#1 |
Member#: 457490
![]() Event: Dyno Pull
Location: Dyno Pro Techologies / St. Louis, MO Ambient Temp: ~50 degF. Elevation: Unknown Weather: Cold, Dry. Tires: Michelin, Pilot Sport A/S 4, 235/40/17r Car: 2004 Impreza WRX Tuner: Shinji Tuned Dyno Info: DynoJet Transmission: 2005 STi Transmission with 3.90lsd (dccd inactive) Gear: 3rd/4th Peak HP at RPM: 407whp @ 6400rpm SAE Corrected Peak Torque at RPM: 370ft/lbs @ 5200rpm SAE Corrected Baseline hp/tq: 311whp/335wtq as 93 octane VF37 TS Exhaust setup Target Boost: 24psi Target AFR: 11.7 Fuel: 93 octane and E85 (rated to E60 at the time) Engine/Power Modifications: Stock V8 EJ207 internals, Garrett G25-660 .92a/r exh. housing, Full-Race stock location turbo kit (single scroll), Full-Race 2-Bolt ELH (coated), 38mm Tial MVS Wastegate, Invidia N1 Race Cat-Back, fully catless/unresonated, Innovate Flex Fuel Kit, ID1050x Cobb Injectors, AEM 340lph fuel pump, Aeromotive FPR, APS DR725 FMIC, fully functional AVCS, Killer B Oil pickup and oil pan baffle, IAG Competition series AOS. Driveline Modifications: 2005 STi Transmission with 3.90LSD (currently disabled dccd), Competition 6-puck clutch, stock flywheel, stock drive shaft. Suspension Modifications: Fortune Auto 500 gen7 coilovers, 24mm swaybars, ALK, Roll-Center Adjustment. Other Modifications: BBS 17x8 5x114.3, Brembos added, Grey and Black GC8 seats, Nardi Personal wheel, NRG QR, TIC holy shift kit, AFR gauge, ethanol content gauge, oil pressure gauge, boost gauge. Video Link: https://youtu.be/RlzFad5D5CQ Dyno Plot VF37 vs. G25-660 .92ar: https://img.nasioc.com/image/U1msI Picture of Car: https://img.nasioc.com/image/U1tds
#2 |
Member#: 457490
![]() Adding more info as a reply so I don't give the mods any more reason to delete all of that info ^
The car started as a V8 EJ207 that was my daily/weekend autox car. At first Shinji had me tuned at 311whp/335tq on 93oct and the car was awesome; stayed at that power for the better part of 6 months. We then stepped the car up to E85, changing nothing else but the normal fuel related items like fuel pump, injectors, flex kit, and the car seen 335whp/365wtq where it spent it's time at that power for almost 2 years until I was finally convinced that 400whp can be safely achieved with my 90k plus miles motor. I pulled the trigger on having the turbo kit and turbo installed after sitting on the parts for about 5 months and as you all see, the power was made and the power was made effortlessly. There's really so much more left in this turbo in the areas of overall power and spool. You might be thinking 400hp at 90k miles may be late in the motor's game to introduce that much power but if the inevitable happens before a new setup, then it happens. It's not a daily anymore by any means. I'd like to have a 2.1L Outfront Motorsports block installed, with built heads, 272 cams, and a 2.5i intake manifold which is why I opted for the .92ar housing for the extra headroom to grow into. But based on seeing what Speed Academy went through, it seems as if this turbo gets choked up even with a 2.1L so that's all a little undecided. As for autocross, that ship may have sailed for now because the turbo setup is pretty laggy being a 2.0L and having a .92ar exh housing, so it'll probably be a weekend cruiser/backroad carver for a while which is fine. Until I get a forged 2.1L block, the safest way to run this car at this power is on E85 with 93 octane timing which is what this car's tune is currently like. It's not gutless by any means but there's definitely more torque under the curve to be desired that the 2.1L should aid. Atleast the spool will be helped quite a bit. I also realize that my dyno plot photo is cutoff, but it is still making just a smidge over 300ftlbs/tq at 8k rpm which is not bad! Thanks for reading if you made it this far! Last edited by TheGreatTillzby; 02-17-2021 at 02:01 AM. |
#3 |
Member#: 508105
NWIC
Vehicle:2002 WRX Wagon VF39 Midnight Black Pearl |
![]() Very nice setup.
I love seeing 207s still kickin' around making over 400WHP. I almost went with the Full Race stock location G series setup for my 2.1 Stroker but switched instead to a GTX3576 Gen 2 with an IAG 2.5 block to keep it simple and get some more usable torque. Full Race makes tempting products haha This looks like a super fun setup for the street that should last a decent while. Nice build! Last edited by K3rm1tth3fr0g; 02-17-2021 at 08:46 AM. |
#4 | |
Member#: 457490
![]() Quote:
#5 | |
Member#: 508105
NWIC
![]() Quote:
I'd be very curious to see if the G25 660 would be maxed out on the 2.1 setup you're planning, based on the compressor map I would think it would be right on the edge but I could be wrong. Gotta love any setup that can go all the way to 8K! |
#6 | |
Member#: 29292
SCIC
Vehicle:2004 WRX wagon silver |
![]() Quote:
#7 |
Member#: 175624
Vehicle:0304 WRX WRX SY WRB |
![]() ^Speed Academy. I think they changed headers or something too iirc
#8 |
Member#: 182415
Vehicle:1999 RS Aspen White |
![]() Your numbers look pretty solid, the 550 seems to top out around 420-440 on most 4 cyl motors, 370lb/ft of torque is really good. You have a dyno plot thats not cut off? The 660 housings will make you lose about 1000rpm of spool, but flows about 10lbs more air at the same pressure ratio and turbo speed. So your probably looking at another 80-90hp for that loss in spool and mid range torque, also 450 is about all a stock 207 block will reliably hold i wouldn't push more than that.
For reference these turbos on a K series make about 30-50 more hp, but 50+ less lb/ft of torque, and they spin to 8500-9k or so. |
#9 |
Member#: 29292
SCIC
#10 | |
Member#: 457490
![]() Quote:
#11 |
Member#: 457490
![]() Once i'm 2.1L and it's all re-tuned, hopefully theres a positive difference between my car on E85 and them using pump 93 with octane booster. The results seemed pretty underwhelming on the g25 frame for the Speed Academy boys. So underwhelming that I bought a g30-660 with a 1.01ar like they did but was told that i'd have to modify my full race kit to make it work or cut into my darn block and so i returned it all and got my g25 back. I can tell you I wouldn't have appreciated the spool characteristics of the g30 on an autocross course and they were already dissing the spool characteristics of the g25 on track. Puzzles me what their end goal was with the abandoned sti and thats probably why there's no more content on it lol. Measure twice, cut once. Subies are expensive.
#12 | |
Member#: 508105
NWIC
![]() Quote:
Shaving the block and partially tranny is a very very common and non harmful practice used for the Spoolinator, Full Race kits, and larger FP turbos and more just FYI. |
#13 | |
Member#: 29292
SCIC
![]() Quote:
it might be a little different on a 2.0 than a 2.5 and alot has to do with what you are looking for. im my opinion the problem with autocross isnt where the turbo kicks in its the gearing of the trans. that's the problem. If anything you should try to find a v7 jdm trans that has the lowest gear ratio of all the 6speeds if you are going to do autocross. that will keep you in the zone longer than the other trans will. |
#14 | |
Member#: 457490
![]() Quote:
#15 |
Member#: 457490
