Welcome to the North American Subaru Impreza Owners Club Monday June 23, 2025
Old 12-15-2008, 08:39 AM   #1
joe1
Member#: 93518
2011 Impreza WRX STI
WR Blue Mica
Default Short throw shifter assembly installation
I got a SPT short throw shifter for my wedding present last week. The assembly has no installation instructions, so instead of winging it, I decided to do some reseach. I found some information on Subaru Drive Performance and ClubWRX. It all looks simple, but when I tried to do it, I ran into some difficulty accessing the 2 bolts in the rear.
The driveshaft and exhaust make things a little cramped, so its difficult to get enough leverage to break the 2 bolts in the rear. Does anyone have some advice or suggestions?
joe1 is offline   Reply With Quote
Old 12-16-2008, 04:40 PM   #2
SubieTheThird
Member#: 191196
2006 WRX Wagon
Yep. Just did this myself. Here are my hot tips:
1. Drop the mid-pipe. Not really a big deal to remove and makes SO much more room for hands and wrenches. Make sure to unplug the 02 sensor.
2. Do yourself a favor and do the Kartboy shift bushings (all of them) while you have it apart.
3. Rear bolts: even with the midpipe out, the drive shaft will still cramp your style. The bolts (especially the passenger side) will be much easier to remove with a wobble socket on an extension, rather than trying to stuff a regular socket or box-end wrench up there.
SubieTheThird is offline   Reply With Quote
Old 12-16-2008, 05:19 PM   #3
joe1
Member#: 93518
WR Blue Mica
Thanks for the hot tips. I'll give it another stab this weekend.
Old 12-16-2008, 07:02 PM   #4
PARANOID56
Member#: 22035
2014 Brocoma DCab
71 FJ40, 13 DRZ400SM
or get a swivel socket and a long extension. thats usually how i do it. that way i dont have to remove the exhaust.
PARANOID56 is offline   Reply With Quote
Old 12-16-2008, 07:39 PM   #5
ImWithStupid
Member#: 197661
It is a pita. The COBB is nice because you only have to get under the car to hold the reverse lockout - no bolts or anything.
ImWithStupid is offline   Reply With Quote
Old 12-16-2008, 08:05 PM   #6
joe1
Member#: 93518
WR Blue Mica
5MT has no reverse lockout. I agree its a PITA, but I read in the Cobb installation instructions that you have to trim (ie dremel) the metal plate to make space for the shifter. That sounds like even more PITA.
FS: Short Throw Shifter - Very Short Throw - Brand New traskw Drivetrain 19 03-01-2009 10:43 PM
short throw shifter lever install help! MPREZD Transmission (AT/MT) & Driveline 14 11-24-2005 04:15 PM
WTB: STi Short Throw Shifter or Cobb Double Adjustable Short Throw Shifter rich22 Private 'Wanted' Classifieds 8 05-05-2004 03:27 AM
Aftermarket Short Throw lever with STI short throw shifter? anti.team Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 02-24-2004 12:57 PM
Found out a short throw shifter wasn't installed in my WRX.. cout Bay Area Impreza Club Forum -- BAIC 5 05-03-2001 05:59 PM
