Welcome to the North American Subaru Impreza Owners Club Thursday December 13, 2018
Old 06-30-2010, 05:38 PM   #126
lcjarrett
Member#: 133814
2008 AW STI
Thanks for a quick respond.
I am going to Weld them.
lcjarrett is offline   Reply With Quote
Old 07-01-2010, 01:54 AM   #127
ozzy370
Member#: 162469
2003 WRX wagon
special sauce
+1 on welding. make sure they are flat before putting the gears on.
ozzy370 is offline   Reply With Quote
Old 07-12-2010, 05:30 PM   #128
lcjarrett
Member#: 133814
2008 AW STI
will do sir....
My question is, Is it really worth it? Are STI Cams going to help out?
please explain.
Thank You
Old 07-12-2010, 06:28 PM   #129
paintbing
Member#: 59388
2003 WRX - Hybrid
I do my own stunts
Originally Posted by lcjarrett View Post
will do sir....
please explain.
Thank You
STI cams have higher lift. Higher lift = more air is able to flow.
More air flow = more HP
But then there is the great debate as to whether STI cams come retarded and AVCS advances to the WRX timing, OR whethere the STI cams are at the WRX timing and AVCS advances to increase timing... I am lead to believe the latter - Only because I measured both my STI cams and WRX cams (using WRX gears) and they were the same.
paintbing is offline   Reply With Quote
Old 07-12-2010, 08:41 PM   #130
John__Gotti
Member#: 70598
The Oil patch, as
fun as it sounds
^STi cams are only retarded if running them with the STi cam gears. When running them with the WRX cams gears there is no timing difference.
John__Gotti is offline   Reply With Quote
Old 07-12-2010, 10:40 PM   #131
lcjarrett
Member#: 133814
2008 AW STI
roger That!!!
Old 10-25-2011, 11:06 PM   #132
rek888v2
Member#: 71287
S202 #387, Type RA
#169 and an 04 STi
Subscribed for ideas when I delete my AVCS.
rek888v2 is offline   Reply With Quote
Old 10-26-2011, 04:51 PM   #133
cowboy_Rob
Member#: 194062
2003 Impreza WRX
So letme get this right on my 04 sti swapped into a wrx I have avcs heads and cams but a non avcs ecu so it's not wired up at all this means my intake cams are both retarded 10 degrees? I'm amazed it runs if that's the case
cowboy_Rob is offline   Reply With Quote
Old 10-26-2011, 04:57 PM   #134
soobaviator
Member#: 115070
2009 DGM LGT Spec.B
08 Audi Q7 4.2 PRM
Your reasoning on the cams is not correct.
The cams are not retarded and they run just fine. Ask the many EJ205 owners, including myself, who run them. Major improvement in mid range and top end compared to S20 cams...
They are not AVCS cams when used in non-AVCS heads. The cams are only retarded if you use them in AVCS heads with AVCS disabled...
soobaviator is offline   Reply With Quote
Old 10-26-2011, 05:06 PM   #135
cowboy_Rob
Member#: 194062
2003 Impreza WRX
I have sti avcs cams, heads, and cam gears. I have avcs solenoids on the engine but they don't have any wiring to them.
Old 10-26-2011, 05:17 PM   #136
soobaviator
Member#: 115070
2009 DGM LGT Spec.B
08 Audi Q7 4.2 PRM
It will still run just fine, it just won't advance. The lift and duration of the cams is unchanged.
In any case thought you were referring to EJ205 heads...
Old 10-26-2011, 07:20 PM   #137
cowboy_Rob
Member#: 194062
2003 Impreza WRX
I know they won't advance but since I have the sti avcs gears does that make then 10 degrees retarded or not?
If sti cams with avcs gears unhooked in a wrx head is retarded why wouldn't it be in mine
Old 10-27-2011, 11:17 AM   #138
rek888v2
Member#: 71287
S202 #387, Type RA
#169 and an 04 STi
I believe they would retard but i need to do further research. This is why Im welding the holes on my Cams and running them on the AVCS Heads with the AVCS Oiling lines removed and the banjo bolt holes plugged with a bolt. Now, when doing this, Ive been told you can run WRX Cam graes insted of the STi ones as well. Dont think that matters too much but I need to do more research.
