Welcome to the North American Subaru Impreza Owners Club Monday September 20, 2021
Old 05-28-2016, 12:04 AM   #1
McCarthy
Member#: 391336
2016 WRX
Pure Red
Default True dual-purpose suspension- Rally and race- 2016 WRX
Hey guys,
Recently picked up a 2016 WRX. To paint you a picture, I live in a fairly remote part of Canada. We see a lot of snow in the winter, and a fair bit of bumpy washboard gravel roads. In the summer, our roads are extremely tight, technical, and basically imagine a california canyon with nobody on it. I also track, and autocross my car.
I'm looking for a suspension system that will do all these things well. I DO NOT want to lower the car whatsoever. Coilovers with a range of adjustment of say an inch over stock, and an inch lower than stock (for winter and summer respectively) would be perfect. Probably a big monotube adjustable coilover with lots of travel for the washboard and enough spring rate to keep body roll at stock levels, if not better. Speaking of, can I fit a 15" wheel over stock WRX brakes?
I understand it will not be cheap. I'm okay with that. Suggestions?
McCarthy is offline   Reply With Quote
Old 05-28-2016, 02:02 PM   #2
mitch808
Member#: 10228
2002 Subaru WRX
Something like a DMS 50mm coilover comes to mind?
Lower cost would be from Feal Suspension
mitch808 is offline   Reply With Quote
Old 05-28-2016, 02:22 PM   #3
mrsaturn7085
Member#: 375462
2006 Impreza WRX STI
WR Blue
The common names for rally suspension are Reiger, DMS, EXE-TC, RS&SP (are they still around?), Ohlins, etc.; all good places to start if cost is no object.
If you want something a little cheaper, give Feal a call.
Not all these companies may have 2016 WRX solutions, but they'd be a good place to start.
mrsaturn7085 is offline   Reply With Quote
Old 05-28-2016, 05:05 PM   #4
McCarthy
Member#: 391336
2016 WRX
Pure Red
Thanks guys.
The budget isn't unlimited, but i'm not expecting to pick up what I need for 1000 bucks like a cheap set of tein's or bc coils.
Ideally around the 2-2500 range.
Old 05-29-2016, 02:08 AM   #5
mrsaturn7085
Member#: 375462
WR Blue
2000-2500 is just getting into reasonable track coilovers - rally stuff is generally on a scale of 2-4x more. Call Feal - they'll be the best bet.
Old 05-29-2016, 02:35 AM   #6
McCarthy
Member#: 391336
2016 WRX
Pure Red
5-10k for a rally coil? That seems a bit... High...
Old 05-29-2016, 03:25 AM   #7
-Raven-
Member#: 416044
2015 Subaru WRX 6MT
K1X
Nope. Seems spot on. A set of DMS rally coilovers starts at about $5.5K.
If you really want to be wowed, have a look at how much a set of King shocks costs for a trophy truck!
-Raven- is offline   Reply With Quote
Old 05-29-2016, 05:58 AM   #8
scoobyRx
Member#: 33789
04 WRX Red
20 WRX silver
Maybe a dumb question but what's wrong with stock? That's probably the best suspension to do everything you mention. A good rally suspension isn't gonna be the best thing for track and vice versa, esp. in that price range. I'd suspect the stock units will handle a lot and you don't have to worry about lowering the car or the stiffer ride on the road.
If you are looking to be truly competitive then one suspension probably won't cut it.
scoobyRx is offline   Reply With Quote
Old 05-29-2016, 07:47 AM   #9
A-man07
Member#: 271525
7/2 STi/WRX wagon
SWP/AW
I assume you mean asking Feal to revalve stock struts as their other offerings are going to have less travel than stock struts. But still, I fail to see how Feal will get him to his stated goals.
A-man07 is offline   Reply With Quote
Old 05-29-2016, 12:20 PM   #10
McCarthy
Member#: 391336
2016 WRX
Pure Red
Uhh... Have you ever taken the stock dampers off pavement?
Bye bye back.
Old 05-29-2016, 12:22 PM   #11
McCarthy
Member#: 391336
2016 WRX
Pure Red
Well considering i'm not building a trophy truck, no lol.
I guess i'm looking in the realm of like an MCS coil or similar. Something that is a high end monotube damper that I can pair with a set of properly rated springs, and a lot of travel, with a good amount of ride height adjustability.
With those in place, competence on tarmac will follow, as long as I don't go for a super soft spring.
Old 05-29-2016, 01:29 PM   #12
mitch808
Member#: 10228
2002 Subaru WRX
They do make one rally focused coilover with about an inch more travel. But from the looks of things really just a derivative of their typical setup
Old 05-29-2016, 10:49 PM   #13
jamal
Member#: 71875
I think a DMS 40 is closer to 3k, it's the 50mm shocks that start at like 5500. Lucky for you dms north america is in canada so you might not have to take a huge hit from the exchange rate.
They might actually be a little less for your car than the GD etc as the rears aren't a big inverted strut.
jamal is offline   Reply With Quote
Old 05-29-2016, 11:26 PM   #14
McCarthy
Member#: 391336
2016 WRX
Pure Red
I can go for that if they work. Thanks for the advice, i'll get on the horn tmrw and see what they think!
Old 08-31-2021, 03:42 PM   #15
H4yduk3
Member#: 521629
Default OP- What did you end up going with?
I'm in a harsh, remote environment, as well, and Need more ground clearance. I have a similar budget, and was wondering if you found any decent coilovers.
Feal is made for tarmac use Only.
King Springs and GTWork/Bilstein Strut combo will cost $1,600 plus tax, shipping, etc. They're not adjustable, and raising by spring will cause more bounce, too my understanding, which is the Last thing I need off-road.
Is there a section of these forums for Lifting WRX's for off-road purposes?
If so, I haven't found it.
If not, it'd be Great to start it.
I may have enough replies to start a thread at this point...
Thanks, all.
H4yduk3 is offline   Reply With Quote
Old 08-31-2021, 04:04 PM   #16
whozatguy
Member#: 179775
03 WRX/15 FXT
14 BRZ/ 92 SVX
https://forums.nasioc.com/forums/sho....php?t=1228188
Feal also offers the max travel version of all their coilovers that offers, you guessed it, more travel. Its a selectable option under 'Spec Type' when looking at the coilovers for your chassis.
whozatguy is offline   Reply With Quote
Old 09-16-2021, 07:43 PM   #17
Mike_Feal
Member#: 462296
2003 Lexus IS300
2JZ 620HP/595TQ
Appreciate the plug, but we discontinued any Rally type coilover offerings a few years back. The Max Travel do offer more travel and a softer ride but we don't recommend them for spirited offroad use because they WILL get damaged.
Mike_Feal is offline   Reply With Quote
Old 09-17-2021, 08:59 AM   #18
whozatguy
Member#: 179775
03 WRX/15 FXT
14 BRZ/ 92 SVX
Good to know, thanks!
