Welcome to the North American Subaru Impreza Owners Club Monday September 20, 2021
Old 10-15-2015, 02:53 PM   #126
kaspbrochill
Member#: 432122
Any pic's of the new brakes installed?? I personally went with Powerstop's drilled/slotted rotors + carbon fiber/ceramic pads for my gf's legacy because for $250 for all rotor's and pads...I couldn't pass them up!
kaspbrochill is offline   Reply With Quote
Old 12-17-2015, 02:16 PM   #127
stiloljk
Member#: 436330
Originally Posted by Butt Dyno View Post
After seeing williayayaytya's new writeups I figure we should have a place to list all of them. I am not going to attempt to get all of them - just starting the thread so folks can add stuff.
This thread should not, repeat NOT become a place where everyone asks questions about how to install things - it is purely to compile links to the actual threads themselves.
Here goes...
Thanks for putting these together
stiloljk is offline   Reply With Quote
Old 01-08-2016, 08:11 PM   #128
mikenekminit
Member#: 437696
cheerz
mikenekminit is offline   Reply With Quote
Old 02-14-2016, 02:12 PM   #129
Lilgibby
Member#: 440394
Default Helpp!!!
hit a curb the other day in my 16 wrx now the back wheel looks like the toe is off atleast +5 degrees i want some advice as to if somethings broken or bent or its simple as the alignment might be off or the toe, before i bring it into subaru
Lilgibby is offline   Reply With Quote
Old 12-02-2016, 03:03 PM   #130
maat922
Member#: 456972
You can see it??
maat922 is offline   Reply With Quote
Old 12-02-2016, 03:04 PM   #131
maat922
Member#: 456972
That seems extreme.
Old 04-13-2017, 12:39 AM   #132
terrainasaurus
Member#: 464727
2008 Outback Sport
OBP/DGM
Originally Posted by BIGSKYWRX View Post
torque spec/wrench size for suspension/brakes/drivetrain
http://www.clubwrx.net/forums/showthread.php?t=80548
Thank the gods for this.
terrainasaurus is offline   Reply With Quote
Old 04-13-2017, 08:58 AM   #133
BIGSKYWRX
Member#: 7958
09 GH B+
sweet
BIGSKYWRX is offline   Reply With Quote
Old 04-19-2017, 10:47 PM   #134
NVWRX
Member#: 466340
Default Many Thanks!
Suspension question answered! You all are the best!
NVWRX is offline   Reply With Quote
Old 09-14-2017, 04:49 PM   #135
RSTM
Member#: 204463
2016 Impreza Sport
Crystal White
STOP ASKING QUESTIONS! READ THE FIRST POST BEFORE POSTING!! THIS IS NOT A DISCUSSION OR Q&A THREAD!!!
RSTM is offline   Reply With Quote
Old 09-14-2017, 05:41 PM   #136
Evilchargerfan
Member#: 183529
i wanna help teh
haters ... love life ...
above you are 3 whole posts in the last 5 months .... three.
if you feel that's way too chatty... perhaps time to call in a mod to start putting people on time out
Evilchargerfan is offline   Reply With Quote
Old 01-07-2018, 09:47 AM   #137
Wrightdu
Member#: 291400
2011 Forester
Default Lower Control Arm Bushing removal!
In dire need of assistance in the removal of the lower control arm bushings on a 2011 Forester. Appears to be the same bushings as Impreza. Rented a press but cannot find proper size to use for pressing them and all the shops in the area are closed. Tried all the adapters the press came with as well as random sockets. Any help and assistance would be greatly appreciated. I've search everywhere and can't seem to find any detailed instructions on folks actually pressing out the bushings.
Wrightdu is offline   Reply With Quote
Old 01-07-2018, 12:03 PM   #138
Lilyjess18
Member#: 479122
I had to cut mine out. Heat them up really good and saw zal it out. First side took like 45 mins but once I got the concept other side was about five mins. Use torch it will really help. Never tried to press them bc of weird angle they sit.
