Welcome to the North American Subaru Impreza Owners Club Monday September 20, 2021
Old 02-19-2020, 09:34 PM   #26
cdigerlando
Member#: 6070
2015 STi
Dark Gray Metallic
There is a video on YouTube. Look up sti steering repair to get a look.
cdigerlando is offline   Reply With Quote
Old 02-19-2020, 09:40 PM   #27
ScuubyT
Member#: 38243
2004 Impreza WRX
WR Blue Pearl
I'll give that a shot, thanks!
ScuubyT is offline   Reply With Quote
Old 02-19-2020, 09:45 PM   #28
ScuubyT
Member#: 38243
2004 Impreza WRX
WR Blue Pearl
I found one, looks like even though there are two bolt holes it's still just a round seal. Looking at it we assumed it would be more like an exhaust gasket.
Thanks for the help!
Old 03-17-2020, 12:06 AM   #29
lwlba
Member#: 436739
Just want to throw in there as well that my sti at 74k is also experiencing the leak. Will be looking into some repair soon.
Agreed. First time subaru owner, I have to say I'm quite disappointed this happened 4k miles outside of my extended warranty.
lwlba is offline   Reply With Quote
Old 03-17-2020, 07:08 AM   #30
SubyManV7
Member#: 500350
The part number I posted is what I used on my 2013 WRX STi. It worked. Thats all I know. It has two seals one inner and one outer one for the steering shaft.
SubyManV7 is offline   Reply With Quote
Old 08-22-2020, 12:04 PM   #31
k2blt
Member#: 26105
'17 STi
'98 Impreza '14 FXT
My 2017 STi with 70k daily driving miles just started leaking 2 weeks after getting it aligned. Absolutley zero track, hpde, or auto-x miles on this car.
How many complaints before they decide to make it a recall issue!?!?
k2blt is offline   Reply With Quote
Old 03-31-2021, 02:46 PM   #32
skw6r
Member#: 423690
17 STi, 66k miles all daily driving just started leaking. Only suspension mod is RCE yellows at about 10k. Got quoted around $1000 by an independent subaru mechanic for OEM rack replacement.
skw6r is offline   Reply With Quote
Old 04-06-2021, 02:49 PM   #33
REX_WGN
Member#: 107618
2006 WRX Wagon
2009 FXT
I wonder what's the culprit? Is it the pressure of the fluid? faulty seals?
REX_WGN is offline   Reply With Quote
Old 04-08-2021, 02:30 PM   #34
cdigerlando
Member#: 6070
2015 STi
Dark Gray Metallic
That's a good deal. But I paid $386 to get it repaired. Still going strong.
Old 04-08-2021, 02:31 PM   #35
cdigerlando
Member#: 6070
2015 STi
Dark Gray Metallic
Faulty seals where the steering wheel shaft enters the power steering rack. Take a look at the video I posted to see the rebuild.
Old 04-08-2021, 02:38 PM   #36
murrdogg24
Member#: 50586
2020 STI
Crystal White Pearl
I have a 2020 sti that is already making some weird noises occasionally from the power steering, wonder if I should take it in already...only has 9k miles on it....
murrdogg24 is offline   Reply With Quote
Old 04-10-2021, 09:28 PM   #37
Superdave1.0
Member#: 523636
This should be a TSB or recall. I'm working on a 2016 STI now because of it. 33k miles.
Power steering ran dry for this owner (friend of mine). Rack leaking at input shaft. Loud noises from pump because ran dry.
Towed to dealer. Diagnosed, needs PS rack and pump. New OEM rack, OEM pump purchased.
Steering is shuddering now. Even on jack stands. Bled the system many times. New clamps on the hoses, new PS belt. Need some help!
Superdave1.0 is offline   Reply With Quote
Old 04-11-2021, 12:25 AM   #38
T-37
Member#: 175624
0304 WRX WRX
SY WRB
If you haven't already solved the issue
Jack up the front and cycle the wheels side to side about 20x with the engine off, then about 20x with the engine on, shut off the engine and wait for bubbles to disappear in the reservoir and repeat. If shuddering persists try jacking up one side higher and repeat (air bubbles can be trapped in the rack itself)
T-37 is offline   Reply With Quote
Old 04-11-2021, 04:10 PM   #39
ShibliSTi
Member#: 523650
Hey, I'm actually the owner of the STi - we did try that but we haven't tried it with jacking it up one side higher than the other so we'll give that a go this week
ShibliSTi is offline   Reply With Quote
Old 04-13-2021, 09:04 PM   #40
Homemade WRX
Member#: 33782
96 3MI Racing
search FIRST, then PM!!!
