07-06-2012, 10:10 AM | #76 | |
Member#: 253059
Vehicle:2007 WRX WRB |
http://forums.nasioc.com/forums/show....php?t=2377092 This is when it sucks not being very car-savy
07-06-2012, 12:16 PM | #77 |
Member#: 253059
Also, if the new MAF doesn't fix the issue, I'll be looking at bringing it in somewhere. Dont really want to bring it to the dealer but also don't want to bring it anywhere that doesnt know these cars. Any suggestions on local places?
07-06-2012, 12:27 PM | #78 |
Member#: 165141
If this is Bill (merchgod) who you're talking to I'm sad to see that he's jumping to conclusions on this one. Unless I missed some background information, the 2 logs you posted isn't enough to justify spending $200+ on a new MAF sensor.
The positive fuel trims could be due to many factors, but a bad MAF sensor is one of the last I would look at personally. I have seen more ripped open turbo inlets that have caused this problems than any other thing. I would start by doing a boost leak test off of the turbo inlet. Look for leaks coming from before the turbo. This would cause your problems. |
07-06-2012, 01:02 PM | #79 |
Member#: 253059
Thanks for the reply! I feel like such a noob here.. are boost leak tests hard to do? Reading about some of the DIY testers and people say it's easy but digging through the engine is sometimes pretty foreign to me. I'm always up for learning so I'll keep reading up on this stuff today and see if they start to make sense. Thanks again! =)
07-06-2012, 01:16 PM | #80 |
Member#: 165141
They aren't too hard, but if you are not familiar with the connections on the turbo inlet I would do some reading or ask someone for help.
07-06-2012, 01:16 PM | #81 |
Member#: 165141
You also could try swapping MAF sensors with someone just to try it out, but I wouldn't jump the gun and go buy one right away.
07-06-2012, 03:56 PM | #82 |
Member#: 253059
so... anyone have a boost leak tester that I could hook up to?
If not, they don't look that hard... I'm just very familiar with the hooking it up and testing process and I'm trying not to blow anything up. |
07-06-2012, 04:00 PM | #83 |
Member#: 165141
Just make sure you cap off the crankcase breather lines.
I had one... not sure who has it currently though... |
07-06-2012, 06:58 PM | #84 |
Member#: 198844
Vehicle:2004 WRB STi |
Can of beans! Or any other can for that matter..I'm in gb off work but busy around the apt..if you need help a little later shoot me a text 906 396 4748
07-06-2012, 11:23 PM | #85 |
Member#: 165141
Josh, were you there for that!?!?!
07-07-2012, 01:10 AM | #86 |
Member#: 198844
Lol it was on my car!
07-08-2012, 03:38 PM | #87 |
Member#: 123985
Vehicle:2002 GMC Yukon '10 Forester XT DGM |
07-09-2012, 09:14 AM | #88 |
Member#: 294586
Vehicle:2005 |
Anyone lookin for a vf39 with an external wastegate setup. I have tons of parts off a 04 sti forsale. Text or call me if you wana no what I all got.
920-573-6930 |
07-09-2012, 11:35 AM | #89 |
Member#: 198844
07-09-2012, 01:02 PM | #90 | |
Member#: 294586
Vehicle:2005 |
07-09-2012, 03:44 PM | #91 |
Member#: 300779
Vehicle:'09 Subaru Forester Blackout |
So more drama with my Forester.... now the mileage has gone completely to hell.
