 March 7th...
Old 05-22-2017, 04:13 AM   #791
2017wrx
Member#: 452036
2017 WRX
Originally Posted by nux4thecup View Post
Still looking for an answer to this
Did you increase the base clock of the cpu from 1.2 ghz to 1.6ghz and change the governor to performance mode?
2017wrx is offline   Reply With Quote
Old 05-23-2017, 09:44 AM   #792
Tegots
Member#: 467688
have you guys tried to use BT tethering instead of wifi/usb?
Tegots is offline   Reply With Quote
Old 05-23-2017, 01:43 PM   #793
Thatsubaruguy77
Member#: 448049
Anyone running the Igo Navigation that came with this unit? when ever I change settings in the nav software it doesn't save after the unit powers back on.
Thatsubaruguy77 is offline   Reply With Quote
Old 05-23-2017, 01:50 PM   #794
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Doesn't work. I can pair the unit to my phone via BT with the mobile hotspot activated, but the unit does not pull internet through it. Only normal audio and phone call BT functions. There are no settings on the unit to use BT as an internet device.
Old 05-26-2017, 02:00 PM   #795
Ultrameca
Member#: 468266
New to this forum, got my Sti a few months ago and I really like it! Except for the Clarion. That thing is just begging to be ripped out of the car, which is what I did.
So I just got my HU from Jack at Aliexpress and I'm having issues with it. It's the Octo with android 6.0.1 on it.
The main issue is the touch screen is completely unresponsive, as are the SWC controls.
I also have the "Please check audio system" message.
I have a 2015 Sti with base radio, so I connected Ant power wire to pin 9 on the harness and connected SWC (brown wire) to pin 13, as per previous posts.
Got a short beep from the speakers when doing a reset, so there is some life there. Since the unit didn't come with any instructions aside from the usual basic schematic using pictures which has been posted here before, maybe the reset/reboot process is more involved than just pressing the button for a couple seconds, I don't know.
Has anyone had this before, and if so, what was the fix?
I did email Jack, but I'm guessing he's out for the weekend now.
Thanks for your help!
Ultrameca is offline   Reply With Quote
Old 05-26-2017, 02:40 PM   #796
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
I think you may have wired something wrong. Since you didn't say how you wired anything, if you used any harnesses or just spliced into your factory wiring... or anything else. we need more than "i connected some wires and it doesn't work, help!"
If you don't know what you're doing and don't know what the wires actually do outside of what pin numbers to connect, its VERY easy to make a mistake. my best advise would be to remove all wiring, and contact a harness maker to make something for your car so that it is plug and play and removes the possibility of you making a wiring mistake.
Old 05-26-2017, 10:08 PM   #797
Ultrameca
Member#: 468266
I'm back at home now.
I took some pictures, but I don’t have enough post history to add attachments directly, so I've uploaded to imgur. I’ll try to link here, hope it works -
The original POS radio:
The hole left after the lobotomy:
The harness that I used:
The one that was left behind (it’s still sobbing in a corner):
The back of the HU:
The top of the HU, showing the schematics:
The plugged-in harness – pretty straightforward (Note Antenna Power wire & SWC wire are not plugged in):
Harness into the HU (bare minimum to get it started):
The HU screen after startup (no amount of soft finger caressing will get it aroused enough to respond in any way):
So that's my first and main problem; the touch screen doesn't respond at all.
Old 05-28-2017, 10:46 PM   #798
Ultrameca
Member#: 468266
To follow up on my question and for future reference, I solved the problem.
Jack had offered me a replacement screen, so I opened the radio to see how difficult the swap would be. I then noticed that one of the flat wires on a tiny PCboard next to the touch screen was not inserted properly into its socket. Plugged it in and now all is ok. This is really a good thing as I can confirm the screen would very difficult to replace. It's bonded to the bezel and there is no obvious prying location to detach it without breaking either the screen or the bezel.
This radio sounds much better than the OEM one.
Old 05-29-2017, 03:46 AM   #799
nux4thecup
Member#: 410405
2017 STI
How do I get the side buttons to light up?
Old 05-29-2017, 04:27 PM   #800
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
you have to hook up the illumination wire and turn the headlights on.
