Welcome to the North American Subaru Impreza Owners Club Monday July 16, 2018
Old 08-02-2004, 10:38 AM   #1
dubba you are ex
Member#: 59591
$100 Up/Downpipe
Installs PM me!!!!!!!!!!!
Default Will a Cobb Stage 2 work with a Catted Downpipe?
I know the Stage 2 map is designed for a catless up pipe and down pipe. I'm going to get a catless up pipe but have to get the catted down pipe because of emissions. Will the ECU adapt?
dubba you are ex is offline   Reply With Quote
Old 08-02-2004, 10:44 AM   #2
mrbigisbudgood
Member#: 54378
2013 Mazdaspeed 3
Yes.
mrbigisbudgood is offline   Reply With Quote
Old 08-02-2004, 10:53 AM   #3
Cole
Member#: 64219
2011 Outbackness
2008 Legacy NA Hellastock
Sure. Cobb sells catted and non versions of their dp
Cole is offline   Reply With Quote
Old 08-02-2004, 11:09 AM   #4
dubba you are ex
Member#: 59591
$100 Up/Downpipe
Thanks. I wanted to go with Helix.
Old 08-02-2004, 11:49 AM   #5
Nikko
Member#: 54795
2013 WRX Hatchback
Ice Silver Metallic
Yeah, you should be alright if you go with a catted performance DP and reflash to stage 2. Also, AFAIK you don't necessarily have to have the up pipe gutted. They just specifically say to have a aftermarket DP that has a larger dia. Good luck!
Nikko is offline   Reply With Quote
Old 08-02-2004, 01:59 PM   #6
ZapZilla
Member#: 51190
2002 WRX Wagon
is it ok to run stage 2 with a shorty downpipe (retaining 3rd cat) and uppipe?
ZapZilla is offline   Reply With Quote
Old 08-02-2004, 10:19 PM   #7
brizey
Member#: 36505
2004 Forester XT PSM
2007 Acura RDX w/Tech CBP
Zap:
Yes, but you are better off not. Read Cobb's whitepaper on their DP design. Basically, the main thing that matters is getting rid of the stock DP cat.
brizey is offline   Reply With Quote
Will a Cobb Stage 2 OTS Map pass a Smog Test? flukewrx Bay Area Impreza Club Forum -- BAIC 5 06-30-2009 02:24 AM
Will a cobb ap not work with my cold air intake? 02dubRX AccessPort 8 10-03-2006 02:32 PM
Cobb Stage 2 w. stock 3rd cat - How much power am i losing? Alan l. Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 09-29-2005 03:57 PM
How will my cobb stage 2.5 vf34 wrx run against other stuff? brandon230573 Proven Power Bragging 54 03-31-2005 11:02 PM
will cobb stage 2 work on..? ZapZilla Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-03-2004 03:31 AM
