Welcome to the North American Subaru Impreza Owners Club Monday July 26, 2021
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 10-12-2014, 12:10 AM   #551
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
The light doesn't have to work on the AC button to send the request. You can actual see what is being requested in one of the tools menus.
To me it sounds like your coolant thermostat is stuck open.
Element Tuning is offline   Reply With Quote
Old 10-12-2014, 09:13 AM   #552
Element Tuning
Member#: 54918
673 WHP Element
Also if your AC request was never on but the AC Comp output was and the fans ran, you likely have a short circuit somewhere. .maybe the wire to the AC Comp itself is pinched in the engine bay.
Old 03-05-2015, 06:03 PM   #553
skets
Member#: 170698
2003 WRX V-Limited
Phil,
I need to re-pin the connectors on my harness.
Is this GM 12146447 the correct part number for the terminal?
And is this the correct tool to de-pin them?
skets is offline   Reply With Quote
Old 03-20-2015, 12:54 PM   #554
skets
Member#: 170698
2003 WRX V-Limited
I figured it out. Those are in fact the terminals and you really don't need more than a paperclip to de-pin them.
The next question is:
I have a situation where I set the thermofan to turn on at 200 degrees but the temperature creeps up well past that (verified on Hydra) and the fans still don't turn on. However, if I change the output parameter from thermofan to 'on' the fans switch on (so I know the connection to the fans is solid). What else should I check?
Old 04-15-2015, 11:03 AM   #555
veel86
Member#: 308550
2006 Wrx STi
Default The Hydra Thread
Hey guys, I'm trying to tune a car with hydra, but the ecu is password protected so I cannot data log and or view the current tune. I believe the car was tuned by George at P&L in Chicago previously. Is there anyway I can get access to the ecu without the password? Or should I contact P&L to get the password?
veel86 is offline   Reply With Quote
Old 06-14-2015, 01:15 PM   #556
Rabbit78
Member#: 314307
Default Timing retards when I hit boost?
Hi, whenever I go into boost, the Hydra is dropping my timing back to the very lowest level. I've looked everywhere in settings to see what is making it do this and am at my wits' end. Has anyone ever experienced this, and if so what the heck is causing this??? I appreciate any help being pointed in the right direction.
Rabbit78 is offline   Reply With Quote
Old 06-14-2015, 04:04 PM   #557
SW00P_G
Member#: 5591
EJ257 Gt35r
I've seen that happen many times if you try to use a newer software version with an older firmware box. When you try to take off it retards the timing and runs like it trying to tow a house.
Either upgrade your firmware or switch back to the proper software version and reload the map.
Let me know if that helps.
SW00P_G is offline   Reply With Quote
Old 06-15-2015, 12:43 PM   #558
18gabtom35
Member#: 210254
2003 wrx
wr blue
Thanks for the help SWOOP_G. You are right about using the 2.7 software on a 2.5. The previous owner told us he had sent it back, so it would run on the 2.7 software.
I found the 2.5 software online, and now my only problem is, I can't get it to connect to the hydra.
18gabtom35 is offline   Reply With Quote
Old 06-15-2015, 12:46 PM   #559
SW00P_G
Member#: 5591
EJ257 Gt35r
Awesome! I'm not really familiar with the 2.5 software anymore. I know there was some issues and certain settings that were needed for USB to Serial adapters though.
Old 06-16-2015, 04:00 PM   #560
PhilGrabow
Member#: 421737
Which version of the software are you using (2.5, 2.6, or 2.7)?
Typically this is a sign you're "launch or anti-lag" maps are turning on. You can log the request flag in 2.7 and you can view in panel with 2.6. A simple fix is to turn off any of those requests in your "auxiliary input requests"
2.6 and 2.7 also have gear based trim maps etc. If you're not running an Element Tuning base map odds are some of these maps are wrong and could be pulling timing.
PhilGrabow is offline   Reply With Quote
Old 06-16-2015, 07:34 PM   #561
Rabbit78
Member#: 314307
Default Thank you for chiming in, Phil!
As GabTom (my bf) said above, it is 2.5 device, however the previous owner said that he'd "sent it back" (presumably to Hydra) to run on the 2.7 software. I assume that meant upgraded. We cannot connect to the Hydra with anything other than 2.7 software on our 'puter tho so aren't sure if it truly was rolled back? Hydra info says the platform is 2.7084. I don't know if this will help but the s/n is: FHZ050111C2.7-W11534
He said he has gone to the auxiliary inputs and turned everything to "off". He has also zero'ed out any of his anti-lag ignition trims, just to be safe, since that was his first thought when he saw it was initially going into negative timing.
Originally this was an ET map, however it's impossible for us to know how much that base map was altered before we purchased it.
This is in a Factory Five 818 and is plenty fast already, we just know it will be even more rip-roaring awesome if we can get this tuned right! For now, we've set the lower ignition limit to 10 degrees & it immediately kicks down to 10 when we hit boost.
Oh, one other thought: I'm not sure if the Hydra uses the MAF sensor at all to calculate load, but I do have that in a blow-through configuration just before the throttle body so I know that would throw off a normal (stock) ECU's load site. I am not sure if that would throw off a Hydra or not?
Any help would be greatly appreciated. We totally think you rock, and love watching your race videos!
Old 06-17-2015, 01:30 PM   #562
PhilGrabow
Member#: 421737
We sell a tech support package for second hand Hydras and I really think you need it. There are so many layers to the mapping and I'm sure if this unit does not have a specific ET 2.7 map there's likely a trim being applied somewhere either gear based, speed based, or other. It will save a you a ton of grief and time to start with a known well tuned base map.
