04-01-2009, 05:15 PM | #326 |
Member#: 56203
Vehicle:00 RSTI Coupe Twin Scroll 2.5XTR EJ207 |
04-01-2009, 05:48 PM | #327 |
Member#: 21392
Vehicle:2018 E63S AMG MB Black/MB |
mmt in time causes your valves not to seat right , loss of compression, misfire from fouled plugs,lots of idle issues .
if your running water alcohol injection you probably wont notice nothing cause the alcohol and water is cleaning your intake at the same time your using torco. |
04-07-2009, 10:40 PM | #328 |
Member#: 6375
Vehicle:2004 STi Java Black Pearl |
I ran the torco for over 25,000 miles .. in the same car, the same plugs. Never miss-fired once. I ran 32 oz, to every 10 gallons of fuel.
I saw the same orange MMT residue, but in the end, it literally looked the same as a car that wasn't running MMT. Anotherwords, the soot/carbon buildup looked exactly the same in density, just that it was a black/carbon grey color instead. I find it hard to believe that thousands and thousands of people are using the Torco additives in much the same way, barely anyone seems to have these kind of issues. Did you notice how the actual electrode and the arm above it are nice and clean? Unless you are running some super concentrated amount like 32 oz to 5 gallons, you shouldnt' be experiencing those problems ..... my $.02 |
04-11-2009, 03:24 PM | #329 | |
Member#: 208281
According to your calculations Valhakar, am I correct in saying that about 9oz of torco will raise my 13.3 gallon tank of 91 octane up to approximately 93 octane? I have a Solstice GXP by the way. Also, how is everyone running with this stuff...is it causing any damage like the guys sparks plugs in a previous post ? Also, i love your guys' smilies !! |
03-29-2012, 07:54 PM | #330 |
Member#: 222494
Vehicle:17 STi WHITE |
raising this from the grave how bout it torco users?
07-24-2012, 12:14 PM | #331 |
Member#: 192492
SCIC
Vehicle:05 built FP green obp |
just bought a 6-pack of the 32 oz cans. Gunna use it on track days just to prevent knocking
09-01-2012, 01:07 AM | #332 |
Member#: 307624
Vehicle:2008 WRX Hatch 325/347, 380XT, 8 cm2 |
Yeah.
09-02-2012, 07:43 AM | #333 |
Member#: 52043
Vehicle:04 sti |
You bumped to say yeah.
09-26-2014, 03:29 AM | #334 |
Member#: 125064
Vehicle:2013 JDM STI spec C Blue |
Bump this. I want to start using torco to compensate for the crappy 90 fuel i get down here, so far i didnt see any catastrophic failure, just some orange colouring on the plugs. So i want to hear from long time users, still no problems?
09-26-2014, 04:21 AM | #335 |
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
yeah.
09-26-2014, 04:52 AM | #336 |
Member#: 21392
Us torco OG's moved on .
09-26-2014, 05:32 AM | #337 |
Member#: 16200
id rather have a good water alky injection setup
09-26-2014, 07:24 AM | #338 |
Member#: 32792
NESIC
Vehicle:2003 GGA MBP 12.9 / 105+ |
i'm STILL prepping to install my ADI setup.
and i STILL want to put a bottle of torco in the ADI tank. |
09-26-2014, 07:47 PM | #339 |
Member#: 16200
09-27-2014, 07:57 AM | #340 |
Member#: 53665
NESIC
Vehicle:2022 BMW M240i Thundernight |
Would toulene or xylene do the trick?
Sent from my XT1060 using NASIOC mobile app |
09-27-2014, 09:35 AM | #341 |
Member#: 250152
Vehicle:2006 WRX Limited OBP |
I know a guy who mixes Xylene in his 3000GT VR4. Don't know what ratio he was using but he was able to pick up an extra 30-40 HP because he could really throw the ignition timing at it.
Sent from my SAMSUNG-SGH-I537 using NASIOC mobile app |
09-27-2014, 09:44 AM | #342 |
Member#: 32792
NESIC
i think the difference is that toluene or xylene are aromatic fuels themselves (higher distillates of petroleum) and have an inherently higher octane rating. ie, you could run an engine on pure toluene. but you have to add a lot because you're basically averaging two octane ratings together.
like lead, torco works on a molecular level to stabilize the volatility of the fuel/air mix and interrupt spontaneous combustion. traditionally ADI is all about cooling and condensing the intake charge beyond what is possible via physical/mechanical intercooling. obviously in the case of water injection there are no combustible products being introduced to the chamber. in the case of methanol it is also flammable, and used as an internal combustion fuel in its own right, and it does have a higher native octane rating than pump gas, but the real benefit comes from the speed at which it evaporates and steal heat energy from the charge air. the injection of torco appeals to me because it can be added in such small quantities relative to total fuel consumption to achieve pretty substantial results. that's not the case with introducing xylene or toluene where in order to achieve the same level you'd need to add quite a bit. |
09-27-2014, 03:29 PM | #343 |
Member#: 257818
SWIC
Vehicle:2007 STi CGM |
09-27-2014, 03:41 PM | #344 |
Member#: 125064
I still would like to hear from long tine Torco users experience any problen to the engine or whatsoever. As i plan to use some in each tank of our ****ty 90 gas
09-28-2014, 11:11 PM | #345 | |
Member#: 16200
screw adding torco to every tank |
09-30-2014, 09:34 AM | #346 |
Member#: 250152
Technically wouldn't 100% methanol give you the highest Octane advantage?
Sent from my SAMSUNG-SGH-I537 using NASIOC mobile app Last edited by 2Fast4U1DAY; 09-30-2014 at 08:26 PM. |
09-30-2014, 02:35 PM | #347 |
Member#: 32792
NESIC
as an adi fluid, or as a primary fuel?
09-30-2014, 02:43 PM | #348 |
Member#: 250152
As an adi. I know that methyl alcohol (methanol) as a primary fuel is equivalent to 113 octane...
09-30-2014, 10:27 PM | #349 |
Member#: 16200
yeah...there are calculations to be made.....it isnt 100%....it is usually in the 65%-75% range
09-30-2014, 10:45 PM | #350 |
Member#: 32792
NESIC
Torco race fuel concentrate | dwaynesti | Vancouver Impreza Club Forum -- VIC | 0 | 06-29-2007 06:33 PM |
FS: Half Case Torco Mach-1 Unleaded Race fuel concentrate | godai | Accessories & Misc | 4 | 09-21-2006 09:54 AM |
Torco Race Fuel Concentrate in Phx? | AaronB | South West Impreza Club Forum -- SWIC | 25 | 04-18-2006 11:26 PM |
Oil analysis after 3k of using Torco Race Fuel Concentrate | The Deliverator | Service & Maintenance | 8 | 05-19-2005 12:51 PM |
NY: 4.5 gallons of Torco Race Fuel Concentrate | The Deliverator | Private 'For Sale' Classifieds | 2 | 09-13-2004 12:55 PM |
