04-08-2013, 08:25 AM | #1 |
Member#: 345962
NESIC
Vehicle:2012 WRX Sedan WRB |
Stage 2 WRX transmission problems?!
Hey guys i had a question about whats going on with my 2012 stage 2 WRX. it happens when cornering under hard acceleration and also when i punch the gas in first or second lastly It seems when i floor it in either 2nd or 3rd and let off at about 5.5k RPMS, it feels like my transmssion shakes and clunks?! i can feel the tranny or motor like clunk back and forth. its only 1 or 2 big clunks and it makes you cringe because it sounds awful haha. does this mean my transmission or motor cant hold the power of my stage 2? thoughts and suggestions would be awesome guys thank you!
04-08-2013, 09:03 AM | #2 |
Member#: 245218
South East
Vehicle:2013 STI Limited |
Are you pushing the clutch in when you let off that gas at that RPM? If not then DERP.
04-08-2013, 10:47 AM | #3 |
Member#: 345962
NESIC
I don't touch the clutch unless I'm shifting and if I'm shifting then i don't have this problem. It's only when I reach high RPM's and then let off the throttle.
04-08-2013, 11:19 AM | #4 |
Member#: 3687
MWSOC
Vehicle:MY99 GF4 JDM 6spd NF Performance |
You should inspect the tranny mounts, engine mount nuts.
04-08-2013, 11:52 AM | #5 |
Member#: 345962
NESIC
Sense I do not know what I'm inspecting should I just get this looked at, at a auto shop?
04-08-2013, 01:00 PM | #6 |
Member#: 100300
MWSOC
Vehicle:06 WRX CGM |
I asked a similar question. My engine bucks hard if I let off the gas near redline, especially if its a partial let off. One big buck. I was told pitch stop. Upgrade that and maybe the stuff happen g to you will reduce or disappear.
04-08-2013, 01:20 PM | #7 |
Member#: 130990
NWIC
Vehicle:06 Red Ltd.Wagon Dom 1.5xtr JJ tuned |
Stock engine mounts. Upgrade them and you will have little if any bucking. It makes a huge difference, believe me.
04-08-2013, 01:35 PM | #8 |
Member#: 345962
NESIC
Whats pitch stop? And Dave d did you have this similar problem or something?
04-08-2013, 01:46 PM | #9 | |
Member#: 284792
RMIC
Vehicle:2011 STI Blurple |
04-08-2013, 03:22 PM | #10 |
Member#: 345962
NESIC
is this a serious issue? are my motor mounts likely to break or can i ignore this?
04-08-2013, 04:21 PM | #11 |
Member#: 100300
MWSOC
Its probably only serious if they break and you don't replace them. Probably not very serious to break one, just don't make a habit of it or anything. Look under your intercooler. There should be a brace there connected to the firewall. That is the pitch stop.
04-08-2013, 08:33 PM | #12 |
Member#: 345962
NESIC
alright cool i appreciate the help ill look into getting a new pitch stop/tranny/motor mounts!
08-09-2013, 05:03 PM | #13 |
Member#: 345962
NESIC
hey guys im still worried about this clunking noise. I brought it to my local subaru dealership where i bought my car and i had the head mechanic look at my motor and transmission mounts, while i waited there for over 2 hours he came back and said that they were not stressed or in bad condition at all and that they looked fine. Does this mean that those are now out of the question now for being my problem? i want to get this fixed because i cant really do any spirited driving without worrying about the clunking noise.
08-09-2013, 05:06 PM | #14 |
Member#: 345962
NESIC
i will try and explain the problem again in better detail. Its a hard clunk underneath my car i cant tell if its the motor and tranny but its a heavy clunk. the noise can happen almost at any range in the rpms for Ex.) if im in first gear i can punch the throttle for a second to bring the rpms to like 3-4 and let of quickly and it will clunk. going around corners in high RPMs it will clunk, letting off the gas at high rpms to slow down without the break it will clunk as well. just trying to put as much detail as possible. Looking for some help here, i dont want to buy the mounts and have that not fix the problem. thanks guys
08-12-2013, 12:26 AM | #15 |
Member#: 278744
NWIC
Vehicle:06 WRX WRB |
Like the previous people have said, replace the motor mounts and possibly the pitch stop. I have the same issue except this is on an 06 wrx. Saving up to get those parts. Let us know how everything turned out once you have replaced those parts
08-12-2013, 07:32 AM | #16 | |
Member#: 197384
NESIC
Vehicle:2006 WRX Ltd OBP |
08-12-2013, 08:54 AM | #17 | |
Member#: 123843
NESIC
Vehicle:2016 STI LTD CWP Let LED's light your way! |
OEM Liquid-filled engine mounts, and a soft-durometer rubber for both the engine mounts and the transmission mount. Solution: Replace with Subaru Group-N engine mounts and transmission mount. Buy parts package from TiC: http://turninconcepts.com/product_in...oducts_id=1083 PS: I'm not 'guessing' on this one, or 'think I know'; I do know. |
08-28-2013, 03:20 PM | #18 |
Member#: 345962
NESIC
Update: Bought a STI Group N Transmission mount and a Kartboy pitchstop ill update you guys to see if those have stopped the problem after i install them.
08-28-2013, 03:21 PM | #19 |
Member#: 345962
NESIC
08-28-2013, 04:55 PM | #20 |
Member#: 305615
Vehicle:2013 WRX Limited Sdn SWP |
Let me know how this works out...I'm thinking about doing the same to my '13 WRX.
09-06-2013, 09:37 PM | #21 |
Member#: 345962
NESIC
Update:
i installed a new Transmission mount/ pitchstop/ shifter bushings and all the clunking has gone away and the car is so much more responsive and quicker and is a lot faster, the only think is that the NVH is very bad. i can hear so many random noises here and there and i dont know if its normal or not. |
09-09-2013, 11:02 AM | #22 |
Member#: 207614
South East
Vehicle:2008 WRX Hatch VF52d SSM |
Perfectly normal. I doubt the car is any faster, but absolutely more responsive. Enjoy that feeling, you won't be able to stop replacing soft bushings and mounts now!
09-17-2013, 01:00 AM | #23 |
Member#: 343621
MWSOC
Vehicle:2012 Impreza WRX Dark Metallic Gray |
I have some Group N engine mounts for sale!
But seriously, I upgraded to the Group N transm ount and the Torque Solutions pitch stop mount and 90% of my "bucking" issues are gone. |
09-17-2013, 08:06 PM | #24 |
Member#: 345962
NESIC
i fixed the NVH problems it was a couple things rubbing like the heatshield.
10-02-2013, 04:27 AM | #25 |
Member#: 369855
check clutch
