#1 |
Member#: 519850
Vehicle:2019 Wrx CWP |
![]() Hey guys, quick question. Is AF correction 1 -20 to +35 normal? AF Learnin 1 -15% to +18. I have seen it pooped out couple times on my AP when driving to work, occasional -1.41,-2.81 knock. I feel like the car jerks a little when driving in traffic, AFR looks fine, no DAM drops. I have been dyno tuned since couple weeks.
GS EBCS, CHARGEPIPE, TMIC, INTAKE, JPIPE Perrin turbo inlet, IAG TGV deletes, P&L EGR delete. 93octane. Are those AF correction and learing numbers fine? Should i be concerned about this?
#2 |
Member#: 487500
Vehicle:2018 WRX |
![]() Are you quoting min/max values or are you getting those values while cruising? Under load?
Take a datalog to post up so we can take a look at what is going on. |
#3 | |
Member#: 519850
![]() Quote:
Theses are the min and max values i saw when cruising not sure when they happend. Will get a log tomorrow. |
#4 |
Member#: 487500
Vehicle:2018 WRX |
![]() Ok. My understanding is that Min/max is mostly irrelavant. When you are on decel or just barely tipping into the throttle some funky values can register. AF correction should be +/-5 while cruising and under light load.
#5 | |
Member#: 519850
![]() Quote:
I have recorded 3 logs, im gonna post them later after work. I noticed that one spike up to 30 was when the car was idling at gas station, oil temp was around 140 so it was still warming up. |
#6 |
Member#: 409636
Vehicle:2015 WRX |
![]() https://phatbottituning.com/buy-an-e...roubleshooting
read this... it will answer your questions and give you direction. #phatbotti |
#7 | |
Member#: 519850
![]() Quote:
Thanks, i guess nothing is wrong with my car and im overreacting. Car runs completely fine, was just worried about those high af correction numbers being high but i see now that it’s normal i certain situations. |
#8 |
Member#: 501927
![]() I agree with it being normal, after warm up reset the min max on ap and see what it does
Just for your piece of mind Good ol’ anxietyport |
#9 |
Member#: 519850
![]() Here are the logs if someone with more knowledge would take a look at them i would be grateful.
https://datazap.me/u/maverpl/af?log=2&data= https://datazap.me/u/maverpl/af?log=1&data= https://datazap.me/u/maverpl/af?log=0&data= First log is after i cleaned the map sensor. thanks |
#10 | |
Member#: 487500
Vehicle:2018 WRX |
![]() Quote:
#11 | |
Member#: 519850
![]() Quote:
Anyway i cleaned my maf and mas sensors and checked for any boost leaks, didnt find any. Af learning 1 looks better now but i still see numbers above -10 and -14 especialy when cruising on highway. AF correction looks normal, sometimes shoots up to 30% for a quick second but from what i know it's normal, especialy when letting of the throttle and coasting to a stop. Still trying to figure out af learning and get those numbers as perfect as possible. Can a tune play a role in those numbers? I have been dyno tuned by a JR so im not sure. I'll get some new logs after cleaning those sensors. |
#12 | |
Member#: 487500
Vehicle:2018 WRX |
![]() Quote:
I don't even have my accesport plugged in all the time. When I do, I don't even monitor AF learning. Its a long term ecu determined value. I'm sure the tune map affects it but its a closed loop correction that really doesn't matter all that much to me. AF correction should be within +/- 5% though. Again, min/max doesn't matter but while cruising and light throttle the ecu shouldn't have to make a lot of correction. |
