Welcome to the North American Subaru Impreza Owners Club Sunday January 24, 2021
Old 10-08-2016, 10:51 PM   #1
GK1707
Member#: 373868
'04 STi
Default 02 WRX LED headlight bulbs 9007
Searched and didn't find much. But has anyone successfully installed 9007 Cree style LED bulbs on a bugeye?
Looking to get better light output from the stock headlights without going to HIDs.
Looking into a set of bulbs similiar to these: http://www.ebay.com/itm/9007-80W-800...NXPN8L&vxp=mtr
Wondering if the LEDs fit with the stock retainers since the bulbs have large heat sinks on the back.
GK1707 is offline   Reply With Quote
Old 10-08-2016, 11:09 PM   #2
Cobrakai
Member#: 176408
2005 EJ207 STy
You're going to be scattering any useful light, stick to your halogen reflectors or pony up the dough and do it right with an HID retrofit.
If you want better output make sure your headlight lens aren't hazy and buy some quality halogen bulbs.
Cobrakai is offline   Reply With Quote
Old 10-09-2016, 12:18 AM   #3
GK1707
Member#: 373868
'04 STi
Already have sylvania silverstar in my bugeye looking to get away from halogens. I've had HID's in my other cars and the light scatter isn't so severe to me. Thanks for your input.
My question was referring to fitment of the Cree LED bulbs in the OEM headlight housing with the 9007 ring retainers.
Old 10-09-2016, 01:00 AM   #4
oaklandish_WRX
Member#: 267339
2002 0[[XXXXoXXXX]]0
MBP LongRoof
Philips xtremevision or narva rangepower 50+. Silverstars are overrrated crap.
oaklandish_WRX is offline   Reply With Quote
Old 10-09-2016, 03:58 AM   #5
Bikelok
Member#: 254851
2002 WRX wagon 5mt
What Cobrakai was trying to tell you is that it's a waste of time and money to use LED, or HID in a halogen reflector housing. It might appear brighter than halogen, but you are producing a terrible light pattern giving you LESS usable light. Not to mention blinding oncoming traffic!!!!!
As a bugeye owner myself, I know just how crappy the stock lights are. If you really care about light output, then get one of the following:
•a good HID retrofit
•JDM HID converted to left hand drive.
•DEPO Bugeye STI replicas
•Morettes
•clean up your current lenses and do some REAL research on good halogen bulbs and optimize what you have (post 4 has great suggestions for bulbs) (even optimized they will only be just ok, but FAR BETTER THEN A CRAPPY LED/HID MISMATCH).
There you go.
Good luck.
Bikelok is offline   Reply With Quote
Old 10-09-2016, 10:25 AM   #6
Mulder
Trust no one
Member#: 11170
02 RAV4 MT
15 WRX/11 CRZ
The post above is the best advice you are going to get here.
The 9007 configuration isn't the greatest for lighting performance to begin with, and there isn't much you can do to improve it. The Philips and Narva bulbs mentioned in post #4 may help somewhat, but forget about plug-and-play LEDs or HID's.
Morettes and Prodrive/UK-300's were a good aftermarket option but they have been unavailable for a long time and your only hope with those is to find a good used set in the classifieds.
Another thing you can do is to buy or fabricate a relay harness for the low beams to eliminate the substantial voltage drop on the ground/negative side of the lighting circuit. This will make a noticeable difference in light output even with stock bulbs.
Old 10-10-2016, 06:50 PM   #7
Cobrakai
Member#: 176408
2005 EJ207 STy
Retrofitting is probably your best bet, TRS has a kit for 320 for their mini D2S projectors, ballasts, shroud, and bulbs.
All you would need is a wiring harness which can be had for around 40 dollars on top of that.
The Mini H1 kit is 270, but then you're stuck using non-oem grade bulbs (if that matters to you).
https://www.theretrofitsource.com/co...rsal-kits.html
Old 01-20-2019, 03:40 PM   #8
bredzy
Member#: 358182
2001 20K Impreza
Guys. Come on. None of you have answered the question. I myself would like to know if they fit , crapy or not. I to am just curious about the fitment. I appreciate the honest advice but at the end of the day the question is still not answered.
Anyone with answers ?
bredzy is offline   Reply With Quote
Old 01-20-2019, 03:56 PM   #9
Mulder
Trust no one
Member#: 11170
02 RAV4 MT
15 WRX/11 CRZ
Sorry but the answer hasn't changed. Whether they fit or not, it's a bad idea.
Go ahead and try them if you like, just make sure you can return them if they either suck, don't fit, or both.
Old 01-20-2019, 04:00 PM   #10
bredzy
Member#: 358182
2001 20K Impreza
There was no answer to begin with .
Old 01-20-2019, 04:03 PM   #11
Mulder
Trust no one
Member#: 11170
02 RAV4 MT
15 WRX/11 CRZ
Post #2 was the answer. Anything but halogens in these lights is ill-advised.
You may not like that answer, but it's the right one. If you really want to improve the lighting on a bugeye, within the limitations of the reflector/9007 setup, the suggestions given are the way to go. Otherwise you'll be blasting light all over the place.
This is just like your A/F gauge thread, we're trying to help you out here.
Old 01-20-2019, 04:06 PM   #12
bredzy
Member#: 358182
2001 20K Impreza
I read that post brov and I disagree. That response does not say whether the bulb fits or not. It's obvious I won't get an answer here , or maybe you can't answer because you don't know. Anyway Thanks.
Old 01-20-2019, 07:50 PM   #13
the_saintusa
Member#: 171486
2019 911 GTS
They will fit.
But I wouldn't use them.
the_saintusa is offline   Reply With Quote
Old 01-20-2019, 09:04 PM   #14
bredzy
Member#: 358182
2001 20K Impreza
Originally Posted by the_saintusa View Post
They will fit.
Thanks!!! That's all I wanted to know. I'll try them anyhow.
Old 08-13-2020, 04:40 PM   #15
GK1707
Member#: 373868
'04 STi
Any updates on how they fit/look?
Old 08-13-2020, 06:44 PM   #16
bredzy
Member#: 358182
2001 20K Impreza
They fit. You just have to disassemble the bulb itself to fit into the bracket then re-attach it from the back .
Old 01-10-2021, 06:43 PM   #17
Alan_herrlin
Member#: 466729
They do not fit over the locking mechanism they would have to be modified
Alan_herrlin is offline   Reply With Quote
Old 01-11-2021, 09:06 AM   #18
bredzy
Member#: 358182
2001 20K Impreza
Umm.. they actually fit. Like I said before, you have to disassemble the bulb from the connector then push the glass part or led part through , place the locking system in the housing then refit the connector to the pins at the end of the bulb.
Old 01-13-2021, 01:28 PM   #19
Jaws4God
Member#: 521646
So do you have the issue they are talking about with FOG LIGHTS turning on the HIGH BEAMS?
Thanks.
Jaws4God is offline   Reply With Quote
Old 01-13-2021, 07:08 PM   #20
bredzy
Member#: 358182
2001 20K Impreza
Thanks.
No.. The fogs are on a dedicated switch.
Old 01-14-2021, 09:27 AM   #21
Jaws4God
Member#: 521646
Can you point me to the thread that showed you how to do that or can you let me know the process you did? Thanks!
~~ 2003 Subaru Impreza WRX ~~~
Old 01-14-2021, 11:23 AM   #22
bredzy
Member#: 358182
2001 20K Impreza
I sent you a PM. please reply.
