Welcome to the North American Subaru Impreza Owners Club Wednesday August 12, 2020
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 10-30-2013, 11:32 PM   #401
htownboxer86
Member#: 261422
06 WRX TR
UGM
Simple answer: Get as far away from the UTEC as you can......It's a POS. You only have a small window of tuning with your ECU as it is simply a piggy back. Best advice, go stand alone EMS ECU or ACCESS PORT V3. Gives you complete and total access to tuning your ECU to you're hearts consent. Car will be running as smooth yet beast like as possible......just my 02.
htownboxer86 is offline   Reply With Quote
Old 11-09-2013, 01:59 PM   #402
GiovannieSTI125
Member#: 349053
2004 STI
Question Firmware 5.8 for Utec
someone have the firmware 5.8 for Utec?
GiovannieSTI125 is offline   Reply With Quote
Old 11-19-2013, 10:11 AM   #403
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
http://turboxs.com/shop/attachment.p...attachment=111
fastnoypi is offline   Reply With Quote
Old 12-13-2013, 01:25 AM   #404
andrew94
Member#: 328468
07 Sti
UGM
Are the UTEC's easy to learn how to use? I need a good tune but there arnt any close tuners that are somewhat close in elevation as well. Its got a decent tune on it right now from VA but elevation has changed by over 1000ft. Iv never tuned a car before so im asking if it is easy to pick up on. Any info would help! (PM perferred)
Thanks in advance.
andrew94 is offline   Reply With Quote
Old 05-21-2014, 09:05 PM   #405
churrey1
Member#: 389994
05 WRX Wagon
Grey
Default tune question
i bought a 2005 wrx with spt intake, catless uppipe, invidia 3" high-flow catted downpipe, catless midpipe, perrin catback. had the CEL on for AFR sensor on manifold. i replaced this, and it passed inspection, and has no engine light. The mechanic told me the cat code still reads "not ready". im thinking it must have an aftermarket tune to hide the light, probably a custom protune? is it worth it to take it to a tuning shop and have them check it out and make sure the tune is good? it smells rich, and inside of tailpipe is all black. everything else is good and no knock or anything. from reading the FAQ i concluded that the cobb ap wouldn't work for these mods, so it couldn't have that, do i spend the money and get the custom tune or is the car already good?
churrey1 is offline   Reply With Quote
Old 05-22-2014, 01:21 AM   #406
zaxrex
Member#: 9898
Water Injected Blue
you are pretty extensive and your list of modifications. Didn't see anything about a Turbo XS Utec for tuning. I think you may have posted in the wrong forum if you dont already have it under the passenger footwell.
If this is just for the ecu reading not ready, it could be two things. 1) you haven't driven as many cycles and miles as is needed to pass onboard diagnostics. 2) the prevoius owner used a MIL resistor inline with the rear O2 sensor and is preventing diagnostics to be completed.
if neither, then I would try a spark plug anti-fouler adapter between the rear O2 and the pipe.
zaxrex is offline   Reply With Quote
Old 10-16-2014, 08:51 PM   #407
moop2010
Member#: 393650
Just need a little tuning advice for the utec, I'm running a 2.0 with a hks catback, 3in catless dp, turboxs tmic, aftermarket turbo inlet, k&n intake, 650cc injectors and a vf39. Right now I'm just using the basic stage 4 map from turboxs but ive tweeked a little bit for the setup. I'm just wondering if anyone has a better base map for a similar setup? Also its not wanting to boost right almost like there is a fuel cut happening, and it just won't boost smoothly. Kinda wondering if I'm maxxing out the stock fuel pump
moop2010 is offline   Reply With Quote
Old 02-07-2015, 01:49 AM   #408
Zolliuos
Member#: 412884
1997 Legacy L
green
Is there a way to turn off the limiter on the car?
Zolliuos is offline   Reply With Quote
Old 02-17-2015, 06:13 PM   #409
Seahawk
Member#: 71665
1994 Impreza
You can raise the rev limit if you are running the newer firmware
Seahawk is offline   Reply With Quote
Old 04-01-2018, 10:31 AM   #410
Snowbaordguy
Member#: 470783
2017 WRX STI
WHITE
Does UTEC work with linux based laptops?
Snowbaordguy is offline   Reply With Quote
Old 04-01-2018, 10:49 AM   #411
zaxrex
Member#: 9898
Water Injected Blue
OS doesn't matter.
If you can run a hyperterminal emulator and a serial port (or serial to usb adapter), you can interface with the UTEC.
Old 11-21-2018, 04:45 PM   #412
Ruthless_Obsession
Member#: 494259
were can i get hyperterminal emulator and firmware. i just got a 2005 wrx and want to know what the ute ems is set at. fyi I'm on a MAC PC
Ruthless_Obsession is offline   Reply With Quote
Old 11-21-2018, 07:43 PM   #413
zaxrex
Member#: 9898
Water Injected Blue
If your "PC" is running OS X, then you already have the interface,This link will get you connected if you are using serial to USB. I can't remember the last Mac that had a serial connection.
"Firmware" is already on the UTEC, after you connect you will see the version number and decide if you need to flash a new version. Nothing is installed on your computer.
Please understand the interface, variables, and values before editing any maps or settings. Good idea to make copies of the parameters and maps into the computer so you can revert of you mess up.
Improper settings can damage the engine, beware.
Old 11-22-2018, 04:11 AM   #414
Ruthless_Obsession
Member#: 494259
Thanks @zaxrex for the info. Yes I will need a serial to USB adpter. Also as for now I just want to know what it's set at i didnt install the utec. The car drives fine just would like to know. I dont plan on adjusting any thing till I can put a wide band a/f on
Old 11-28-2018, 02:10 AM   #415
Ruthless_Obsession
Member#: 494259
I have been searching for the manual the UTEC but cant find it any one know were I can find it. Thanks
Old 11-28-2018, 08:30 AM   #416
Seahawk
Member#: 71665
1994 Impreza
I have a pdf of the owners manual on my computer at home, PM me your email address and I'll email it to you.
Old 12-10-2018, 09:45 PM   #417
Ruthless_Obsession
Member#: 494259
i bought a serial to usb adpter connected it to the utec cable and plunged it into my macbook pro and nothing. Am i missing some thing or do i need to down load any thing.
UTEC fuel tuning question Davenow Engine Management & Tuning 2 02-27-2003 01:46 PM
New UTEC software/tuning questions RIDEwrx Engine Management & Tuning 48 01-23-2003 02:20 PM
UTEC Fuel tuning question? muddywaters Engine Management & Tuning 2 01-17-2003 08:44 PM
TXS UTEC sowtware/tuning question RIDEwrx Engine Management & Tuning 1 01-12-2003 06:47 PM
UTEC fuel tuning question rwroth Engine Management & Tuning 2 01-02-2003 06:25 PM
