Welcome to the North American Subaru Impreza Owners Club Thursday January 17, 2019
Old 06-09-2007, 10:12 PM   #51
AWDBoost
Member#: 33082
V7 EJ207
Prodrive GDB
turbo studs to Downpipe?
AWDBoost is offline   Reply With Quote
Old 08-16-2007, 12:48 AM   #52
Daggah
Member#: 152077
2014 Subaru BRZ
World Rally Blue
Hey, I just received a stock air intake that I purchased off a member here and he didn't include any of the bolts and nuts I need.
Does anyone know the size of bolt/nut/washer I need for:
A) I need a nut for this bolt
B) I need washers + bolts
C) I need washers + bolts
Daggah is offline   Reply With Quote
Old 08-16-2007, 08:00 PM   #53
Daggah
Member#: 152077
2014 Subaru BRZ
World Rally Blue
bump for great justice
Old 10-17-2007, 10:11 PM   #54
el_guapo
Member#: 132038
funk er chicks
serious bidness
Thread just helped me out a bunch, bump and thank you!!!!!!!!!
el_guapo is offline   Reply With Quote
Old 10-18-2007, 12:37 AM   #55
prometheum
Member#: 92003
04 bicycle!
Originally Posted by Daggah View Post
Hey, I just received a stock air intake that I purchased off a member here and he didn't include any of the boM10 x 1.25 by 41mmlts and nuts I need.
pretty sure its an m6*1.25...thats the same size as the one that holds on the windshield washer fluid bottle, if its too small try an m8*1.25
turbo studs to the down pipe are the same as up pipe studs m10 x 1.25 by 41mm
prometheum is offline   Reply With Quote
Old 10-18-2007, 02:58 PM   #56
DirtstyleWRX
Member#: 18212
Originally Posted by specialev View Post
M6X1.0 on the DP heat shield.
Exactly what I was looking for...
DirtstyleWRX is offline   Reply With Quote
Old 12-31-2007, 05:01 PM   #57
Scion
Member#: 56333
2002 wrx
my 02 wrx motor mount nut size?
Scion is offline   Reply With Quote
Old 08-19-2008, 08:16 PM   #58
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Updated 1st post with info from others in this thread. Also added M6x1.0 for the fender where it mates to the chassis inside the engine bay.
jblaine is offline   Reply With Quote
Old 11-12-2008, 05:28 PM   #59
andrewt461
Member#: 70647
2004 WRX
Asked this in a separate thread - but see that there is an individual thread for this info -
Can yall add the bolt size for the 3x 10mm bolts that connect the black PCV line to the intercooler?
andrewt461 is offline   Reply With Quote
Old 11-12-2008, 05:32 PM   #60
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Originally Posted by jac04 View Post
No, it's not.
Yes it is at least for aftermarket units. I had to find buy a Tap for it recently and it wasn't easy to find.
Old 11-13-2008, 12:29 PM   #61
andrewt461
Member#: 70647
2004 WRX
To answer my own question - these bolts are M7 by 1.0 thread bore or whatever.
And they are 15mm long I believe. (Shop only had 20mm, so I had to use washers)
Old 11-13-2008, 12:49 PM   #62
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Andrew, I think you grabbed an M6 bolt out of the M7 container unknowingly. Or something else that I cannot figure out.
M6 fits perfectly (just tested)... and 15mm is super overkill length.
Old 11-13-2008, 12:59 PM   #63
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Old 11-13-2008, 01:10 PM   #64
gtfaded
Member#: 142322
2002 wrx
wrb
torqe specs are always nice too
gtfaded is offline   Reply With Quote
Old 11-13-2008, 02:47 PM   #65
andrewt461
Member#: 70647
2004 WRX
M6 doesn't fit in mine - was too small (and this is for a brand new TMIC - so the threads are fresh). I tried this w/ brand new M6's at the store. M7 is the only thing that fit perfectly.
M7 is what fits for this car at least.
maybe the size changed between 2002 and 2004...., tho that'd be odd
Old 11-13-2008, 03:12 PM   #66
Wrx_Fan_0717
Member#: 152080
6266 Precision'd Big
Cam'd 2.55l 6spd Bugeye
Awesome thread, Subscribed*
Wrx_Fan_0717 is offline   Reply With Quote
Old 08-16-2009, 12:57 PM   #67
batmobile2
Member#: 220602
1995 wrx turbo 2.0
416 blue
Default front hub stud replacement
Help, hi guys, anyone know the procedure for replacing the hub studs, the previous owner of my little beatsie kindly crossed one of the threads,
any advice gladly welcomed,
Dave H
batmobile2 is offline   Reply With Quote
Old 11-11-2009, 10:14 PM   #68
soob noob
Member#: 220158
02 bugeye
medamullet tuned
size for the bolts that hold the turbo heat shield on?
thanks
edit i need the thread pitch if there was any confusion
thanks again
soob noob is offline   Reply With Quote
Old 01-12-2010, 01:44 PM   #69
02silver bullet
Member#: 224258
I also need the same thing..
02silver bullet is offline   Reply With Quote
Old 01-12-2010, 01:46 PM   #70
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Motor mount studs/nuts are M10x1.25
Old 01-12-2010, 10:24 PM   #71
vien
Member#: 221538
2003 wrx/ylw wheels
darkness.................
subscribed
vien is offline   Reply With Quote
Old 03-09-2010, 08:59 PM   #72
illmatic
Member#: 3536
2017 SWP BRZ PP, FXT
2002/2003 AW/PSM WRX
Picked up a new 2003 Project WRX and need to return the exhaust manifold back to stock. Just wanted to verify M10 x 1.5 x 40 should be fine?
http://www.boltdepot.com/product.asp...&cm=22&cd=1329
illmatic is offline   Reply With Quote
Old 03-09-2010, 10:20 PM   #73
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
The header to cylinder head studs are M10x1.25.
Old 03-23-2010, 02:43 PM   #74
fastfive09
Member#: 169597
2011 WRX Sedan
Anyone know what size the bolt that attaches the alternator cover on the left side is?
I have the nut for the right side already.
fastfive09 is offline   Reply With Quote
Old 04-12-2010, 10:52 AM   #75
hunter15
Member#: 151168
99 OBS
anyone have bpv bolt size?
hunter15 is offline   Reply With Quote
PCV line -> Intercooler bolts - Bolt Size? andrewt461 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-14-2011 05:40 PM
Bolt size for bolt on exh mani heat shields? djoye Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-08-2007 02:24 PM
Oil Cooler Bolt Bolt Size??? Drink Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 09-11-2006 01:23 PM
Bolt size/thread pitch for seat bolts? anti.team Interior & Exterior Modification 1 09-30-2004 11:42 AM
Bolt size for airbox? blaster88 General Forum Archive 3 02-13-2001 04:49 PM