The Hydra only uses MAF for air temperature input. Speed, throttle, coolant temp, air temp, gear, boost, knock threshold, launch, anti-lag, and auxiliary maps all have ignition trim tables.
Old 06-17-2015, 07:03 PM   #563
18gabtom35
Member#: 210254
2003 wrx
wr blue
Thanks Phil, I will probably take you up on the tech support package. I'm a pretty confident with my tuning abilities, but I just want to be sure on the non standard things.
I did find my timing issue thanks to your help. My gear ignition trim was set to -64 in every gear, I never thought to check that. I think I'm going to have to use the gear boost trim, as I'm now smoking tires in the first 3 gears at only 13 pounds of boost.
I'll give you guys a call at Element to discuss the tech support package.
Thanks again, Tom
Old 06-22-2015, 12:14 PM   #564
Bariga
Member#: 179846
07 STi Limited
EFR 8474 TS EWG
Hey Phil,
Whats up with the retards removing hydra 2.5 software from the website?
Are they ****ing serious ?
Bariga is offline   Reply With Quote
Old 08-27-2015, 07:02 PM   #565
H_wells3000
Member#: 322035
Is anybody running a drive by cable ej255 swap in their wrx with avcs? I need some pointers on how to wire the avcs solenoids to a hydra 2.7 ems.
I'm running an ej255 longblock in my bugeye, stock 03 wiring harness and dbc throttle, the avcs solenoids and cam sensors just unplugged for now.
H_wells3000 is offline   Reply With Quote
Old 10-16-2015, 09:03 PM   #566
H_wells3000
Member#: 322035
Does anyone have a picture of their hydra installed? I cant figure out how to tuck this all under the kick panel.
EDIT
Got it. Seems I don't have the kick panel spacers.
Old 12-19-2015, 09:28 AM   #567
francisco1971
Member#: 407601
Default impreza 2.5 outback wagon 2002 harness to plug and play with hydra from sti 2004
hy i need aimpreza 2.5 outback wagon 2002 harness to plug and play with hydra from sti 2004. im doing a 2004 sti engine swap into my impreza outbak 2002 wagon. let me know what can you do or if you have thar harness to be plug and play.
than you and happy hollydays
francisco1971 is offline   Reply With Quote
Old 12-20-2015, 11:37 AM   #568
PhilGrabow
Member#: 421737
Sure Hydra EMS/Element Tuning offers a plug-in harness for the 2002 RS using the oem RS chassis harness. If you're going to run an STI motor it's a custom harness with the required additional flying leads to ru an STI engine while using an RS chassis harness and Hydra EMS.
How much STI vs how much RS is left really needs to be discussed with a phone call. Some convert to DBW throttle, etc. In any event, yes but custom harness and custom Hydra EMS mapping. Done often so no big deal.
Old 02-21-2016, 08:58 PM   #569
H_wells3000
Member#: 322035
If anyone with a wrx is interested Im pulling the plug on my setup. See my for sale thread.
Old 03-01-2016, 08:32 PM   #570
Battlerager01
Member#: 441527
How can I get my hands on one of these things north of the border (canada)?
Battlerager01 is offline   Reply With Quote
Old 03-01-2016, 11:29 PM   #571
PhilGrabow
Member#: 421737
Email Element Tuning with your year/make/model and engine details and it's as simple as that. Units just came off backorder also.
Old 03-08-2016, 07:08 PM   #572
SW00P_G
Member#: 5591
EJ257 Gt35r
I didn't know they were on backorder. We are talking to a couple of customers about going Hydra at the shop (SM Motorsports). Are there any new things in the works that you have heard?
Everything has been working good for us, but we would like USB, more datalog storage, and more control over closed loop.
Just curious, it's been a while since there has been an update to the hardware or software.
Old 03-12-2016, 01:32 PM   #573
MiSTI93
Member#: 428562
2006 STI
Hello,
have a problem starting my93 wrx type ra with hydra 2.5 ...
Have spark and fuel pressure/fuel pulse, and did crank trigger test (got trigger wheels from wrx, as the pre-owner said)...
While cranking battery voltage goes does to 10V (think the hydra requires 10,4V). Battery is new.
Also new crank and cam sensors.
Maybe someone has an idea why the voltage goes down like this
MiSTI93 is offline   Reply With Quote
Old 09-18-2016, 10:22 AM   #574
Subby2.5i
Member#: 338792
Anyone know why the link for the Nemesis 2.7r84 Firmware Upgrade doesn't work off their website? I'm ready to throw this damn ecu through my window
Subby2.5i is offline   Reply With Quote
Old 09-18-2016, 08:56 PM   #575
SW00P_G
Member#: 5591
EJ257 Gt35r
I don't think their website has been updated since 2013. Take that to mean whatever you may think it does.
Using the Hydra with the GM AIT Sensor.. sponaugle Other Engine Management 1 11-14-2008 01:24 PM
How does the antilag work on the Hydra? Crazykev Other Engine Management 2 10-15-2005 07:11 PM
How many people are using the Hydra on the STi? Quick Other Engine Management 10 10-03-2005 01:20 AM
The Second Official Unofficial Hydra Thread bboy Other Engine Management 2 06-06-2005 11:39 AM
Hydra Users: Anyone know the Hydra injector mapping? wgknestrick Other Engine Management 12 03-07-2005 04:12 PM
