12-12-2019, 03:16 PM | #1 |
Member#: 168226
RMIC
Vehicle:2000 2.5RSti Coupe 02 Forester L |
Master C's 2000 RSTi Coupe
Hello NASIOC!
I have been a long time member, lurked since 2004 when I bought my 2000 2.5RS coupe and signed up in 2008 when I finally moved over from rs25.com. Most of my build progress is on Instagram but since NASIOC now has image hosting I thought I'd start a thread. Instagram: Chaecker5 I have owned this 2.5RS coupe since 2004 and it has gone through several evolutions: 2004-2006: N/A basic bolt ons, Apexi N1 exhaust, intake, HKS lowering springs 2006-2008: N/A-t build. Started with a small vf11 turbo and variable rate fuel pressure regulator and eventually got up to a TD04 and about 12psi of boost with emanage blue piggyback 2008-2012: built the original EJ251 with forged pistons, STi rods, and custom heads from delta cam. Ended up with a Greddy 18g and emanage ultimate piggyback and eventually had 800cc injectors and a Greddy 25g turbo running 21psi which maxed out my injectors and capabilities of the piggyback. 2012-present: decided to go full STi swap, shaved engine bay, chargespeed body kit, and go after my dream build. Life has got in the way along the journey but I have slowly been building. Now that the thread is started, I will try and find pictures of the older build and share as it progresses. Pictures as it sits today:
12-12-2019, 03:40 PM | #2 |
Member#: 343218
Vehicle:2004 WRX wagon Blue |
I need moar!
12-12-2019, 06:13 PM | #3 |
Member#: 493859
TXIC
Vehicle:06 WRX TD Swapped sorta black-ish |
very cool stuff
Dah... no radiator build? |
12-12-2019, 06:20 PM | #4 |
Member#: 168226
RMIC
12-19-2019, 12:55 PM | #5 |
Member#: 168226
RMIC
Just scored a set of Defi Link gauges in white with green backlight to match the STi 10k rpm cluster I have. Won't be using the tach, but these should look good together.
12-19-2019, 01:09 PM | #6 |
Member#: 110078
Vehicle:02 Bugeye JDM STi OBP BLACK |
I’m really liking what I see here.
12-19-2019, 01:48 PM | #7 |
Member#: 253498
SCIC
Vehicle:02 RSTI MURK'D |
SUCH A TEASE!! Lessssss go Master C!!
just followed you I'm @elcucuy_sti |
12-19-2019, 05:11 PM | #8 |
Member#: 168226
RMIC
01-20-2020, 05:06 PM | #9 |
Member#: 168226
RMIC
Quick update: built a custom bracket setup for the hella horns, designed a fuel filter mount for my AEM fuel filter, got the power steering system from Chase Bays routed, and am currently working on the fuel pump hanger/fuel tank and getting the engine oil cooler mounted/duct work completed.
01-21-2020, 03:44 PM | #10 |
Member#: 25768
RMIC
Vehicle:2003 XONA 9569S 40++ 2.3 slobaru |
Love It!
01-22-2020, 08:27 AM | #11 |
Member#: 450712
Vehicle:04 STi WRB |
Followed you as well man. mine is @OG_Boo.Barusti
Love builds like these. |
01-22-2020, 11:29 AM | #12 |
Member#: 168226
RMIC
01-22-2020, 01:40 PM | #13 |
Member#: 1273
Vehicle:98 Impreza RBP |
following
01-22-2020, 08:37 PM | #14 |
Member#: 2692
TXIC
Well whaddawehave here?... Sub'd
01-23-2020, 12:37 PM | #15 |
Member#: 168226
RMIC
Rear fenders cut, welded, and ready for seam sealer. used stainless rivnuts and hardware for mounting the flares. Final fitment after paint will include a rubber weatherstrip seal around the flare to body mounting surface to seal up any small gaps and prevent rubbing.
01-27-2020, 02:30 PM | #16 |
Member#: 168226
RMIC
AEM fuel filter bracket complete:
01-28-2020, 09:31 AM | #17 |
Member#: 511129
Looks amazing !
01-28-2020, 02:05 PM | #18 |
Member#: 2692
TXIC
Cool, what filter bracket is that?
01-28-2020, 04:34 PM | #19 | ||
Member#: 168226
RMIC
01-30-2020, 10:56 PM | #20 |
Member#: 2692
TXIC
02-13-2020, 04:35 PM | #21 |
Member#: 168226
RMIC
2/13/20 Update:
Finished modifying custom made master cylinder brace to mount AEM fuel filter and Apexi super grounding stabilizer. Started on cleaning up the fuel tank which includes: degreasing, removing and replacing all hoses, delete EVAP system, and upgrade fuel pump hanger. Pics: |
02-13-2020, 09:56 PM | #22 |
Member#: 253498
SCIC
That fab work on the rear pitch mount though, lol JK MC. Diggin your work.
02-25-2020, 04:49 PM | #23 | |
Member#: 168226
RMIC
Got my Chase Bays power steering reservoir and coolant overflow reservoir mounted up this last weekend. Ordered some tools to flare the 5/16 fuel lines and re-bend them where I want them. |
02-25-2020, 09:25 PM | #24 |
Member#: 253498
SCIC
That thing is nice... Do you know Chase?
02-26-2020, 11:02 AM | #25 |
Member#: 168226
RMIC
