10-10-2008, 05:32 PM | #1 |
Member#: 190226
Walbro pump install turned sour
Well i tried to install a walbro 255 into my 2002 wrx--- everything went smooth except now my fuel level gauge doesn't work and is throwing a CEL---
What side does the float go on of the metal division you see when working on it?? It was on the left first, nothing. Then i put it on the right, nothing. What is wrong?
10-10-2008, 06:34 PM | #2 |
Member#: 150394
Vehicle:2007 WRX sedona red |
Improperly grounded?
Just a random guess, Theres not a whole lot that can go wrong with a installation of a fp.....unless your smoking while doing it. |
10-10-2008, 07:06 PM | #3 |
Member#: 185169
NWIC
Vehicle:07 sti black |
seems the only reason your gauge wouldnt work at all is if its a improper connection in the wiring, also just check your float to see if it slides without any restrictions
10-10-2008, 07:17 PM | #4 |
Member#: 190226
good suggestions folks, sent me in the right direction. Some how my bob lever got turned around and the thing wasn't even making contact. I must have done it while installing it and not seen it. I fixed it but taking the bob up and over the top where there is less resistance, took a flashlight while reinstalling to check if it was still continuous--- sure is..
Fixed-- no cel after ecu reset Does our cars make it run on less gas when we get really low on gas?? My bov was making wimpy whoosh's while this was going on--- after I fixed it the whooshes were back to normal. Tip--> Water washes out gasoline out of your eye. If you wash it out quick enough, you wont burn.**(edited later that night, eye hurts again might be going to ER to get some good drops or some kind of flush) That bad. Use a fan too unless you want to get reallly reallllly high on fumes. Maybe even pass out---yes try to leave as little of gas in there as possible. I did mine with a little below half of a tank and was alright WOW i love this fuel pump... it runs so much better now-- for some reason it even shifts smoother---???? haha no smoking while doing this FP-- grandfather came out to check on me and he about lit a cig--- i was like "noooooooooooooooooooooooooooooooooooooooooooo " you'll blow me up... He replies-- we dont have enough insurance on you to do that yet LMAO i love gramps he tried to blow me up hahahah This was seriously the most chaotic FP install i've heard of. Almost blown up, and gas in my eye. On top of installing, uninstalling--3 times trying to figure out wtf was wrong with the gauge. 4-5 hours total time. roflmao *----[ xxxTNTxxx ] Last edited by Skoloseven; 10-10-2008 at 08:44 PM. |
Walbro pump install questions. | udelslayer | Engine Management & Tuning | 15 | 10-10-2009 12:43 PM |
Fuel gauge misreading after Walbro pump install | sanovichleo | Service & Maintenance | 1 | 08-03-2009 02:52 PM |
WTB: Walbro Pump Install Kit | golf97 | Private 'Wanted' Classifieds | 16 | 02-20-2007 06:25 PM |
walbro install, pump wont turn-on? | SnowWhiteWRX | Newbies & FAQs | 43 | 02-10-2007 07:50 PM |
Walbro pump install | Imprezav | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 9 | 07-13-2006 10:24 AM |
