Welcome to the North American Subaru Impreza Owners Club Wednesday August 15, 2018
Go Back   NASIOC > NASIOC Classifieds > Vendor Storefront Forums > Perrin Performance
Old 05-03-2016, 05:32 PM   #26
PERRIN_Thomas
Vendor Sales Rating: (0)
Member#: 423601
2016 WRX
LBP
Originally Posted by Zombie Panda View Post
So no love for a 02/03 WRX...
Sorry that year is different for some reason
__________________
PERRIN_Thomas is offline   Reply With Quote
Old 05-19-2016, 04:29 PM   #27
nate_fisher
Member Sales Rating: (5)
Member#: 270482
2011 turbotek fxt
[email protected] 4eat xt record?
Confirmed to fit 09-13 forester xt just installed today on my 2011.
nate_fisher is offline   Reply With Quote
Old 07-18-2017, 09:51 PM   #28
RussianTiny
Member Sales Rating: (1)
Member#: 387467
2018 WRX Limited
WRB Stage 2 FlexFuel
Bumping an Old thread. But I tried installing this part (2018 WRX) and after 2 days of this I'm giving up. I loosened the u joint bolts like the instructions but I just can't get the 2 pieces together enough for the short bolt. I ended up stripping the stock bolt hex head i was putting so much force on it.
I watched some installation videos and it seems like my dampeners don't lay flat like others do.
Any other suggestions or tips for install? Do you sell replacement hardware?
RussianTiny is offline   Reply With Quote
Old 07-19-2017, 11:02 AM   #29
PERRIN_Thomas
Member#: 423601
2016 WRX
LBP
Hey!
So we haven't had confirmed fitment for your car but as long as the dampener measure this it should work!
If you do confirm this measurements then I would recommend putting some grease where the lock down slides into, this normally works!
Yes you can get the hardware, just give us a call!
Please let me know if this does or does not work.
__________________
Old 07-19-2017, 01:15 PM   #30
RussianTiny
Member#: 387467
2018 WRX Limited
Ah, I saw it listed as 2015+ and decided to buy. I'll try to measure later. It's a tough thing to measure in that short space. Does this U joint look correct? Here's is the closest I was able to get them.
Do I need to spin the U joint in a certain orientation? I tried a few different ways but nothing worked out, even with a hex bolt
Old 07-19-2017, 03:37 PM   #31
PERRIN_Thomas
Member#: 423601
2016 WRX
LBP
Yes you would spin it tell you get it in the right spot for install.
After i saw this i went and tested this on our 2018 and i got it to work!
So it is now a confirmed fitment, try lubing it up to make it slide easier.
__________________
Old 07-19-2017, 05:17 PM   #32
RussianTiny
Member#: 387467
2018 WRX Limited
Ok thank you, there is hope!. My car is still all apart on jack stands for a bunch of mods so I'll try again.
How do I know what the best angle for the U joint is? It never really seems "straight" to me like in your photos removed from the car.
Old 07-20-2017, 01:50 PM   #33
PERRIN_Thomas
Member#: 423601
2016 WRX
LBP
Oh i was just saying what ever angle works best for you, as far as where your hands go.
__________________
Old 10-17-2017, 10:30 PM   #34
CMoranRVA
Member#: 387281
2015 WRX
I know this is an old thread but thought Id chime in for anyone looking for help. Did this install tonight, and noticed a step that might be helpful in the directions. Turn the steering wheel to the point that gives you the best access to the two 12mm bolts you have to loosen, THEN turn it again to the best angle to install the unit that gives you the best access to tighten the Allen bolt. Repeat step when tightening the 12mm bolt when youre finished.
CMoranRVA is offline   Reply With Quote
Old 11-30-2017, 05:54 PM   #35
Bimmer
Member#: 4116
2002 Impreza TS
Can somebody confirm that this will NOT fit an '02 Impreza?
I want one, but not if it doesn't fit...
Bimmer is offline   Reply With Quote
Old 12-01-2017, 01:29 PM   #36
PERRIN_Thomas
Member#: 423601
2016 WRX
LBP
If the dampener has this measurement then it should work!
__________________
Old 04-17-2018, 11:24 PM   #37
BoostinChick
Member Sales Rating: (26)
Member#: 218971
2007 WRX
Bumping this as it says 2007 WRX fitment is a no, but PERRIN_Thomas said it did work in his 2007? Did different trims come with different sizes?
BoostinChick is offline   Reply With Quote
Old 04-18-2018, 10:05 AM   #38
PERRIN_Thomas
Member#: 423601
2016 WRX
LBP
It didn't work on a 06 WRX, and yes different years and trim models will affect this. Just make sure your dampener looks like the diagram above
__________________
Old 06-18-2018, 09:35 PM   #39
Harey
Member#: 270569
'15 Foz XT & GT86
Just installed this on my 2015 Forester XT and WOW what a MASSIVE improvement!!! I never liked the steering, it was very non linear and found myself over correcting backwards and forwards. Tight roundabouts were a nightmare.
But now the steering is very precise! I cant feel any increase in nvh through the steering wheel which is great. Strongly recommended and wish I had done it sooner.
Harey is offline   Reply With Quote
Old 06-25-2018, 08:23 PM   #40
PERRIN_Thomas
Member#: 423601
2016 WRX
LBP
Awesome! Thank you for your support
__________________