Current mods are: Lowered 4.5" inches on STI coilovers Tires at 43-45 psi Roof rack removed Custom intake Straight exhaust (no cats/no muffler)... this gets swapped back and forth with the stock exhaust as it gets too annoying. Some parts removed/lightened. Average mileage over the first 77,000 miles was 27.6... the last year or so it has been closer to 30. If I really watch my foot and hyper mile I can get 36-37. Rarely is it under 26, ever... Last month the oil pump seized and the motor failed. I replaced the motor with a new OEM motor. Upon start up there was a bad fuel leak in one injector... mileage was around 18-20. Made sense considering the gas was spraying out like a squirtgun. I drove it for a total of 55 miles before I parked it and waited for the O-ring (week wait from the dealership). I replaced the O-ring and the leak was fixed. However the mileage is still terrible...The other day is was 12-15 mpg around town. The best I would see was 19-20 on the higway at 65. Its been about 250 miles and no improvement. I do have an engine light on, however this has been on since nearly day one when I switched exahausts. This has never had any ill-effect on mileage previously. I've read that a bad O2 sensor can cause horrible drops in mileage, but this bad? I'm having my codes checked tonight and I'll go from there, but wanted to get some opinions/feedback as well. I ordered a new O2 sensor (both) but they sent the wrong parts, so its another week of driving this way.... Any have any ideas?? I don't even want to drive this thing anymore... Thanks in advance! |
07-09-2012, 04:18 PM | #92 |
Member#: 165141
Check your fuel trims. If you notice that they are very far positive it could be your o2 sensor, but it's hard to say otherwise.
If you can log the car I'd check that your car is in closed loop going down the road, and if not you will have to figure out why... Off the top of my head I'd say o2 sensor, but I HATE throwing parts at a car and hoping that it fixes the problem. If you want I could check the fuel trims and maybe spend a few minutes logging the car and let you know if there is anything that sticks out. |
07-09-2012, 04:47 PM | #93 | |
Member#: 300779
I work til 4 in Omro, and live in Oshkosh... whats the easiest/most convenient way to meet up? |
07-09-2012, 05:59 PM | #94 |
Member#: 198844
Check the cel and get back to us. If bad front o2 it will dump fuel. If it comes up with system too lean it will also dump fuel. If your injector was just dumping fuel and not atomizing it wouldnt burn right and you could get a system lean code that way. Get your cel checked and go from there.
07-10-2012, 10:54 PM | #95 |
Member#: 6697
Vehicle:2011 WRX 5-door Look-At-Me Red |
07-11-2012, 01:29 PM | #96 |
Member#: 99876
Vehicle:2 2005 Subies! WRB STi and AB LGT |
SUNDAY, SUNDAY, SUNDAY!!! Be there!
07-12-2012, 08:53 AM | #97 |
Member#: 165141
You realize there's an autocross, right?
07-12-2012, 12:05 PM | #98 |
Member#: 99876
There is an autocross every weekend. I couldn't find one acceptable weekend without one, so that's the day we went with. No problems though, we are going to hit capacity - I just thought you guys who came last time would have a good time once again...
07-13-2012, 08:01 PM | #99 |
Member#: 306892
Vehicle:2006 wrx flat black |
Hey guys im grand rapids mi and im up in three lakes eagle river area wanted to know if there is anyone up in this area and if so are there in meets up here or gatherings where I could go find people to race. I did spot a wingless 04 silver rex in three lakes today and saw a new sedan wbite in eagle river.
07-15-2012, 02:34 PM | #100 |
Member#: 37870
Vehicle:2012 ISM WRX '16 Forester XT |
Hello
I am the new guy in town from Nebraska. I went to the beginning of the auto cross today and then to the Gilligan's car show.
Met a couple Subaru guys at the auto cross. Nice showing of cars at the show. See you around. Brian |
Similar Threads | ||||
New Website means New Thread - now with Carbotech on the way. | KNS Brakes | Suspension/Brakes/Handling | 4 | 05-20-2010 12:09 AM |
Official Northeast Wisconsin Thread!!! | getaforknjob | Mid West Subaru Owners Club Forum -- MWSOC | 0 | 02-28-2008 05:42 PM |
Official Modded/JDM 08-STi thread #2 *NOW with less nerd!..... | STI_SLC | Member's Car Gallery | 40 | 11-30-2007 11:45 AM |
SE Meet ...teh thread...now with less whoring...and bs... | madspecvman | Texas Impreza Club Forum -- TXIC | 95 | 09-12-2007 06:59 PM |
Crazy cop video - now with 100% less WTLW | STiMUL8 | Off-Topic | 26 | 11-22-2005 10:02 AM |
