Welcome to the North American Subaru Impreza Owners Club Friday February 14, 2025
Alaskan Impreza Club
Old 03-24-2005, 03:55 PM   #1
MGAMAN
Member#: 24671
2010 Audi S4 PP
2006 R1 - 06/08 hybrid
Default Left headlight not working?
My left headlight went out a week okay and when i replaced the bulbs they turned out to be okay, but i replaced them anyways, the left headlight still wont work. What do you guys think? Wiring? Water damage from the rains and slush a week or so ago? wiring burn out? Im running the stock foglight bulbs so I dont believe there is an issue related to that.
MGAMAN is offline   Reply With Quote
Old 03-24-2005, 04:08 PM   #2
SQUAD_907
Member#: 10104
WOW! JUST WOW!
I make posts disappear
wiring...check the socket...might have melted?!?!
SQUAD_907 is offline   Reply With Quote
Old 03-24-2005, 05:58 PM   #3
00Maddog
Member#: 62410
2004 wrx w/o engine
psm/carbon
i believe the headlights have sepperate power fuses and relays in the under hood fuse box, I'd have to look in the book to be sure but I would start there if the socket looks good.
00Maddog is offline   Reply With Quote
Old 03-24-2005, 07:29 PM   #4
earlmale
Member#: 47551
04 wrx wagon
jbp
yep, separate fuses for the headlights. that should do it.
earlmale is offline   Reply With Quote
Old 03-24-2005, 08:08 PM   #5
SparkysJDMSpeedWagon
Member#: 52530
2004 For Sale:
Silver 04 wagon w/18g
The fuses you're checking are fuses 3, 8, and "H/L RELAY LH", all on the Main Fuse Box in the engine bay. Here's a picture of which one is which:
Note, this is for 2004's, but it should be the same fuses. 3 is the power relay, and 8 is for daytime running lights.
SparkysJDMSpeedWagon is offline   Reply With Quote
Old 03-27-2005, 08:27 PM   #6
tribalwrx
Member#: 32993
vf39 Best trap 110
Best ET 12.51 Dale tuned
yeah my right side hid went out last night not sure what happened ,checked all the fuses an dswaped the relays to see if that was it and both relays are still good so i'm about to pull it out an dgive it a closer look, see if it comes on with a stock bulb otherwise i'll have to see if its the igniter or the ballast or even the bulb.
mike
tribalwrx is offline   Reply With Quote
03 Forester headlight not working bucanero Electrical & Lighting 0 10-24-2006 10:10 AM
Help - Left headlight stopped working dmaurzada Texas Impreza Club Forum -- TXIC 2 01-22-2006 11:25 AM
Help - Left headlight stopped working dmaurzada Service & Maintenance 1 01-21-2006 08:52 PM
Left speaker not working. Pre-diddy Car Audio, Video & Security 4 12-02-2005 02:10 PM
front and side left blinker not working Der_Dude Electrical & Lighting 1 09-11-2005 10:16 PM
