Welcome to the North American Subaru Impreza Owners Club Tuesday July 23, 2019
Old 02-26-2005, 02:06 AM   #1
sacks-wagon
Member#: 71402
04 WRX
Default Cusco Lower Arm brace = Hack The Sub frame
I just got my v.II cusco lower arm brace installed on my car. The car feels like it has made an imporvement in handling comapred to running with the stock sub frame on there. It just seems to dive into turns harder adn the front suspension feels like more of a unit. Anyways since the bar really provides no crash portection to the front portion of the car, i was wondering if there was a way to hack teh legs off the stcok sub frame and put it back on to provide some crash protection.
TIA
sacks-wagon is offline   Reply With Quote
Old 02-26-2005, 02:40 AM   #2
darksands
Member#: 75122
2005 Impreza WRX
Crystal Gray
I didnt knwo you had to remove the sub fram U shaped frame to install it. Can you have both on. I think Ive seen it done.
darksands is offline   Reply With Quote
Old 02-26-2005, 02:42 AM   #3
thesmokingman
Member#: 17751
Removal of the subframe is not needed.
thesmokingman is offline   Reply With Quote
Old 02-26-2005, 07:53 PM   #4
ashumo
Member#: 51318
89 SVX Syncro
sacks-did you really remove your subframe?
ashumo is offline   Reply With Quote
Old 02-26-2005, 08:31 PM   #5
sacks-wagon
Member#: 71402
04 WRX
Yes i dide for weight reduction etc. So thats why i was wondering if you could chop the legs off and still have some front protection.
Old 02-26-2005, 09:34 PM   #6
ashumo
Member#: 51318
89 SVX Syncro
did you consider gt spec subframe?
do you have a full interior? stock seats? you can kill some serious weight before you leave the cockpit.
you can hack as much of it as you want and bolt it up. protection who knows until you smash it.
Old 02-26-2005, 09:48 PM   #7
sacks-wagon
Member#: 71402
04 WRX
Yeah so say if i just hacked the arms like right before the start of the wheels tehre would be enough mounting points to put it on. Also the entire sub frame will fit with the cusco ver II lower arm brace/bar thing? Maybe ill just run it with the tthing on all teh time then swap it for runs/ track days. And yes i did consider the do-luck and the gt-spec both are kind of out of my price range. Anyone got any pics of someone running with the sub frame and bar?
TIA
Old 02-27-2005, 03:09 AM   #8
ashumo
Member#: 51318
89 SVX Syncro
Enough mounting points to put part of the subframe on? yes subframe and ver 2 brace fit. i have my subframe and cusco v2 bar on. the gt spec subframe is a good price considering do-luck price. the do luck piece looks super solid since its one piece. are you trying to cut weight here? or tune your suspension?
Old 02-27-2005, 03:10 AM   #9
ashumo
Member#: 51318
89 SVX Syncro
gt spec webpage has sub frame pics, i have pics of my v2 brace and subframe on, if thats what your talking about wanting to see????
Old 02-27-2005, 03:16 AM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
The Cusco v2 lower arm bar is designed to be installed with the subframe......as a matter of fact if the subframe isn't used with the v2 bar, the foreward attach points of the v2 bar hang in space by ~1 1/4" or so and require spacers to attach properly....
Old 02-27-2005, 03:55 AM   #11
oldmansan
Member#: 17877
2007 Exige S
Storm Titanium
Default Right,
and Scotty and I used our Whiteline ALK aluminum spacers to make up the difference. Ditch the subframe if you care about weight. No difference in stiffness (that I could tell).
San
oldmansan is offline   Reply With Quote
Old 02-27-2005, 05:37 AM   #12
ashumo
Member#: 51318
89 SVX Syncro
how much does the subframe weight?
Old 02-27-2005, 08:10 AM   #13
el~sharko
Member#: 29735
2011 JSW TDI - DSG
2008 EVO X MR
approx. 25lbs
el~sharko is offline   Reply With Quote
Old 02-27-2005, 01:46 PM   #14
sacks-wagon
Member#: 71402
04 WRX
Im gonna put the sub frame on today.
Arm Bar, Lower Brace, Lower Arm Brace?!?!? impreza_GC8 Brakes, Steering & Suspension 2 07-30-2007 01:25 AM
Cusco Lower Arm Brace for STi rich728 Brakes, Steering & Suspension 47 09-11-2005 11:51 AM
Cusco lower arm brace VS ebay H brace? realwomble Brakes, Steering & Suspension 11 05-29-2005 07:01 PM
Cusco lower arm braces scotter Brakes, Steering & Suspension 2 05-09-2002 10:30 AM
Cusco front lower arm brace Dirty Underwear Gang Brakes, Steering & Suspension 3 08-29-2001 04:21 PM
