09-19-2010, 02:22 PM | #1 |
Member#: 131280
BAIC
Vehicle:2004 Impreza WRX WRB |
Hybrid WRX Engine Oil Leak?
I have a 2004 2.0 heads mated to a 2.5 block. However I think I have an oil leak and need to find out which correct gasket I need to use to replace it with. I have included a picture. Its located right behind the whole timing belt cover on the driver side. A part number if possible would be great and if there's any other gaskets needed to go along with it is also appreciate it.
09-19-2010, 02:42 PM | #2 |
Member#: 12811
South East
Vehicle:2002 2.5l Wrx 517whp/516wtq (Stage pi) |
That gasket there is not your problem. If you are seeing oil there it is either left over from being spilled while filling the oil or you have an issue with a cam seal.
09-19-2010, 08:56 PM | #3 |
Member#: 131280
BAIC
So far I've cleaned up that area really well and been driving for most of the day. So far no visible leaks, hopefully it was just oil spilled on there. Will continue to monitor the area.
09-20-2010, 03:53 PM | #4 |
Member#: 112612
Vehicle:2010 Legacy 2.5 CBS 2002 Impreza WRX WRB |
If your not seeing any leaks than I'd suspect the oil that was there had dripped off the dipstick the last time you checked your oil. I've done that.
09-20-2010, 04:16 PM | #5 |
Member#: 184564
Vehicle:2009 SWP Hatch Hella Snail'd |
given the area if you have cleaned it up and it conitnues to leak and you havent been letting oil fall on the area, thats the area of a cam seal.
09-21-2010, 12:08 PM | #6 | |
Member#: 32669
SCIC
Vehicle:2007 2.34LR, EFR7670 LINK G4+ hybrid STi |
PS: I can't see you pic so I don't know where you have oil |
09-21-2010, 01:13 PM | #7 |
Member#: 142244
Vehicle:2007 SWP STi WFC #243 |
+1. take the cover off. this happened to me, but it turned out to be power steering fluid gathering in that rubber timing belt cover gasket.
09-21-2010, 07:27 PM | #8 |
Member#: 131280
BAIC
I appreciate the tips guys. Yeah I've been keeping an eye on it, so far no more leaking. So knock on wood, it was probably just dripped oil.
Similar Threads | ||||
2.5 hybrid pass. side oil leak | Twiztidunreal | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 7 | 06-03-2008 11:39 PM |
1.8L FWD engine oil leak | yimmer | Normally Aspirated Powertrain | 15 | 07-17-2004 04:08 AM |
Engine oil leaking | GTKim | Service & Maintenance | 8 | 09-15-2002 06:03 PM |
Engine Oil Leak ? | JAnderson | Normally Aspirated Powertrain | 2 | 04-28-2002 07:40 PM |
Engine oil leaking into transmission | bmacauto | Normally Aspirated Powertrain | 5 | 02-23-2002 04:00 PM |
