Welcome to the North American Subaru Impreza Owners Club Thursday July 19, 2018
Old 06-03-2014, 11:49 AM   #76
otobeagod
Member#: 337147
2003 WRX
Very nice. Starting mine now.
otobeagod is offline   Reply With Quote
Old 06-03-2014, 04:22 PM   #77
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
Welcome to 7 years ago.
2gnt2wrx is offline   Reply With Quote
Old 06-04-2014, 07:45 AM   #78
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
7 years but still using the same manifold!
i did have a hairline crack on the RH collector that i welded, and i rewrapped everything about a month ago when i swapped to an EWG.
Old 06-06-2014, 03:26 PM   #79
otobeagod
Member#: 337147
2003 WRX
@ride5000
I hope mine holds as well as yours!
Getting ready to put the car back together. Did the up-pipe too. Maybe I will make it another 100,000
Old 06-06-2014, 04:24 PM   #80
oaklandish_WRX
Member#: 267339
2002 0[[XXXXoXXXX]]0
MBP LongRoof
@ride5000
1 - Who did your PnP work?
2 - No further sealing/tape/tree sap planned over heat-wrap?
thx
oaklandish_WRX is offline   Reply With Quote
Old 06-06-2014, 08:31 PM   #81
otobeagod
Member#: 337147
2003 WRX
1. I did the PnP work.
2. I might put HVAC tape, but probably not.
Old 07-16-2014, 12:25 AM   #82
Amerino
Member#: 298182
Looks awesome, did you gasket match the ports that connect to the heads?
Also, how many rolls of the DEI did you use on the manifold?
Amerino is offline   Reply With Quote
Old 07-19-2014, 12:34 AM   #83
oaklandish_WRX
Member#: 267339
MBP LongRoof
Prevailing wisdom is to match collectors to gasket, leaving the smaller exh port in the head as is to retain an anti reversion step.
Old 07-19-2014, 08:49 AM   #84
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
that is exactly what i did
Old 07-24-2014, 03:26 AM   #85
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
I would
for SURE
FS in IL - ported/polished/swain tech ceramic coated OEM STi exhaust manifold SilverSurfer04STi Engine/Power/Exhaust 7 09-27-2008 02:40 PM
FS in IL - ported/polished/swain tech ceramic coated OEM STi exhaust manifold SilverSurfer04STi MWSOC Private Classifieds 10 09-27-2008 02:39 PM
FS: VA Gutted/Ported/Polished/Coated OEM WRX Uppipes soobaviator Engine/Power/Exhaust 18 03-06-2007 10:35 PM
Port, Polish, Wrap Stock Manifold, what will fit 300zxls1 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 55 01-31-2006 12:36 AM