Lilyjess18 is offline   Reply With Quote
Old 01-09-2018, 12:55 AM   #139
dagger108
Member#: 337743
2002 WRX Wagon
WRC Blue
It has been a while, and not certain we are even talking about the same bushings. Big rubber ones without much metal around them to press against? I'm recalling taking 2 different types of drills to them. One was just to make a lot of little holes with a 1/4" bit that weakens the rubber, followed by a torch and lots of fire. Not real efficient, but very cathartic after working at it way too long.
The better route was to get a hole saw. Larger than the metal sleeve around the bolt, but smaller than the outside of the bushing. Even easier if you have a dowel the size of the bolt that the guide bit can bite into. Maybe there was some more cutting and burning. Sorry, it's been 5 years.
dagger108 is offline   Reply With Quote
Old 03-21-2018, 03:24 PM   #140
Ramzo
Member#: 483671
excellent article
Ramzo is offline   Reply With Quote
Old 07-03-2018, 01:23 PM   #141
Vesper25
Member#: 487917
super helpful thread
Vesper25 is offline   Reply With Quote
Old 10-20-2018, 11:40 PM   #142
subaru2010
Member#: 484831
2010 Impreza 2.5
What are recommended brakes/rotors for a 2010 Subaru Impreza 2.5i Premium non-turbo?
subaru2010 is offline   Reply With Quote
Old 11-03-2018, 12:49 PM   #143
turboICE
Member#: 33979
2006 STi
I ordered the following last year from Tire Rack when my original brakes were finally used up on my 2011 OBS, which lasted quite a long time.
They work very well in conjunction with my performance tires. They dust more than OEM but not horribly so. I am happy with them.
2 Centric Plain 120 Series Rotors - Manf. Part #: 120.47012
(Front) plain vented rotor.
2 Centric Plain 120 Series Rotors - Manf. Part #: 120.47029
(Rear) plain solid rotor.
1 Hawk hp street 5.0 pads - Manf. Part #: HB432B.661
Front brake pads.
1 Hawk hp street 5.0 pads - Manf. Part #: HB557B.545
Rear brake pads.
Get them from your preferred NASIOC Tire Rack Wholesaler along with a brake flush and you will be all set.
turboICE is offline   Reply With Quote
Old 11-23-2018, 12:56 AM   #144
petersensignej
Member#: 490223
petersensignej is offline   Reply With Quote
Old 03-30-2019, 04:30 PM   #145
Jamesa86
Member#: 499755
Default Question
I got some rear complete struts for my 2013 wrx sedan and they sent me 2010 sti hatch struts, from what I have been able to research they may fit but I want to confirm this. Part number they sent 20365FG500
Jamesa86 is offline   Reply With Quote
Old 09-24-2019, 10:55 AM   #146
hamsandwitch207
Member#: 506693
Default need new brakes and dont know what to get help ??
im in the market for new brakes for my 03 wrx (clippers rotors and pads all around) but im not sure what to buy. i want something streetable but i want good stopping power and i also want them to last as long as possible
hamsandwitch207 is offline   Reply With Quote
Old 05-07-2020, 03:45 PM   #147
Blooroo86XT
Member#: 514552
1986 Subaru XT
Here goes...
Whats the quote you doin
Blooroo86XT is offline   Reply With Quote
Old 05-07-2020, 03:46 PM   #148
Blooroo86XT
Member#: 514552
1986 Subaru XT
They should fit since its the same frame
Old 05-07-2020, 03:47 PM   #149
Blooroo86XT
Member#: 514552
1986 Subaru XT
I would just replace the arm completely, i dont like replacing just the bushings cause then threads get messed up
AZP Installs -Your Tri-state Brake and Suspension Installers- AZP Installs Suspension/Brakes/Handling 10 09-09-2008 07:35 PM
Ten+ simple rules for Brakes/Steering/Suspension - READ THIS BEFORE POSTING! Butt Dyno Brakes, Steering & Suspension 5 04-09-2008 11:25 AM
ssautochrome install walkthrough? Ceyvme Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-06-2006 06:46 PM
kyb agx and spring install walkthrough?? CXspeed Newbies & FAQs 4 05-09-2006 10:45 AM
Boost Gauge Install Walkthrough? Uncle Ben Electrical & Lighting 4 07-15-2003 04:31 PM
