Welcome to the North American Subaru Impreza Owners Club Thursday October 18, 2018
Old 06-25-2018, 03:08 PM   #1
streetsoldier59
Member#: 177106
2006 STi WFC #130
Default Boost Leak? Stall Issue
Hey guys. I've been having some issues with my 06 STi for a while. Its on a Speed Density tune so its a little hard to diagnose issues not to mention that it'll still run with a vacuum leak. The issue started when I did a pull and parked the car. I realized the next day that I didnt have any boost after 4k rpms and especially at WOT. I later found that the hose from my Tial bov was disconnected on the opposite end. To me and all of the diagrams that I've seen, it looks like it came from the nipple on the intake manifold under the throttle body. So I plugged it in and shouted VICTORY! But to my surprise , when I started the car it just shut back off again. And now I cant get it to crank without pulling that bov hose back off. I even tried to reset my tune. I'm going to add my mods list just incase it'll help with any suggestions. Any help would be greatly appreciated. Thanks in advance.
Ets rotated turbo kit
precision 5862cea turbo (no maf sensor)
Perrin EL Headers
3" straight pipe (loud)
Tial 44mm wastegate
Ageny power fuel rails
Deatschwerks 850cc injectors
Grimmspeed Tgv deletes
Grimmspeed gated Ported and coated uppipe
Grimmspeed Ported and coated dump tube
Grimmspeed 8mm Phenolic Spacers
Grimmspeed air oil seperator
Grimmspeed 160 degree Thermostat
Gates Timing belt kit w/ Water Pump
NGK 1-Step-Colder Spark Plugs
competiton clutch 3.5
Acl race bearings
Killer bee oil pick up
11mm oil pump
Aeromotive 340lph fuel pump
Tial 50mm bov
Aps dr525 fmic
Treadstone performance aluimlum pipes
Hallman pro. Manual boost controller
Cobb accessport v2
4 bar map sensor
streetsoldier59 is offline   Reply With Quote
Old 06-25-2018, 03:45 PM   #2
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
Hmmmmmm.....can't comment on boost issue, but, WTF you mean it won't crank?
Many issues may not allow it to not start, no crank is (in my mind) is totally separate.....
So......it won't crank, or it cranks but won't start?!?!
Did you kill the battery while trying to get it started?
Did you disturb a battery connection while trying to resolve your issue?
Charlie-III is online now   Reply With Quote
Old 06-25-2018, 03:52 PM   #3
streetsoldier59
Member#: 177106
2006 STi WFC #130
Its simply as I stated. I can drive the car forever until I connect that bov hose. Once I do that it idles low, almost stalls and gets jerky or cranks and shuts off immediately.
