Welcome to the North American Subaru Impreza Owners Club Tuesday December 18, 2018
Old 12-24-2002, 01:40 PM   #1
ChrisWRX
Member#: 17117
2002 M3
Default UTEC stage 4 map with Vishnu stage 2?
Can I use a UTEC stage 4 map with the Vishnu Stage 2 kit since the components are almost identical? How would this setup work out?
ChrisWRX is offline   Reply With Quote
Old 12-25-2002, 03:26 AM   #2
Redleader
Member#: 14430
'02 WRX Wagon WRB
STi swap luvin it!!!
Thats what I am doing now, but I am overboosting. 19 PSI+
I told Mark theat I has a Vishnu stg2 and he loaded their stg4 map for me.
I think I need to lower the boost in the map because I have turned the ABC all the way down and I still am overboosting.
The stg4 map boost only has boost numbers in the last 4 columns:
1. If I lower the numbers there will it loower my boost levels to stop the overboosting?
2. If I paste numbers into the earlier columns will boost build with less throttle?
Thanks, Mitch
Redleader is offline   Reply With Quote
Anybody running the stage 4 map with a VF22? L80Killa87 UTEC 5 06-13-2006 09:36 AM
Will I be okay? Stage 4 map with 20g for 200 miles. Justin962 Engine Management & Tuning 3 02-27-2005 07:14 PM
TXS Stage 4 map with stock TMIC Zola Engine Management & Tuning 4 05-21-2003 03:01 PM
anyone have a UTEC stage 4 map with ION instead of a VF30 frdawg Engine Management & Tuning 0 04-14-2003 10:55 PM
utec stage 4 map and stage 4 tmi map the same? datdudedennis Engine Management & Tuning 4 03-19-2003 12:37 AM
