09-07-2007, 11:18 PM | #1 |
Member#: 115154
MWSOC
Vehicle:2005 Outback XT White on grey |
WRX control arms on a BE...hmm
So I've been reading this:
http://scoobymods.com/forums/showthr...1280#post21280 And got to thinking...pick up some wrx sedan control arm takeoffs, change out the bushings (the front is $46 and the rears will be group N ones I bought from ten80 ), and the front track has just been increased by 20mm for under $200 and increased negative camber from the geometry change. How would that affect the handling do you guys think? It should help reduce understeer and better turnin and sharper steering response (combination of the stiffer bushings, neg camber, and wider track)...at least that's what I'm theorizing. I'm also thinking that the negative camber should prevent any rubbing from the fender with the wider track too...but it may be anyone's guess. Right now I'm just bouncing this idea around. Opinions, questions, theories? |
09-10-2007, 03:16 PM | #2 |
Member#: 115154
MWSOC
Well, I think I'm going to try this out. I've asked a couple of wrx wagon owners about the extra stance and it seems to work out pretty well with not a lot of downsides.
Time to source me some used control arms |
09-10-2007, 06:43 PM | #3 |
Member#: 36735
MWSOC
Vehicle:99 GF8 Impreza 2.0 2= 1998 BD + BK Legacy GT |
Should be an interesting mod - you should have plenty of room under the fenders too...
09-22-2007, 06:51 PM | #4 |
Member#: 97745
MWSOC
Vehicle:2005 OBXT 5spd red 05 OB Lmited Black |
Keep us updated,Sounds interesting.
07-18-2008, 09:23 AM | #5 |
Member#: 115154
MWSOC
Updating this:
It didn't go quite as planned, but the control arms are in there Even at 0 camber, I didn't have problems rolling on 225's and a 48 offset wheel (7.5" width). I have about 3k miles on this setup and so far no transaxle issues. I can't say about the wider track being the only contributor to the handling changes, but it is much more stable during high speed turns, turn-in's much more responsive, and it's not as tail happy as before (unexpected). |
07-18-2008, 10:54 PM | #6 |
Member#: 74907
NWIC
Vehicle:98 cam'd EJ251 Wrx Tranny,slowr than ish |
You might not have axles problems now, but there is a reason sedan and wagon axles are different. I would probably throw some sedan axles in there just to be on the safe side.
Thats interesting that the wider front track you now have doesn't make the rear step out a little easier... ~Josh~ |
07-22-2008, 12:19 AM | #7 | |
Member#: 115154
MWSOC
The multi-link rear and wheel setup may have something to do with different handling characteristic that I've heard from impreza owners that went with the wider front track. |
07-21-2008, 05:35 PM | #8 |
Member#: 1964
RMIC
Vehicle:2012 Fit Sport 5MT Orange Burst |
Neato.
07-21-2008, 06:21 PM | #9 |
Member#: 73684
NWIC
Vehicle:2012 4Runner |
Story on the headlights?
04-19-2011, 09:31 PM | #10 |
Member#: 115154
MWSOC
Just to update this. almost 3 years later and over 32k miles, still doing fine on the original axles, hubs, bearings (though I did have to replace one bearing/hub because the hub cracked from attempting to remove a stubborn ball-joint).
Similar Threads | ||||
I bent my aluminum control arm. Can i put 02 control arms on for now? | ki11switch | Brakes, Steering & Suspension | 4 | 07-14-2009 12:39 PM |
OEM Alum. Front Control Arms on '04 WRX? | hakkenpepper | Brakes, Steering & Suspension | 12 | 05-29-2006 03:23 PM |
How many of you with aluminum control arms on your WRX | modvp | Brakes, Steering & Suspension | 12 | 01-02-2004 01:37 PM |
EJ20 X-member, do I need to go with WRX control arms on my GC8. | underground-mpyre | Subaru Conversions | 8 | 09-25-2003 12:39 PM |
Identical struts/ control arms on 02+ WRX & pre01 Impreza? | pillaka | Brakes, Steering & Suspension | 1 | 02-24-2003 07:02 PM |