Old 11-10-2011, 08:24 PM   #139
oldandslowjim
Member#: 259570
Default cams
if you are running avcs cams and avcs heads you need to run the solnids and oil lines to properly lub. the front cam bearings even with plugged cams VERY IMPORTANT or you may sieze the cam in the head
oldandslowjim is offline   Reply With Quote
Old 01-03-2012, 08:42 PM   #140
billimpreza
Member#: 295031
hello.my name is bill and i am from greece.i have wrx heads and wrx cams,but i also have sti cams.i really want your help because now i am closing the engine,and i don't know anything about the edm camshaft specs.can you help me???what lift and duration have the edm wrx cams and what the sti's???witch cam to prefer?
thank you very much
sorry for my bad english
billimpreza is offline   Reply With Quote
Old 02-16-2012, 01:07 AM   #141
dirtslayer
Member#: 242550
2002 impreza wrx wag
olive drab
completely agree.
any long term success with plugging these oil passages? anything more than six months driving?
very curious because the way im seeing the oil passage on the head, if you block the end of the cam gear, you block all bearing lube..
dirtslayer is offline   Reply With Quote
Old 09-09-2012, 08:49 PM   #142
curtisboes
Member#: 280395
04 WRX (STI Swap)
I'm putting a ej 25 long block in my 04 wrx and need to plug these holes even tho iv got sti heads just not running avcs...am I correct on this?
curtisboes is offline   Reply With Quote
Old 09-10-2012, 12:33 AM   #143
dirtslayer
Member#: 242550
olive drab
Depends on where your orig cam sensor was/is? If its on the back by turbo then no, leave avcs cams there.
Old 09-10-2012, 02:06 AM   #144
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
If you have EJ25 heads, you need to find a way to mount the cam sensor for your ECU, as it's different than the sensors used for the ECUs that drive the AVCS heads.
As or the holes, if you have AVCS cam gears you do not block. If you have non-AVCS cam gears you need to block them.
Concillian is offline   Reply With Quote
Old 09-10-2012, 09:22 PM   #145
curtisboes
Member#: 280395
04 WRX (STI Swap)
I have ej35 heads not runnin avcs...I got a cam angle bracket for the sensor...the problem is that the holes arnt plugged and oil is pouring out of the cam into the timing cover...
Old 09-11-2012, 06:27 PM   #146
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
This is really good. I will be building a set of 2.0 heads with sti cams
medamullet is offline   Reply With Quote
Old 09-11-2012, 08:07 PM   #147
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
umm... plug the holes? non-AVCS cam gear = plug the holes.
Old 09-11-2012, 09:23 PM   #148
curtisboes
Member#: 280395
04 WRX (STI Swap)
If I use the avcs cam gears will that block the holes?
Old 10-08-2012, 10:38 PM   #149
Timmy_M2000
Member#: 289514
2003 WRX Sedan
Ralley Blue
Originally Posted by dirtslayer
completely agree.
2nd this. Any follow up?
Timmy_M2000 is offline   Reply With Quote
Old 10-08-2012, 10:43 PM   #150
soobaviator
Member#: 115070
2009 DGM LGT Spec.B
08 Audi Q7 4.2 PRM
I've been running plugged STI cams in WRX heads for more than 2 years. No issues, Billet 20G DD.
How To: Install Evo X seats in wrx/STi xxscaxx Interior & Exterior Modification 172 01-23-2017 11:25 PM
sti cams in 2L heads wickedwrx2002 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-03-2007 06:43 PM
sti cams in wrx heads? ejsportcom Built Motor Discussion 22 06-22-2006 04:34 PM
do sti cams in wrx heads really make that much of a difference? legacy2003 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 01-15-2006 02:31 PM
STI cams in WRX heads=cel??? Davenow Subaru Conversions 0 03-28-2005 02:59 PM