I've always had good luck with the 'run it rack to rack' 15-20 times. I've never had an issue but the leaning method is new to me. I'll keep that one in storage if needed.
I'm about to rebuild my own leaking 2015 STi rack.
Old 04-13-2021, 09:55 PM   #41
ether947
Member#: 297799
2003 WRX
EJ207 version 8
I put the wrong Dexron fluid in my old 2005 STi power steering system and it shuddered randomly (and pretty violently) until I replaced it with the correct fluid. Apparently, I can't read roman numerals. I don't know what fluid Subaru uses for the VA STi racks but it's something to consider.
Coincidentally, I just took my new to me 2015 Sti rack apart. I am depowering it and hopefully I never have to deal with p/s fluid ever again.
ether947 is offline   Reply With Quote
Old 08-19-2021, 10:59 PM   #42
WRXyInRed
Member#: 526158
Adding to the list here. 17 STI, 45k miles, no mods, no track/x-cross, just city/highway miles. Mine rack leaked, failed to the point that I had it towed to my local dealership (I know, I just took it there to see if it was warrantied). They quoted $1200 for a full replacement and I opened a case with SoA. They offered to pay $7** (can't remember the specific number) towards repair. I'm going to call them back because it seems like an issue affecting multiple people so I'm not just going to trust repairing or replacing the part with the same thing.
WRXyInRed is offline   Reply With Quote
Old 09-04-2021, 05:58 PM   #43
djoye
Member#: 50072
2017 STI
'17 STI 50k miles and for a bit I've noticed something in my splash guard when inspecting the engine bay on a regular basis. I've noticed this for a while, so I should've paid better attention, but today it looks worse and sometimes I hear a different sound when turning the steering wheel. Car does have mods, but no suspension mods. Never tracked it and it doesn't even get driven hard.
Rack on my '03 WRX lasted around 200k, this is ridiculous.
EDIT: Finally got under the car and the rack seems fine, but the sway bar bushings appear to be the culprit. I had seen them seeping in the past, but they must have recently started leaking more junk.
djoye is offline   Reply With Quote
Old 09-05-2021, 11:11 AM   #44
cdigerlando
Member#: 6070
2015 STi
Dark Gray Metallic
Depowering it. What's that like? No we didn't all just put the wrong fluid in, unless subaru did, so I doubt it. Many cars just totally stock. The system has problems. Period. Too many people with the same issues over and over again, and no commitment by subaru to make a permanent fix. Very frustrating. Wish they could at least determine the design flaw that wears out the seals that quick. Unless it was a factory seal install issue. We'll see. My repaired rack is still going strong after 84k.
Old 09-05-2021, 11:14 AM   #45
cdigerlando
Member#: 6070
2015 STi
Dark Gray Metallic
Great suggestion. Thanks.
Old 09-05-2021, 12:40 PM   #46
ether947
Member#: 297799
2003 WRX
EJ207 version 8
I'm still dialing the EPAS setup in, but I am pretty happy with it so far. Not having to worry about leaks anymore is great. Now I worry about electrons.
Old 09-08-2021, 01:29 PM   #47
faminiSTi
Member#: 458295
Sorry for reviving an old post, but My stock 2017 Sti barely has 26,000 miles has the same issue with leaky steering rack. I took it in a local Subaru dealership for diagnosis, and they quoted me $1,700 for the repair. And the best part of it is not covered under powertrain 5yr warranty.
I opened a case with SOA and hopefully they could assist me on it.
faminiSTi is offline   Reply With Quote
Old 09-08-2021, 04:27 PM   #48
REX_WGN
Member#: 107618
2006 WRX Wagon
2009 FXT
I'm surprised Subaru has not yet issued a service bulletin or some sort of recall to fix this issue
Old 09-10-2021, 10:20 AM   #49
cdigerlando
Member#: 6070
2015 STi
Dark Gray Metallic
Yes. It will be interesting to see if the seal replacement does the trick. I'm almost wondering if air got in the system in the factory or during delivery that caused the problem. Air in any hydraulic system is very damaging to seals. I really liked the suggesting posed tipping the car and turning the wheels back and forth to remove air from the system. It makes sense to me, but who knows.
I also replaced my steering column bushings with something stiffer, to get rid of that mushy feeling high speed that these steering columns have. Although the steering is extremely tight. You really have to keep your eye on the road.
Old 09-10-2021, 10:23 AM   #50
cdigerlando
Member#: 6070
2015 STi
Dark Gray Metallic
Sorry you are having this problem too. Let us know how you make out. That is ridiculous to have this problem.
But if you have to have it repaired, look at the fix on youtube. It's cheaper and you can have your favorite mechanic work on it.
