Welcome to the North American Subaru Impreza Owners Club Friday August 17, 2018
Old 07-16-2018, 04:59 PM   #1
Max2003WRX
Member#: 487816
2003 Impreza WRX
WR Blue
Default Bigger/ better boost
So I'm still pretty new to cars, but I've learned a lot over the past couple months. I have an 03 wrx and I was wondering if there was a way to use my COBB accessport to make my turbo spool sooner and/or increase the maximum PSI. Right now, I max out at around 11 PSI when in 4th gear at 6000 rpm. Any speed below 60 MPH and I get around 9 PSI boost at best. What can I do to get more boost??? (I already have an SPT intake and exhaust, nvidia up and down pipes)
PS - I might look into a new turbo. How much are they and what would you recommend?
Max2003WRX is offline   Reply With Quote
Old 07-16-2018, 07:23 PM   #2
CarmelValleyWRX
Member#: 453872
2005 wrx wagon
48w
you need to tune your car so it stops knocking and then you can get the stock 14.5psi of boost at least. then worry about turning up the boost once its running half way descent. a "stage 2" map would probably get it running pretty well.
CarmelValleyWRX is offline   Reply With Quote
Old 07-16-2018, 07:55 PM   #3
Max2003WRX
Member#: 487816
2003 Impreza WRX
WR Blue
So do I just make a map of my current setup and send it to COBB and ask for a stage 2 map? what are the drawbacks of this?
Old 07-16-2018, 08:16 PM   #4
CarmelValleyWRX
Member#: 453872
2005 wrx wagon
48w
well with the mods you have the engine is over boosting, which means the turbo is spinning faster than expected. the intake you have is making it run lean. both of these things cause "knock" which is when the air and fuel kind of explode uncontrollably which is not good. the car detects it and tries to save it self by limiting your boost and reducing ignition timing. that is why you only have 8-10psi right now. a stage 2 map is already done and you just load it onto the cars ecu. it will adjust the ignition timing and bring the turbo back under control. you should take the intake off and put the stock air box back on. it works great. you can use an accessport or a tactrix to flash a stage 2 or a custom map.
Old 07-16-2018, 08:37 PM   #5
Brother EddieJ.
Member#: 181617
2004 wrx
6speed/ 330whp/ 300wtq
https://forums.nasioc.com/forums/sho...d.php?t=533787
Read this ^^^^^^^ all of it. Stay to the noob section. Read their stickies, all of them. Read way way more, post way way less. Any question you have has been asked and answered. Trust me everything you could ever want to know is here, just search.
Brother EddieJ. is offline   Reply With Quote
Old 07-17-2018, 07:27 AM   #6
Max2003WRX
Member#: 487816
2003 Impreza WRX
WR Blue
Thank you
Old 07-23-2018, 01:21 AM   #7
BugeyeJay
Member#: 445146
I think you should check for vacuum leaks. In my experience when you overboost, you get boost oscillation but when you have a vacuum leak you get slow spool and under boost. Your car is fine with the SPT intake. They were sold with stock cars and if Iím not mistaken keeps the stock MAF diameter. The stage 2 tune should really wake the car up
BugeyeJay is offline   Reply With Quote
Old 07-26-2018, 12:08 AM   #8
Max2003WRX
Member#: 487816
2003 Impreza WRX
WR Blue
checked for vacuum leak when replacing my valve cover gaskets, sure enough there was a leak. Hitting target boosts now, thanks!
Old 07-27-2018, 12:16 PM   #9
contaminatrix
Member#: 435611
2002 SG5-2.0-XT-JDM
45A, originally 18L
where was the leak exactly if you may? it may help someone in future. thanks.
contaminatrix is offline   Reply With Quote
