Welcome to the North American Subaru Impreza Owners Club Monday September 20, 2021
Old 09-11-2021, 03:22 PM   #1
jeff6666p
Member#: 400078
1998 2.5rs06wrx swap
black
Default Autox sway bar set up question
I read if you put a bigger front sway bar your get quicker turn in. If you put a bigger front bar on but then put a larger rear bar on does it negate the turn in response from the bigger front bar?
jeff6666p is online now   Reply With Quote
Old 09-11-2021, 04:42 PM   #2
subaru_gc8
Member#: 29292
2004 WRX wagon
if you put on a larger rear sway bar you get more rotation. I would more use the front bar if you need more stabilization in the middle of a corner
subaru_gc8 is offline   Reply With Quote
Old 09-13-2021, 10:01 PM   #3
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
All changes affect the balance and particular handling characteristics of a car. Depending on the relative bar sizes front and rear, and the spring rates and dampers a bigger rear bar can negate the turn in response from a larger front bar. That is where balancing spring rates and bar rates becomes important.
My '96 XP autocross car for instance ran 800 lb/in front and 600 lb/in rear springs with a 22mm front bar and no rear bar for a very balanced and active suspension.
Also very important is the alignment. It has as much effect on handling as any other component in the car.
speedyHAM is offline   Reply With Quote
