Welcome to the North American Subaru Impreza Owners Club Saturday June 23, 2018
Closed Thread
Old 09-22-2004, 10:13 PM   #1
txl146
Member#: 32459
02 WRX VF34 (SOLD)
Junior Tuned 301whp
Default Expected power gain on Cobb stage 2 car with Borla header install?
Just received mine today from NOPI. They shipped it out a day after I placed an order. My concern is whether Cobb stage map can benefit from Borla header.
Weld quality and fitment seems very good although I haven't installed it yet.
txl146 is offline
Old 09-22-2004, 10:34 PM   #2
UGotBoost?
Member#: 45735
2002 Impreza WRX
Perhaps you should e-mail Cobb and ask them (as it says on their AP website).
By the way... you think the fitment is good when you haven't even had a dry-run yet??
You've got a hell of an eye, then
UGotBoost? is offline
Old 09-22-2004, 10:38 PM   #3
txl146
Member#: 32459
02 WRX VF34 (SOLD)
Junior Tuned 301whp
Yep, I do have a hell of an eye
txl146 is offline
Old 09-22-2004, 10:57 PM   #4
HoOn
Member#: 43270
2004 Impreza WRX
I'm actually interested in what you find because I'm installing my Borla headers this weekend.
- John
HoOn is offline
Old 09-23-2004, 12:14 AM   #5
Lordhowe
Member#: 35265
same here
Lordhowe is offline
Old 09-23-2004, 12:44 AM   #6
voam
Member#: 33460
2003 WRX Wagon
There are some Cobb Stage IIs at the bottom here.
voam is offline
Old 09-23-2004, 02:01 AM   #7
Jard
Member#: 34935
Phil Kessel is a 2x
Stanley Cup Champion!
Take a look at my dyno thread (too lazy to find it right now). I really didn't get much of a gain from headers, but I'm pretty sure they are keeping the EGTs nice and low.
Jard is offline
Old 12-09-2008, 12:46 AM   #8
jmbwrx2004
Member#: 176321
2011 wrx
CGM
Heres your answer: I am also running the cobb stage 2 map with all the goodies, uppipe, dp, 3" TBE, and I installed my headers and I had the same question.."is this gonna be safe?" Well yes it can be only if you do it the right way: Once you install your headers you MUST reset your ECU by disconnecting the negative terminal on the battery and by pumping the brakes to drain any power left in the system(this just makes it reset quicker), the reasoning behind this is because your ecu once it flashed with the stage 2 map is not in a learning mode anymore it knows the map, and thats all it knows, to make your ECU "learn" the mod you must disconnect the negative terminal on the battery, let it reset, then this is the single most important thing( when you start the car dont touch anything! just let it run, dont hit the gas at all dont move just let it run for about 3 minutes, then shut it off. You must shut it off once before you go for a spin that way your ECU has learned the new airflow/velocity for timing, fuel delivery, etc. Now restart and drive you will feel the difference with the headers and now its safer than the ECU not recognizing it at all. And no resetting your ECU will not require a reflash, unless your using a Realtime cobb map, but if its the regular Basemap then it is already stuck in your ECU's database so resetting the computer will NOT erease the flash. Hope this helps..
jmbwrx2004 is offline
Old 12-09-2008, 12:56 AM   #9
Jncominco2
Member#: 170212
you just accidentally a paragraph
Jncominco2 is offline
Old 12-09-2008, 01:12 AM   #10
trix1
Member#: 195946
02 GGA
Why do you want your EGTs nice and low? The main thing that drives the turbine is delta T.
Anyways, a 4 to 1 is better than the stock bendy straw even if you only gain 1HP.
trix1 is offline
Old 12-09-2008, 01:33 AM   #11
SlverEJ20
Member#: 157158
05 WRX stage 2
WOW did you realize how old of a thread you bumped???? this thread is 4 years old!
SlverEJ20 is offline
Old 12-09-2008, 02:33 AM   #12
bettyblue
Member#: 90920
2005 2.0FPGREEN 6SPD
2002 bugeye Vf39
hahahahaha
bettyblue is offline
Closed Thread
disabling CEL codes / forcing readiness on a Cobb Stage 2 car using romraider? wrxftl Open Source Reflashes 2 03-20-2008 09:44 AM
Driving with VF39 on Cobb stage 2.5 map without JDM pinks... gopsu AccessPort 16 08-01-2006 10:50 PM
Will ECU Explorer work on Cobb stage 2.5 car? txl146 AccessPort 3 05-23-2006 05:26 PM
Is there a thread on Cobb Stage 2 vs. Prodrive Stage 3 Power Pack? casualsurfer Newbies & FAQs 4 05-03-2004 05:06 PM
$500 to spend on my Cobb stage 2 car... suggestion? WRXVII Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 04-10-2004 04:31 PM
