Welcome to the North American Subaru Impreza Owners Club Sunday June 17, 2018
Old 05-03-2005, 04:32 PM   #1
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
Default ported/polished/wrapped oem manifolds webpage
teaser pic...
rest of writeup...
http://ken-gilbert.com/wrx/porting/p...t_manifold.htm
haven't had a chance to put them on the car yet... this week i hope! i will try to get before and after datalogs.
comments appreciated
Old 05-03-2005, 04:48 PM   #2
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Looks like very impressive work, Ken.
That is going to be one fast spooling machine...!
cdvma is offline   Reply With Quote
Old 05-03-2005, 04:52 PM   #3
garie
Member#: 26607
2002 wrx wagon
great writeup. Very thorough with many pictures. The best writeup w/ pictures on pp the stock headers so far.
how long did that take you? how many man hrs?
great job man...and how does is compare to before? can you compare it to aftermarket headers?
garie is offline   Reply With Quote
Old 05-03-2005, 05:40 PM   #4
InfamousDX
Member#: 25413
That musta been a lot of man hours! But it looks great
InfamousDX is offline   Reply With Quote
Old 05-03-2005, 05:43 PM   #5
steve
Member#: 4718
Sold my Subaru, and
now I'm so OT
Good work ride5000.
I just P&P'd my exhaust manifolds, and the results are great. Well worth the many hours to do it right.
steve is offline   Reply With Quote
Old 05-03-2005, 06:33 PM   #6
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
awesome!
djerickd is offline   Reply With Quote
Old 05-03-2005, 06:33 PM   #7
SleepinRex
Member#: 12449
nice ken. Good to see a fellow p&p'er doing some good work. Love how pretty manifolds get... lol
U also may wanna try a dremel or rotozip with a flex shaft. They allow me to reach farther than even my 7 inch mandrel will allow me to. lets me reach all the way down.
SleepinRex is offline   Reply With Quote
Old 05-03-2005, 06:51 PM   #8
03WREX
Member#: 38932
WRB - Cobb Stg2
That's a very good write up and I give you props for doing all of that yourself. I am curious on what type of gains you will see from this. Please keep us all updated.
I'm sure this was a work in progress but can you estimate about how long this took you to do? Definitely post this on scoobymods if you haven't already.
03WREX is offline   Reply With Quote
Old 05-03-2005, 07:06 PM   #9
kennyvb
Member#: 70234
MY86 BMW E30 325
SCIC/NWIC tranplant (-_-)
ken, good work. let us know how the tape holds up. you didn't remove disassemble the turbo before porting?!?
kennyvb is offline   Reply With Quote
Old 05-03-2005, 08:39 PM   #10
jamesfacts
Member#: 51282
98 RS
black & blue from parking
I really have to do this before my motor goes in.
I think Mike and I are going to attempt this sometime over the next week at Jon's actually. I hope it comes out as nice as yours. Are you recycling the gaskets?
jamesfacts is offline   Reply With Quote
Old 05-03-2005, 08:50 PM   #11
distorto
Top Scoob 024
Member#: 56364
RIP stompr :(
bagged vulvva
that looks awesome, but why the work on the outside?
distorto is offline   Reply With Quote
Old 05-03-2005, 09:12 PM   #12
CMJ
Member#: 39235
Polished metal retains more heat than a rough surface would.
CMJ is offline   Reply With Quote
Old 05-06-2005, 10:32 AM   #13
spit_heron
Member#: 23655
well, not when its wrapped and taped.
spit_heron is offline   Reply With Quote
Old 05-06-2005, 11:27 AM   #14
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
sure it does!
Old 05-06-2005, 11:48 AM   #15
spit_heron
Member#: 23655
Originally Posted by ride5000
sure it does!
i would think the primary modes of heat transfer would be conduction through the walls, conduction to the wrap (with a pretty high contact resistance), conduction to the tape, then convection off the tape, with a little emiittance to surroundings. No?
