Welcome to the North American Subaru Impreza Owners Club Monday September 20, 2021
Old 07-02-2019, 12:16 PM   #1
xthejuicex
Member#: 105732
2005 STi
Question HELP! - ABS light on and binding front diff - No ABS Codes :(
Hey all, I have a 05 STi and I recently have been experiencing an issue where my front diff is binding on sharp turns as well as the ABS light being on.
Symptoms:
Bind/chunking at slow speeds
ABS light on / ABS not working
Tests:
First I checked all fuses in the kick panel and under the hood, none are blown.
I put the DCCD into fully open and the amount the diff binds goes down a lot but is still prevalent.
Replaced passenger axle as it was leaking from the boot a tad. No Change, old axle CV joint is fine.
Connected Laptop with FreeSSM and there are no ABS trouble codes. I can monitor the sensors in the "Transmission" diagnostics but I get NO readings for the speed sensors or the "ABS" sensor variable. (Is this normal?) I still see brake light, neutral, yaw readings.
I have tried to get any codes by initiating the ABS flash sequence using the DCCD dial, however when I do this, the DCCD green oval just flashes continuously (no code sequences).
I replaced the ABS module which is connected to the ABS pump with a used working unit. No change.
I tested to make sure ABS was indeed not working by getting up to speed and able to lock up all tires with heavy braking.
Front diff/trans fluid is at normal level and has been replaced 6-8 months ago (Motul 300).
HELP!
I have read that the ABS and DCCD modules work together and I am assuming that since the ABS is not working correctly, the DCCD is not adjusting correctly at low speeds causing the binding.
I am now stumped and do not know what to try next. Has anyone experienced anything like this or know what else I should try to test?
Any help would be greatly appreciated.
Thanks!
xthejuicex is offline   Reply With Quote
Old 08-27-2021, 06:10 PM   #2
Momo loco
Member#: 218487
2013 Wrx
Iím having the same exact issue with my 05 sti!!
Momo loco is offline   Reply With Quote
Old 08-27-2021, 06:12 PM   #3
Momo loco
Member#: 218487
2013 Wrx
Iím having the same exact issue with my 05 sti!! Wish I had some advice for you. Please let me know if you figure it out!
