05-15-2015, 03:38 PM | #251 |
Member#: 236475
BAIC
Vehicle:2002 WRX Black |
05-15-2015, 03:40 PM | #252 |
Member#: 166324
NESIC
No, I haven't. I figured since it's in my Subaru maybe Subaru people have dealt with this.
05-15-2015, 03:51 PM | #253 |
Member#: 166324
NESIC
Just registered and tried making a post. Guess it didn't work though, couldn't find it after I posted.
05-15-2015, 04:02 PM | #254 |
Member#: 236475
BAIC
It's been a few year since I signed up for RomRaider but since you just registered they might require a moderator to approve your first post.
05-15-2015, 04:17 PM | #255 |
Member#: 166324
NESIC
Yes, I think that's what it is.
I'm hoping someone around here can help. |
05-16-2015, 01:49 PM | #256 |
Member#: 166324
NESIC
So with everything I was trying yesterday my car was never running (didn't really think it needed to be) so today I started it up and tried connecting to the ecu. Still nothing.
Romraider boots up perfectly, click logger and that boots up perfectly (as you pros would know, without the correct definition and xml files it will not) yet still cannot connect to the ecu, ughh. |
05-20-2015, 07:32 PM | #257 |
Member#: 421614
Vehicle:2006 WRX STI Aspen White |
When using the latest RomRaider (0.5.9), if I open an image and then save to a new file without making any changes to the original image, there still seem to be some other random changes within the new ROM file (did a binary compare with BeyondCompare program). RomRaider's "ROM Compare" tool will say both files are identical. When I open either file with RomRaider, it says "Checksum disabled". Does anyone know exactly what these other random changes are when saving a new file via RomRaider? I guess I can post on their forum but there seem to be more responsive people here.
Basically, I'm reluctant to flash a new ROM image that contain unexplained changes. Last edited by theongreyjoy; 05-20-2015 at 07:41 PM. |
05-21-2015, 07:35 AM | #258 | |
Member#: 70395
05-21-2015, 08:05 AM | #259 |
Member#: 166324
NESIC
I have Ecuflash installed and working as well.
In RR the COM button doesn't show any options though. When I click it there's nothing there. |
05-21-2015, 11:02 AM | #260 |
Member#: 70395
And the computer is recognizing the Tactrix?
05-21-2015, 04:38 PM | #261 |
Member#: 166324
NESIC
Yes, As soon as I plug in or unplug I get the sound effect.
07-25-2015, 07:51 PM | #262 |
Member#: 426590
Vehicle:2007 Forester XT AT. Black |
Air pump code reflash
New to the forum.. I have done a ecu reflash with tactix. Selected all the DTCs that I wanted to trigger and left all the secondary air pump codes unchecked and reflashed. After two or three drive cycles I get p0410. At first I figured I must of mistakenly selected it. Went through the reflash again making sure I didn't miss anything. Still p0410 returns. Please help what am I missing?
07-26-2015, 01:09 PM | #263 | |
Member#: 236475
BAIC
-Mike Tactrix |
08-24-2015, 10:50 PM | #264 |
Member#: 357613
RMIC
Vehicle:2006 Forester Steel |
10-01-2015, 05:22 PM | #265 |
Member#: 206074
11-23-2016, 12:54 PM | #266 |
Member#: 458215
Vehicle:2015 Impreza Sport P |
I've been searching all over and even asking around with no luck.
I cannot read due to, what I think, not being able to "choose car" (2015 2.0 Impreza Sport Prem). Are there updated instructions out there? -PLEASE! Point me in the right direction, reply, or PM me. What am I doing wrong? Do I load the new definitions? -These instructions are fairly old. I see my car (impreza 2.0) in the original Subaru folder but not in ECU Flash when choosing my car. |
11-23-2016, 05:56 PM | #267 | |
Member#: 392151
11-23-2016, 05:58 PM | #268 |
Member#: 458215
Awesome! I'm glad I started bugging people. I will try it soon.
11-30-2016, 10:49 AM | #269 | |
Member#: 458215
I'm currently in the works (job/school/time needs to match up)of verifying install to make sure it's not just a placebo affect that I feel. I appreciate your suggestions and help through youtube and here! |
04-20-2017, 12:18 AM | #270 |
Member#: 465558
Vehicle:1998 Impreza Outback green |
Someine please help.
I have a 98 impreza outback 2.2L N/A and I am trying to find a way to tune it (write to the ECU) short of buying or having access to the factory Soob software. Is this even possible? I will be adding a Turbo soon @ 6-7 lbs boost and would like to know how I can accommodate this without a piggyback or full ECU. I could tolerate a piggyback, but prefer to have access to timing and other variables.
Thanks in Advance, Tony |
04-20-2017, 12:25 PM | #271 |
Member#: 236475
BAIC
Hey Tony,
Cool project. I used to have a 99 OBS myself. There is no good tuning solution for these older ECUs. I believe EcuTek made something long ago but there really isn't any product currently that will allow you to reprogram your Hitachi/Jecs ECU. Dealership software will not allow you to custom tune the ECU tables to compensate for a turbo being bolted on. You might just want to do what I did when I started working at Tactrix, buy an older WRX Good luck! -Mike Tactrix |
04-20-2017, 01:10 PM | #272 |
Member#: 182415
Vehicle:1999 RS Aspen White |
This is opensource for limited non-turbo ECU's, nice software and dongle. More expensive than Romraider/Tactrix but theres only a few people developing it
http://www.rs25.com/forums/f105/t227...ce-thread.html |
04-20-2017, 04:26 PM | #273 |
Member#: 236475
BAIC
Hey, that's a pretty cool project. I hadn't heard about that. I'll point people in their direction as I get a couple requests a month for support on the older Jecs ECU cars. There is this project in France for turbo (non-USDM) vehicles of that vintage, but they don't support NA vehicles.
http://eculabs.com I've tried to talk them in to adding support but no go so far. -Mike Tactrix |
04-21-2017, 12:38 AM | #274 |
Member#: 34361
Vehicle:04.7 STI WRB IG @got2boostit2 |
Subscribed, thanks.
04-26-2017, 05:08 PM | #275 |
Member#: 376197
SWIC
Vehicle:2014 WRX Pearl white |
Help? Contribution willing via paypal
Hi! Trying to get ecuflash to communicate with 06 wrx. Previous owner had removed obd2 from dash location, possibly to connect aftermarket system or tuner. I have some experianc using ecuflash and evoscan on previous car"evo8". Current problem is my ecuflash will not display the *read, write,test write to ecu. I have java, I have reloaded ecuflash, and I have tried different laptop. Anyone ready to kick my ecu in the toosh and help me pull the
romraider/ecuflash? | weaponstroop | Open Source Reflashes | 14 | 03-23-2020 08:27 PM |
reading logs - FAQ or getting started guide? | jmc9809 | Newbies & FAQs | 2 | 08-05-2005 06:40 PM |
I want to get started racing! Where to start? | wayne_rx | Motorsports | 27 | 12-23-2004 03:00 AM |
Auto-Xing Newbe, How to get started? | Ed_RS | New England Impreza Club Forum -- NESIC | 7 | 01-31-2001 11:34 AM |
how to get started | jjp | New England Impreza Club Forum -- NESIC | 5 | 11-09-2000 06:26 AM |