Old 05-06-2005, 12:27 PM   #16
spit_heron
Member#: 23655
with unwrapped manifolds, radiation off the cast walls is certainly a significant loss of heat.
I guess im saying that the only surface that can radiate to surroundings in your setup is the outer layer, i.e. the tape (which will have a pretty low emissivity).
As you said, it seems the benefits of not having an abrasive surface against the wrap is worth the time itself though. Parts look good man! Let us know how that tape holds up.
Old 05-03-2005, 09:52 PM   #17
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
I ported and polished mine when I had them off but I didn't bother with the outside. How long do you think before rust sets in and returns them to the original state?
LiquidForce is offline   Reply With Quote
Old 05-03-2005, 10:50 PM   #18
needmoreboost
Member#: 36806
98 Rsti/denali
Infamous Racing
Wow that is some great work right there. Makes me wanna take off my manifold and go at it with my dremel and aluminum carbide bits.. at least as far as it'll let me (which isn't very). Time to buy a flex shaft from sears.
needmoreboost is offline   Reply With Quote
Old 05-03-2005, 10:58 PM   #19
strohausii
Member#: 26770
'02 WRX
midnight black
noob question: is it true the manifold's holes are smaller than the actual ones on the head? To increase the velocity? I thought I had read this early on before the wrx came.
strohausii is offline   Reply With Quote
Old 05-04-2005, 12:27 AM   #20
ebeck
Member#: 35585
RIP I'll always be
The Ver8 Magistrate
Is this completed? There is alot of meat left to get to the gasket seal ring as far port matching goes.
ebeck is offline   Reply With Quote
Old 05-04-2005, 01:15 AM   #21
SleepinRex
Member#: 12449
i know it may look that there is a lot of the meet around, but trust me that this is completed. Ive done near 10 more since this, and all have been within 1mm for some gasket play. ill post anot pic with teh gasket on.
Old 05-04-2005, 02:32 AM   #22
booimaghost
Member#: 71144
94 MKIV
I have read that a good P&P on your stock headers can actually be better than a aftermarket down pipe.... is this true?
booimaghost is offline   Reply With Quote
Old 05-04-2005, 09:00 AM   #23
Davenow
Member#: 23676
None, did you mean aftermarket header?
If so, then yes, ported stock manifolds work WAY better than aftermarket headers.
Old 05-19-2005, 06:38 PM   #24
popcrux
Member#: 85829
2005 WRX Wagon
Ok Dave, I've been reading up on headers and I was wondering if you could explain this one to me. I know the stock headers are cast iron so they will retain heat and spool up faster than aftermarket headers. If the airflow from P&P'ing is similar to that of an aftermarket header, then do these two attributes combine to make the P&P of the stock header a much better option?
What about wraps and/or heat coating to help retain heat on the aftermarket headers?
What about P&P'ing aftermarket headers (such as the Gruppe-S) and heat wrapping those. Would you still say a P&P'd stock header would be superior to this route?
popcrux is offline   Reply With Quote
Old 05-04-2005, 02:39 AM   #25
SleepinRex
Member#: 12449
check out my thread "port and polish madness" i have a bunch of impressions on there. EVery single customer so far has been very pleased with the gains, especially for the price.
FS in IL - ported/polished/swain tech ceramic coated OEM STi exhaust manifold SilverSurfer04STi Engine/Power/Exhaust 7 09-27-2008 02:40 PM
FS in IL - ported/polished/swain tech ceramic coated OEM STi exhaust manifold SilverSurfer04STi MWSOC Private Classifieds 10 09-27-2008 02:39 PM
FS: VA Gutted/Ported/Polished/Coated OEM WRX Uppipes soobaviator Engine/Power/Exhaust 18 03-06-2007 10:35 PM
Port, Polish, Wrap Stock Manifold, what will fit 300zxls1 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 55 01-31-2006 12:36 AM
