Welcome to the North American Subaru Impreza Owners Club Monday September 20, 2021
Old 02-15-2009, 10:48 PM   #1
r12rex
Member#: 77894
2015 XV Crosstrek
Crystal Black
Default Ball joint cone removal
How the heck did you guys remove the cone on the ball joint?
I was installing my RCA kit and got the ball joints out...everything was ready to go, but I could not get the cone off the ball joint for the life of me.
Suggestions?
FWIW I used PB blaster on the cone with no luck.
Kind Regards,
Ryan
Anyone have a set laying around I can use? $$?
r12rex is offline   Reply With Quote
Old 02-15-2009, 10:51 PM   #2
STi-MAN
Member#: 70252
05 STI
blue
check you post on iwsti...
anyways
Use a pitman arm puller on it.. go to pep boys. pick up a pitman arm puller.
it'll be off in a second.
STi-MAN is offline   Reply With Quote
Old 02-15-2009, 10:59 PM   #3
MasterKwan
Member#: 98961
2003 WRX
I used a press. Puller looks good though.
Old 02-16-2009, 01:26 AM   #4
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
That one tool will pop the ball joint out of the control arm, pop the cone off the ball joint, and pop the outer tie rod out of the knuckle. All for $15.
Old 02-16-2009, 02:55 AM   #5
STi-MAN
Member#: 70252
05 STI
blue
^^tried looking for that one.. couldnt find it anywhere...
Old 02-16-2009, 02:56 AM   #6
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
NAPA has two kinds. A $15 one and a $45 one. The only difference is that the $45 has a ball bearing at the end of the bolt to reduce friction. Obviously, I bought the cheap one
Old 02-16-2009, 02:58 AM   #7
STi-MAN
Member#: 70252
05 STI
blue
^ yeah.. if you have a choice go for the one williaty posted.. I should have checked out napa..
with the pitman, if you remove the outer tie rod you'll have to remove the rotors (yes i did that) with the one williaty posted.. you dont have to, so its sooo much better.
Old 02-16-2009, 03:01 AM   #8
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
My only warning is wear hearing protection when you use that tool. It'll sound like .45ACP round going off next to your ear when it breaks the joint loose.
Old 02-16-2009, 03:13 AM   #9
STi-MAN
Member#: 70252
05 STI
blue
ahah wow... nice warning.
Old 02-16-2009, 03:16 AM   #10
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
First time I popped a balljoint out of the LCA with that, I was reeeeeeaaaaly cranking on the wrench. I got worried I was going to break the tool. I stuck my head into the wheel well to be able to look behind the rotor to make sure that the tool wasn't hung up or something. I gave the tool a poke and the joint finally let go. With my head still in a confined space with it. I literally couldn't hear for ~30 minutes and my right ear rang for 4-5 days afterwards.
Old 02-16-2009, 08:23 AM   #11
MasterKwan
Member#: 98961
2003 WRX
I've found that when you get it tight to the point you don't really want to tighten it any more. A couple taps on the control arm with a hammer will often unfreeze it and let it pop out. I have the ball bearing one and ball has actually gouged the arm it rests on.
Old 02-16-2009, 09:05 AM   #12
PolarisSnT
Member#: 85905
2004 WRX
JC Whitney has it too.
PolarisSnT is offline   Reply With Quote
Old 10-19-2009, 11:13 AM   #13
Snowphun
Member#: 1800
anyways
This thing is *beefy*. Pep Boys sells two, this is the larger one (part number is visible in the pic) and $20. I tried a number of other tools before this with no luck. It took a lot of pressure for mine to pop but it did.
The NAPA tool looks awesome but my local shop confirmed no one in the area (including the warehouses) had it in stock.
Snowphun is offline   Reply With Quote
Old 06-17-2017, 10:18 PM   #14
motorsport816
Member#: 427578
I know this is an old thread. If you are not reusing the ball joint that is stuck in the cone, put it in a vise and gently tighten it on the cone itself. Be careful that you don't damage the cone or it won't sit in the control arm like it should and you'll have to clean it up with a grinder. Get out a propane torch and evenly heat the con for 30 seconds or so and tap the threaded stud with a hammer and it will come right out. The first on I did this way came apart on its own, all I had to do is heat it. The second one just took the lightest tap with a hammer. You may burn the ball joint boot so be careful. If you are putting in a roll center kit in it won't matter. Hope this helps
motorsport816 is offline   Reply With Quote
Old 09-03-2021, 11:45 AM   #15
chmod755
Member#: 35115
Thank you, old reply to an even older thread. Heating the cone worked like a charm!
chmod755 is offline   Reply With Quote
Old 09-07-2021, 09:38 AM   #16
REX_WGN
Member#: 107618
2006 WRX Wagon
2009 FXT
I use a 3-jaw puller
Works like a charm. If you live near a tool rental place, get the smallest one they have.
REX_WGN is offline   Reply With Quote
The ULTIMATE Ball Joint Removal VIDEO! Remove with Ease! (2004 WRX in video) Bad_T Brakes, Steering & Suspension 46 05-18-2015 09:51 AM
Cone removal on ball joint r12rex Southern California Impreza Club Forum -- SCIC 1 02-15-2009 03:25 PM
oem ball joints vs moog ball joints ROC pit-bull Car Part Reviews 2 07-14-2006 11:21 PM
ball joint removal vtownrida Brakes, Steering & Suspension 12 11-16-2005 09:32 AM
Removing ball joint IggDawg Brakes, Steering & Suspension 2 12-13-2002 02:36 PM
