Welcome to the North American Subaru Impreza Owners Club Wednesday August 15, 2018
Old 04-28-2010, 03:36 PM   #76
island boyeee
Member#: 171758
2006 WRX Ltd Stg [email protected]!
Blk&Grn / 08 Daytona 675
Default Re: Retrofitting STI Projectors into 2010 WRX Housing, Now with 100% more DIY!
Originally Posted by P.Rico
I suggest you start reading from the first post.
I did when it was first posted like 2 months ago. My question was meant as more if a statement, as to why not spend less money and do a little extra work for a better outcome
island boyeee is offline   Reply With Quote
Old 04-28-2010, 04:07 PM   #77
P.Rico
Member#: 239452
2012 Volvo S60 T6
2005 Outback 2.5i
It's marginally better.
P.Rico is offline   Reply With Quote
Old 04-28-2010, 04:20 PM   #78
island boyeee
Member#: 171758
I've read that the TSX projector does actually make a difference, versus just using the lens. My post wasn't aimed at the OP. The guy a few posts up was looking for a STi setup for cheaper. I was simply saying not to be afraid of doing a little modifying, and save some money by getting TSX setup instead of the STi setup.
Stop trying to twist my advice.
Old 04-28-2010, 04:44 PM   #79
CarbonXe
Member#: 211237
82 XJ 750
92 YJ 4.0
The TSX projector is a better unit, but the difference is so miniscule, that it doesn't make much of a difference. Also, TSX projectors are usually $170-230 for a set, whereas STI projectors usually run $110-150 a set. Personally, I didn't see the difference between the two projectors worth the ~$60 price difference and the massively increased installation difficulty.
If you're going to go all out, TSX's are not the way to go. FX or ZKW projectors are probably the best two on the market.
CarbonXe is offline   Reply With Quote
Old 04-29-2010, 11:38 AM   #80
Felginator
Member#: 210088
97 Outback Sport
TSX projectors are not the best things out there, there are better options if you are going to take the time to do a full retro to these headlights. I use Valeo projectors in my retro that are probably 10 years old and I have a light spread fairly close to the TSX's.
Felginator is offline   Reply With Quote
Old 05-01-2010, 03:03 PM   #81
steverx05
Member#: 128269
The clear lens AP1 S2000 projectors are one of the best single beam HID projectors out there. I retrofitted them into the headlights on my old WRX. They blow away the stock HID projectors on my 08 STI in both width and intensity. They are just a pain to retrofit because of the brackets they are housed in, but WELL worth the money.
TSX projectors are decent for the cash and are easy to retrofit because of their evenly spaced mounting holes...but as stated, there are better, less expensive options out there. Down the road, if I upgrade my projectors, they will definitely be replaced with some S2K's.
steverx05 is offline   Reply With Quote
Old 05-12-2010, 10:20 PM   #82
Robstunner
Member#: 134222
2015 WRX Limited
ISM
just to re-confirm, i can direct swap the TSX-R lenses into my Stock STi HID headlights? How many washers did you use? I have a little condensation in my right headlight so i figured i can install those and clean up the marks
Robstunner is offline   Reply With Quote
Old 05-12-2010, 10:29 PM   #83
CarbonXe
Member#: 211237
82 XJ 750
92 YJ 4.0
As long as it's an 06+ STI, then yes, it's a direct swap.
I used one washer per top bolt. I didn't play around with any other settings though, as the 1 washer gap offered a nice amount of color and the cutoff remained nice and sharp.
Old 05-12-2010, 10:30 PM   #84
Robstunner
Member#: 134222
2015 WRX Limited
ISM
Sweet, i might just get the value lenses, as the are half off almost and they have no negative effects.
Old 05-12-2010, 10:33 PM   #85
CarbonXe
Member#: 211237
82 XJ 750
92 YJ 4.0
I have the value lenses, lol.
Old 05-12-2010, 10:45 PM   #86
Robstunner
Member#: 134222
2015 WRX Limited
ISM
Haha nice. Looks like ill give this a go. I have 08 STi headlights.
Old 05-14-2010, 03:45 PM   #87
fuji6
Member#: 186175
2009 WRX 5 Door
Dark Grey
Sorry if this has been covered, but I have a question concerning wiring. So from what I know you're supposed to disable DRL (daytime running lights) during the install. I saw the thread on finding the module for this and unhooking it. I'm also told that on the stock HID headlights the DLR work on the high beam bulbs. My question is, what would be involved in wiring up to a retro fit in this way?
fuji6 is offline   Reply With Quote
Old 05-14-2010, 04:01 PM   #88
CarbonXe
Member#: 211237
82 XJ 750
92 YJ 4.0
I didn't disable the DRL or change any wiring at all.
