Welcome to the North American Subaru Impreza Owners Club Monday September 20, 2021
Old 08-27-2021, 08:00 PM   #1
RealBACONATOR2
Member#: 520025
2011 Impreza OBS
Default Creaking from rear after 1.5" lift? (With subframe spacers)
Didn't know if anyone had experience with this, got some weird creaking from the rear of the car after lifting it 1.5" and putting on the subframe spacer kit. (Anderson Design Fab)
I'm a bit stumped since the subframe spacers should have dropped everything down to original angles in the rear. If it helps the creaking sounds like it comes from the outside of the rear, both sides.
(2011 impreza hatch)
RealBACONATOR2 is offline   Reply With Quote
Old 08-28-2021, 07:25 AM   #2
Elbert Bass
Member#: 283429
2016 Fuji Sunfire 03
Did you loosen and then tighten the trailing arm link bolts with the car sitting at the new ride height so they wouldn't be in a bind?
Elbert Bass is offline   Reply With Quote
Old 08-28-2021, 10:09 AM   #3
RealBACONATOR2
Member#: 520025
2011 Impreza OBS
I didn't do that! Thanks! I'll give those a look. Can you do that with the car jacked up?
Old 08-28-2021, 10:42 PM   #4
Elbert Bass
Member#: 283429
No - The vehicle must be at ride height so the bushing is is not "loaded".
Old 09-12-2021, 07:00 PM   #5
RealBACONATOR2
Member#: 520025
2011 Impreza OBS
Thank you!!! This fixed the main source of the noise. Man those bolts are hard as hell to access with the wheel on the ground, but managed to get there.
