Welcome to the North American Subaru Impreza Owners Club Wednesday October 17, 2018
Old 09-26-2002, 02:09 PM   #1
UGotWRXed
Member#: 17089
Default Vishnu stage 2/TXS stage 4 setups
got a question. ive been reading this forum for a while, but havent quite got the wrx yet.
what i wanna know is would buying all the parts that come in either the vishnu stage 2 or the txs stage 4 separately be cheaper than actually buying one of those packages?
or would it be cheaper to buy, for example:
a bigger turbo
spark plugs
IC hoses
injectors
etc.....
also, does anyone know what a wrx with one of these packages generally runs in the quarter mile?
thanks for your help.
UGotWRXed is offline   Reply With Quote
Old 09-26-2002, 02:17 PM   #2
gossamer_monster
Member#: 3574
Blase' Yellow----R.I.P.
Well I can`t speak for Shiv but TXS sells the parts the same price as in the stage. So you can slowly build the stage or just jump right in.
As far as stage 4 times, I don`t believe Vishnu has a stage 4, and their stage 3 isn't really comparable to the TXS stage 4.
Vishnu uses a hybrid garrett turbo while the TXS stage 4 uses a VF30/VF34.
I know TXS is working on a variation that uses a nice hybrid garrett.
With a TXS stage 4 people have been running mid to low 12's (depending upon drive ability) and high 11's with no2.
I haven`t really seen any actual Vishnu Stage 3 times just assumptions.
Bill
gossamer_monster is offline   Reply With Quote
Old 09-26-2002, 02:54 PM   #3
phillywrx
Member#: 19876
2017 Audi S3
both the vishnu 2 and txs 4 are pretty much the same (insofaras what each of them chose to replace on the stock wrx). all the main components anyway.
turboxs stage 4: cost $3753
Pre-programmed Unichip Piggyback Computer
TXS Plug & Play Harness
TXS 4" Stainless Steel Downpipe
TXS 3" Stainless Steel High Flow Cat
TXS 3" Stainless Steel Midpipe
TXS 2.5" Stainless Steel Muffler Assy
TXS Uppipe
IHI VF30 Turbocharger
Subaru STI Fuel Injectors
255 Litre Fuel Pump
Resonator Box Removed
60.1% increase over stock hp
no quarter mile stuff on website
vishnu stage 2: cost $4350
Turbo-Back Exhaust System
321 Up-Pipe Kit
Underdrive Pulley
Silicon IC Hose Upgrade
VF 30 (or VF 34) Turbocharger
STi Fuel Injectors
Upgraded Fuel Pump
Unichip Engine Control System
Adjustable Manual Boost Controller
Colder NGK Spark Plugs
Vishnu Billet Battery Tie-Down
50.7% increase over stock hp
Mile: 12.9-13.3 seconds @ 99-102
phillywrx is offline   Reply With Quote
Old 10-09-2002, 02:05 PM   #4
CTRallyRacer
Member#: 18982
2002 Impreza WRX
Ok... I've been reading through most of these posts... and I really want a TXS Stage 4 kit next spring. I was also told by a few people, that Stage 4 kits are cracking blocks or doing weird things to the car. Is this true... I don't want to spend $4k and blow a motor.
CTRallyRacer is offline   Reply With Quote
Anyone ran 1/4 mile with Cobb stage 2 and stage 2 HWG map? txl146 Engine Management & Tuning 2 05-15-2005 08:08 AM
TXS Unichip Stage 2 to Stage 3 E12 Engine Management & Tuning 4 07-12-2003 12:04 PM
turboxs stage 2 to stage 4 frdawg Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-04-2003 07:11 PM
Vishnu Stg 2 TXS stg 4 comparo [email protected] Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 60 11-19-2002 11:40 PM
TXS Stage 2 in 1/4 mile? Gman094 Proven Power Bragging 16 09-18-2002 05:24 PM