As far as I know, the DRL works off the turn signal bulbs, not the high beams. There is only 1 bulb in the high beam housing...
Old 05-14-2010, 04:14 PM   #89
fuji6
Member#: 186175
2009 WRX 5 Door
Dark Grey
Ok maybe I'm confusing model years or what I read. I'll go back and reread it.
Old 05-14-2010, 04:21 PM   #90
CarbonXe
Member#: 211237
82 XJ 750
92 YJ 4.0
I've never heard anything about having to disable DRL...
Either way, I have never turned my lights off, and will never turn them off.
Old 05-14-2010, 04:22 PM   #91
fuji6
Member#: 186175
2009 WRX 5 Door
Dark Grey
Somebody had the same thought I did I guess....
http://forums.nasioc.com/forums/show....php?t=1943296
I'll stop cluttering up your thread now.
PS great writeup
Old 05-14-2010, 04:26 PM   #92
CarbonXe
Member#: 211237
82 XJ 750
92 YJ 4.0
That was for an 06 WRX, I have a 2010. I'm not familiar with the 06 headlight, but it may be similar to the Scion tC, where it has a smaller bulb inside the high beam housing to act as a DRL.
Old 05-14-2010, 04:36 PM   #93
fuji6
Member#: 186175
2009 WRX 5 Door
Dark Grey
Ooops wrong link.
This was the one. But now that I read it again, it sounds like changing anything is not needed at all, as you a have already said.
http://forums.nasioc.com/forums/show....php?t=1363260
Old 05-16-2010, 01:48 PM   #94
Dashome
Member#: 226806
2009 WRX
Since you have your WRX projectors out, I was wondering if you could snap a picture of the stock cutoff shield from each side. I used an MDX bowl but used the WRX shield and TSX-r clear lens and had a little bit of glare above the cutoff. It is not as severe as the pic from the kit but I was looking to do something about it. I was hoping to see the shape of it in case this is the problem without having to take my headlights out to diagnose it. If it is a pain, then don't worry about it. Thanks!
Dashome is offline   Reply With Quote
Old 05-17-2010, 03:16 PM   #95
Robstunner
Member#: 134222
2015 WRX Limited
ISM
Hey man, got my TSX-R lenses in today! Looking to mod it up, but was wondering what size washers your using?
Old 05-17-2010, 03:24 PM   #96
CarbonXe
Member#: 211237
82 XJ 750
92 YJ 4.0
That's a good question, but I don't have an answer for it. The only thing I can provide, is a picture of the washer on the screw...
I had a small kit of misc washers, and I just grabbed two identical ones out of it...
Old 05-17-2010, 03:26 PM   #97
Robstunner
Member#: 134222
2015 WRX Limited
ISM
ok cool, i doubt it will make too much of a difference. Either way i can take the GF's car if needed to the local store, but god do i hate that neon
Old 05-17-2010, 03:28 PM   #98
CarbonXe
Member#: 211237
82 XJ 750
92 YJ 4.0
Just run down to Home Depot or Lowe's before you start the project, and find a small washer kit. Then you can just play with the spacing with the washers in the kit.
You actually might not even need to do the washer mod since you're using the OEM bulbs. I'm using the 85122+ bulbs, which have a bit more of a yellow hue to them over the standard 85122 bulbs, so you might get a decent amount of color with just doing the lenses.
Old 05-17-2010, 03:29 PM   #99
Robstunner
Member#: 134222
2015 WRX Limited
ISM
oh is that what you got? Good call ill go do that, thanks!
Old 05-17-2010, 03:33 PM   #100
CarbonXe
Member#: 211237
82 XJ 750
92 YJ 4.0
Yeah, something like this.
http://www.amazon.com/350-Lock-Flat-Washer-Assortment/dp/B000XVYPQ6
My WRX...Now With 100% More Car Frog DonkeyPunch Member's Car Gallery 60 10-13-2007 10:38 AM
2006 Aspen White STI pics.. now with 100% more Gram Lights SCRAPPYDO Member's Car Gallery 12 09-18-2007 06:23 PM
The Exeter Subaru meet june 18th- $25 06 STi raffle- now with 100% more autox Keith New England Impreza Club Forum -- NESIC 129 06-19-2006 02:13 PM
My SVX, now with 100% more STi! Bwana Member's Car Gallery 48 05-20-2005 11:27 PM
Impreza: Now with 100% more STi lip action Versus Member's Car Gallery 36 04-16-2005 08:58 PM
